Sep 22, 2019, 08:41 AM
Mach One
captain MoMo's Avatar
Having said all that / this is my favorite T45 / Hawk model. The weight gives it a scale like feel and mine is relatively fast as I installed the inrunner motor with 12 blade EDF upgrade way back. It does draw some amps but it’s worth it IMO.
Latest blog entry: ESC and BEC Steup
Sep 22, 2019, 08:49 AM
capt soap's Avatar
Thanks fred. Will look at the online manual.
Sep 22, 2019, 03:27 PM
Originally Posted by fredmdbud
The size and detail parts make it heavy. It is not a rocket at 6S, some people have upgraded to 8S for more speed. The stock ESC is 130A, so yes, it does draw a lot of current. Its high battery drain and relatively short flight times have often been commented on here. This is not a plane to fly 100% throttle all the time. And because of the weight, the stall speed is higher accordingly. If the wings start rocking, you are approaching stall speed.
^ This sums it up perfectly. While I enjoy the way the plane looks (on the ground and in the air), it's definitely power hungry. I'm disappointed in the flight time to say the least. My timer is set at 2:30. I've tried to increase that with throttle management, but it's not stable at all if you slow it down.
Sep 22, 2019, 05:05 PM
Mach One
Sorry to see that its not making your cut. How many flights have you had on yours? Mine has over 150 flights for sure - I stopped counting. I love this model, perhaps its the mods I have done with the power system. One can always use the latest 9 blade FW 90mm EDF setup as I think its more powerful and efficient as compared to the older units that come with this model.
Sep 24, 2019, 03:43 PM
capt soap's Avatar
Got to maiden my jet this last Sunday evening, wow this thing tracked very well like if it had a gyro. Gave it 2 minutes for the first flight on a 5500 Lipo. Track well in landing configuration, but I landed in the grass next to the runway. It pulled all 3 gear out, including part of the top of a wing.
Now I need 3 new gear servos. Looking forward to exploring this jets fast side, and aerobatics.
Sep 28, 2019, 07:57 PM
capt soap's Avatar
With 2600 watts, I'm hoping it's faster than the stinger, f15.
Sold Freewing T-45 Goshawk Super Scale 90mm EDF Jet - ARF PLUS - New in Box RCflyerCT Aircraft - Electric - Jets (FS/W) 5 Jan 19, 2017 06:58 AM
Sold Anyone in need of a Freewing T-45 Goshawk 90mm Fuselage Parts ? storm57 Aircraft - Electric - Jets (FS/W) 0 Dec 04, 2016 05:22 PM
Sold FREEWING 1238mm T-45 GOSHAWK 90mm EDF KIT VERSION with FULL Servos ebelling1 Aircraft - Electric - Airplanes (FS/W) 2 Aug 15, 2016 04:52 PM
Sold FREEWING 1238mm T-45 GOSHAWK 90mm EDF KIT VERSION with FULL Servos ebelling1 Aircraft - Electric - Jets (FS/W) 0 Aug 15, 2016 04:25 PM
