This thread is privately moderated by Red.Sneakers, who may elect to delete unwanted replies.
Jan 19, 2015, 10:57 AM
2016 The Year for Air Shows
Red.Sneakers's Avatar
Mini-HowTo
My DX9 Settings & Voice Alerts
I like to standardize my DX9 Tx settings, just makes it easier to add new models & remember what’s what. Here are some of my standard settings for all my umx aero & some other models. Setting may not apply to some aero. As every model is different, please bench test all your settings using the monitor & during a pre-flight check. I will tweak these settings for each model & after some flight tests.
I have also included a copy of the DX Custom Voice Alerts as reference, see footer for pdf file. Suggest you print it and highlight those you normally use. By knowing the sequence number, you can find them faster once you know how many positions you travel with one roller roll, like a dance: fast, fast, slow.
Trainer
Wireless Trainer = Master has All controls (co-pilot controls assigned at the field)
-------> Switch = A
-------> Master Over-Ride = Inhibit
Trainer Alerts
-------> Instructor = Voice = Instructor Control
-------> Student = Voice = Student Control
-------> No Signal = Voice = No Student Signal
Servo Setup
Travel
-------> Ail = 98 / 98%
-------> Ele = 98 / 98%
-------> Rud = 98 / 98%
D/R (default High / Mid / Low) & Expo (not used)
-------> Ail = 100 / 85 / 70% Switch = F
-------> Ele = 100 / 85 / 70% Switch = G
-------> Rud = 100 / 85 / 70% Switch = C
Note the switches are those located closest to the corresponding stick
Throttle Cut (default for Cut = switch up)
-------> Position =---125%
-------> Switch = H
-------> Position = 1
Mixing
-------> Mix 1 = -B- > Ele : Rate = ---5 / 0% : Offset = ---100% : Switch = B : Position = 1
-------> Mix 2 = -B- > Ele : Rate = 0 / 11% : Offset = 0% : Switch = B : Position = 2
-------> Mix 3 = -B- > Ail : Rate = 0 / -10% : Offset = 0% : Switch = B : Position = 2
Dual Timer => https://www.rcgroups.com/forums/show....php?t=2299554
Telemetry
Flight Log
-------> Frames > 0 = voice
-------> Holds > 0 = voice
-------> Status Reports = 30 sec
File Settings
-------> File Name = (name)
-------> Star = On
-------> One Time = Inhibit
-------> Enables = Yes
Custom Voice Events
-------> Switch H = Smoke On / Throttle Cut
-------> Switch L Lever = F-log / Time Remaining / Time Remaining
-------> Switch B = Normal / Stability / Circle Mode (normal, trim ele down / auto circle)
-------> Switch C = High Rate / Mid Rates / Low Rates
-------> Switch F = High Rate / Mid Rates / Low Rates
-------> Switch G = High Rate / Mid Rates / Low Rates
-------> Switch E = Stability Mode / Smart Mode / Agility Mode (for SAFE models)
-------> Switch I = System Idle / Bailout (for SAFE models)
-------> Switch D = Speed / Cruise / Thermal (used to trim down ele)
