Jan 20, 2015, 07:24 AM
Retired CAD guy
birdofplay's Avatar
I'm liking this one too.
Jan 20, 2015, 08:55 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Sat on my workbench, it looks quite big so I thought I would compare it with the Gripen JAS 39 ... here they are side by side
Just had a thought .... I have forgotten to install the servos for the elevons ... bugger
Lockey
Jan 20, 2015, 09:14 AM
Retired CAD guy
birdofplay's Avatar
Is everyone in Perth as invigorated as you,
or do you have all the oxygen from Shark Bay piped directly into your shop ?
On a Calm day You will have to take all your planes out and Photo the group !
Be sure to bring a WIDE ANGEL lens ! :-)
Jan 20, 2015, 09:18 AM
Lockey,
LOL!!! Happens to the best of us. But since yo have the top off, keep it off 'til you're able to run up the EDF. That's to make sure you're ducts don't collapse on ya. I'd advance the throttle VERY slowly, looking for signs of stress. If need be, you can reinforce the ducts with strips of fiber glass or carbon fiber tow CA'd on them. Space the strips about every 2" or so. But believe me, it is worth the work.
Ksqm
Jan 20, 2015, 07:09 PM
Lockey's Avatar
Originally Posted by ksqm
Lockey,
Ksqm
I already tested the fan Aaron, I ran it up to make sure it was running the right way and to test the thrust .. all seemed to be OK ... AND ... the top is already glued on
Thanks Bob, I guess I must enjoy building more than I enjoy flying oh ...
That said ... it would most certainly be a lot easier to build as a pusher than as an EDF
Lockey
Jan 21, 2015, 03:32 AM
Lockey's Avatar
Did a little more to the build today, seems to slow down at this point as most of the work is fiddly
I have tried a 2200 / 4s battery and it seems to balance easily with the battery under the canards, seems I won't have to move it to the forward compartment
I don't have a smaller 4's battery but I guess a smaller battery could move into the forward section to balance
Lockey
Jan 21, 2015, 06:30 AM
Lockey's Avatar
Ready for maiden ... all up weight with 2200 / 4s battery is 912 grams
Not sure yet how I am going to launch it ???
Lockey
Jan 21, 2015, 07:37 AM
Looks great cant wait to see it fly.
Jan 21, 2015, 08:36 AM
Lockey's Avatar
Cheers Kev, wish you were here to hand launch it for me mate ... tomorrow around 11 -12 am they reckon wind is low
Lockey
Jan 21, 2015, 08:45 AM
I have to agree with Loco1, it looks marvelous! I'm still collecting parts to start the build but hobby time is scarce...
Jan 21, 2015, 08:52 AM
Lockey's Avatar
Don't worry mate, when you get time ... its great been retired (semi retired anyway) only down side is getting old
She certainly is a bit of a strange looking beast eh ... hope I have the CG in the right place ... I am not sure how much lift the body (fuselage) will contribute
Lockey
Jan 21, 2015, 10:13 PM
Lockey's Avatar
EDIT:
I maidened her yesterday and BOY oh BOY I was lucky to bring her home in one piece
It was doing some really strange things, seemed to fly OK at full throttle but as soon as I went to a lower throttle she was a handful
I am pretty sure that it was tail heavy and I moved the battery forward for the second flight and then forward some more ... and I think it needs to go even further forward
Last flight I was about one and a half inches further forward than I started and still seemed a little tail heavy
I couldn’t move the battery any further forward as the Velcro that holds the battery in place wasn’t forward enough
Lockey
FS 2020 Maiden Flight (2 min 59 sec)
FS 2020 Second Flight (3 min 3 sec)
Jan 21, 2015, 11:40 PM
Lockey,
Just to clarify, you where moving the batt to the rear of the plane, to counter it being tail heavy? That is the tail of the plane was dropping in you? If tali heavy, move the batt forward.
Next I would check the thrust line. It would seem tail heavy, if your thrust tube is pointing up. If your thrust tube is not to the end of the tail cone, the tail cone could be causing the problem.
You can also check the alignment of the rudders. If the rear of the rudder is closer to the center line than the front, you have built in tail down nose up attitude. Also, how are the canards set? Traditionally, you want a degree or two, le up te down, so they stall before the main wing. You could go with zero incidence, move batt forward and try again.
The glide just before landing flair was pretty good. Where you providing any control inputs? Was power on at all? That made me think your thrust line was the culprit. Keep at it. Beautiful plane.
Ksqm
Jan 22, 2015, 12:11 AM
Lockey's Avatar
Yes mate, was moving the battery forward
Thrust tube is at zero, and th runs all the way through to the end of the tail cone ... EDIT ... just checked the drawings and it looks like the thrust tube is pointing up slightly ... about 4 mm at the back, which equates to 0.6 degrees (just over half a degree)
As far as I know, the rudders are parallel ( this was the reason for designing the rear end this way ... to keep the tails at the correct angle and position) and the canards are at a positive angle ... front up about 5 degrees (similar to the Gripen)
If you look at the glide on the fist landing in the second video, you will see it was just hanging there BUT it didn't stall and the second landing in the second video it was a better glide (battery moved forward) both landings were power off
Notice also, at the end of th roll (17 seconds in on the second video) it flipped very quick and wanted to roll further until I brought it back
I will be moving the battery further forward, couldn't move it any further today as I had no way of holding it in position
The other thing I did wonder was ... if the rudders (vertical tail fins) were big enough ??
Please check out the second video, I moved the battery forward on the first flight in the video and further again in the second flight in the video
Lockey
