Jun 24, 2019, 04:45 PM
120sr/200srx/230s/300cfx/200qx
targetingxmod's Avatar
So, the stock plastic prop is a 3 blade 32mm 1.4 pitch?
Is that data correct for the stock plastic 3 blade prop?
32mm
1.4pitch
3,2mm hole?
Jun 25, 2019, 02:34 PM
Epilepsy Awareness
Flying High Mike's Avatar
Originally Posted by AirDOGGe
Your wait is over. Just re-trace his path for good tips: https://www.rcgroups.com/forums/show...est-for-30-mph
Only 4 pages, so worthy reading all of it if you are a Recoil owner.
Subbed. I'll have to go back for the read. Thank you for that link Bud
Jun 25, 2019, 02:40 PM
Epilepsy Awareness
Servo freeze
Hi Guys, My Bud was doing something with his Recoil 17 and without thinking he set the stern on a hard bench. By doing this the rudder went all the way right and jammed.
I've tried everything short of rebinding. I do have a reversing servo cable but, not sure how to hook it up.
All ideas welcomed to help me un-jamb this servo.
Jun 25, 2019, 02:48 PM
Epilepsy Awareness
32mm
1.4pitch
3,2mm hole?
Scroll down a bit for more info.
https://www.amazon.com/Pro-Boat-2820.../dp/B0778P6M1Q
Jun 25, 2019, 09:09 PM
Originally Posted by Flying High Mike
Hi Steve, no I did not balance and the brass prop was very sharp. I wouldn't think this prop would need attention considering the money I paid for it. Come to think of it, I'm not sure if that prop will go onto my "Tru-Spin" prop balancer.
PBSPEED, I think I'll wait until you come up with a write up.
Ha, thanks! Coming soon.....!
Jun 26, 2019, 12:20 AM
Just Plane Nutts
AirDOGGe's Avatar
32mm
1.4pitch
3,2mm hole?
30mm dia.
1.4 pitch
3.18mm bore (1/8-inch or .125")
Jun 26, 2019, 12:22 AM
Just Plane Nutts
AirDOGGe's Avatar
If it is not damaged, then you should be able to open the case via the 4 screws and re-position it. Hope that the stock servo has metal gears.
If not, replacement servos are cheap.
Jun 26, 2019, 10:30 PM
Epilepsy Awareness
Thanks Steve, I'll check that out. How the heck do these servos jam to the point of no return? You would think the manufacturers would do something about this.
There is no way to set the throw on these TX's. I'd love to be able to put her on my DX9
