Jan 09, 2002, 12:51 PM
It wasn't me...
DanSavage's Avatar
Originally posted by Gordon
Thanks for the 3-view which is now archived (along with those super colours shots!)
Ref the splitter plate, I am assuming that what will happen is the inner duct walls will eventually meet at a vertical knife edge just in front of the fan. This is the way most modern GDFs are arranged, so must be the right way...
You're welcome. It's the 3-view that I've been using for my design and it's reasonably accurate when one view is compared to the other. I have a couple more colo(u)r shots of the "City of Jacksonville" paint scheme that I'll put online later today.
The second generation Y/A A-4 includes both features you've described. I've noticed that all of the Viojet models which use a bifuricated inlet system are this way as well.
On the other hand, glow models with a single inlet like the F-16, F-86, etc. do not have a splitter plate.
Thanks for posting the detail pic. It's always interesting to see how other people accomplish a given task and I think you've done an admirable job with both the ford and the scooter.
In contrast, I'd planned to have a straight shot from the inlet bulkhead to where the duct halves join.
Dan
Jan 09, 2002, 02:22 PM
It wasn't me...
DanSavage's Avatar
Re: Re: F-106 Delta Dart...
Originally posted by GregG
I did some tests on a small fan some time ago. These involved testing the trust and ampdraw of the fan while running and then moving a splitter plate into place just in front of the fan face.
The ampdraw went down slightly and the thrust improved with the splitter plate installed. There was also a noticable RPM increase by the sound it was making.
Very interesting. Did you perform this testing with a bifuricated inlet or a single?
Dan
Jan 10, 2002, 09:52 AM
Speed Demon
GregG's Avatar
This testing was done with a single inlet. I was trying to use some 2" plastic fans I'd found at a surplus store to make a s300 powered EDF unit. They best thrust I got from one was a little more than 3 oz., and it was using 10 amps on 8 cells. The current drop was in the order of less than one amp.
Jan 10, 2002, 09:35 PM
Registered balsa abuser
Arngeir Blakseth's Avatar
Hi guys,
For all of you 106 buffs out there (you know who you are) might I recommend a book with a 3-view of your favorite plane?
The title is Aircraft Profiles Vol. 3 Military Jets
It's available from www.traplet.com
Arngeir
Jan 11, 2002, 04:02 AM
It wasn't me...
DanSavage's Avatar
Latest Update...
Hi All,
I've posted the latest construction update online. I've completed the forward fuselage. Next comes the cockpit hatch and inlets. After that is the rear fuselage. Then it's time to join the two halves and mount the wings and vertical fin.
Then the fun will really begin...
Click on the photo below to see the latest.
<center><a href="http://members.cox.net/marsavage/Dart/fwd_fuse.htm" target="_new"><img src="http://members.cox.net/marsavage/Dart/centenial_1.jpg" width="607" height="155"></a></center>
Dan
Feb 01, 2002, 02:48 AM
It wasn't me...
DanSavage's Avatar
Latest Updates...
Below are a couple of pics that show the progress.
I've completed the fuselage and am ready to mate the wings. Next comes elevon servo mounts and linkages, then finish the inlet lips and hatch over the inlets, then throw on a basic covering job. Should be ready for initial test flights next weekend.
I tested the WeMoTec MF480/AP-29L combo last night. Using 8 CP-1300 zapped it was pulling 22 amps for 211 watts. Next I tried a 10-cell CP-1300 zapped pack and it pulled 29 amps for 348 watts. As Herb has said, the AP-29L seems to be quite a motor. There was very little arcing at the brushes and the fan unit was turning up really well.
I'll keep you posted.
Dan
<center>
<img src="http://members.cox.net/marsavage/Dart/F-106_1.jpg" width="800" height="378"><br><br>
<img src="http://members.cox.net/marsavage/Dart/F-106_2.jpg" width="800" height="626">
</center>
Feb 01, 2002, 09:15 AM
Purple power
gregg f's Avatar
Dan: she's going to fly like great..........gregg
Feb 01, 2002, 05:05 PM
steve neill
steve neill
Guest
Dan,
Looks great and a simple concept to build. Good thinking!
Gregg and I are planning a couple of scratch F-104's later this year. You guys are really getting me going with
all the great stuff your doing for the contest.
Gregg and I have sort of our own contest, that being able to get the F-104 flying as a good EDF. With those
little wings it's a great challenge as will being getting all those nice contours in the fuse.
Steve
Feb 01, 2002, 09:57 PM
It wasn't me...
DanSavage's Avatar
Gregg:
Thanks! We'll know next weekend exactly how well it flys. It's a bit heavier than I'd originally planned. That might have something to do with the sheer size of this puppy. It's about the same size as the Flankers. All up weight with the airframe and all of the components including the 10-cell pack is just over 39 oz. I expect it'll be up to almost 3 Lbs. RTF. Even so, it'll still only have a wing loading of 17 oz./sq. ft. instead of the 12, I'd previously predicted. (Oh, darn )
Originally posted by steve neill
Dan,
Gregg and I are planning a couple of scratch F-104's later this year. You guys are really getting me going with all the great stuff your doing for the contest.
I'd like to take the credit, but I just integrated two technologies pioneered by others. The wing design came from Steven Ellzey's Apex and the fuse from Kevin Cox's F/A-18. Still, working at a leisurely pace, I've been able to get this far in only a month.
The F-104 is another of my favorite airplanes. the small wings don't make it that difficult to fly. They make it difficult to SEE!
I really like Kevin's style of design. He kept the cockpit section rounded for appearance and squared off the back of the fuse for simplicity. It's really a good, FAST, way to build.
I'll be watching for your "missile with a man in it."
Dan
Feb 12, 2002, 05:38 PM
It wasn't me...
DanSavage's Avatar
Yay!!
Hi Everybody!
After a couple of false starts, I had my first successful test flight today with the six-shooter.
The first was because I came onto the power too late coming off the catapult. (Works great, BTW!) The second was because I didn't have enough up elevator throw to keep the model off the ground.
The third attempt was a success and got a whole flight in. I'll post the video later tonight.
The WeMoTec MF480/Ky AP-29L hybrid worked great and pulls this model around the sky very well. Thanks for the tip, Herb.
That's all for now.
Dan
Feb 12, 2002, 05:44 PM
Purple power
gregg f's Avatar
yeah! good work. on the video, don't forget to include the first two attempts! hehe..............gregg
Feb 12, 2002, 05:52 PM
It wasn't me...
DanSavage's Avatar
Thanks!
They aren't called "belly-floppers" for nothing.
You got it.
Dan
Feb 12, 2002, 06:14 PM
steve neill
steve neill
Guest
Way to go Dan!!Can't wait to see the video, all of it!! Whats next?
Steve
Feb 12, 2002, 06:21 PM
It wasn't me...
DanSavage's Avatar
Thanks!
I need to get the markings on it and get it ready to fly at the MWE this weekend. It's only got the basic paint job. It needs the stars and lettering. Lots and lots of stars...
Dan
Feb 12, 2002, 06:25 PM
Lithium Member
Herb's Avatar
Wonderful! H
Wanted Savage Light F-106 Delta Dart Kit Atindra Aircraft - Electric - Jets (FS/W) 1 Aug 31, 2016 03:01 PM
Sold Convair F-106 Delta Dart kit J328 Aircraft - Fuel - Airplanes (FS/W) 3 Aug 20, 2016 05:21 PM
