Jan 10, 2015, 06:02 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Saab Gripen FS-2020
Saab Gripen FS-2020
This from Wikipedia ... The Flygsystem 2020 ("Flight System 2020", abbreviated FS 2020), is an ongoing project by the Swedish Air Force to develop a stealth fighter by 2020
Can’t find much info on this one but have started my drawings
Am looking at making the wing as part of the fuselage (Depron of course)
Please comment or if you have any other info please let me know
Lockey
Jan 10, 2015, 11:32 AM
Here is a video from the team at Linköping University that made a flying demonstrator for this design.
Swedish Stealth Fighter Jet (4 min 40 sec)
I was thinking along the same lines regarding the wing spar. I would use a 6x1mm CF strip as spar in the wing and sandwitch it between two ply formers in the middle.
However, when I build this plane it will probably be a pusher so using a straight spar right through won't be an issue
Jan 10, 2015, 07:20 PM
Lockey's Avatar
Thanks for the video kalleman, not seen that before
I did wonder about making it a pusher too ?
Lockey
Jan 11, 2015, 06:55 AM
Lockey's Avatar
Been doing a bit more work on it, I think a little more shape to it ... coming along nicely
Lockey
Jan 11, 2015, 03:39 PM
Looking good! Comming long nicely!
Jan 11, 2015, 07:30 PM
Lockey's Avatar
Changed the design (again) ... trying for an easy build with the wings now part of the bottom fuselage so that everything can be built into the fuselage before fitting the top/s in place
Lockey
Jan 13, 2015, 08:26 AM
Lockey,
Been lurking since you started this project. It is AWESOME! I've been tied up, trying to keep up with you on the Gripen build. Can't wait to reach retirement status! lol I'll have to get back with you a little later on you design set up. Many questions and suggestios.
Ksqm
Jan 13, 2015, 11:34 AM
Lockey,
Okay, done with my torture (work out) session. Some things to consider to optimize as an EDF. You can design for a certain size plane or design for the EDF unit you plan to use. At any rate, you'll have to match up the inlet area to the Fan Swept Area of the EDF. Don't know what your background is with EDFs, but you would probably benefit a lot by moving the thread to the Scratchbuilt EDF forum. You have a great bunch of guys who could offer you much more than I could. Years of hands on experience, scratch building EDFs.
In regards to integrating the wings with the bottom fuse, I'd go with keeping the wings separate from the bottom fuse. Use the wings to tie in the top and bottom fuses via the formers. If you did a pusher, you would have a single plane form for the wing. Do that and open up the center just enough for ducting and your EDF. Use a main spar tied to a former like you already have. Add a second spar tie in, towards the front of the wing. You would have fillets both top and bottom for additional support.
Ksqm
Jan 13, 2015, 08:11 PM
Lockey's Avatar
Ksqm
Thanks for the tips Aaron, what you suggest is basically what we are doing on the std Gripen
I was going for something a little different and experimental and for ease of building, maybe it will work ... maybe it won't
I did a similar build to what you suggest on my Dualis with interchangeable wings with 2 spars (see pics)
I will play some more and see how it develops
Lockey
Jan 13, 2015, 08:22 PM
Lockey's Avatar
Lockey,
Ksqm
As you can see from the pics, the area of the inlets (x2) are larger in area than the EDF ... Fan size shown in the pic is 72mm
I have been on the EDF section before, and whilst the guys there are well meaning, they tend to get too technical for me ... I like to try different things ... sometimes they work and sometimes they don't
All I know is that it is better to have a nice smooth transition through the inlet and it must be at least 100% of the fan and the outlet must also be as smooth as possible with around 85-90 % outlet ... both to have as few obstructions as possible
Maybe I will go with a pusher to start with ??
Lockey
Jan 13, 2015, 08:48 PM
Lockey,
LOL!!! Yes they can be technical, but they have been there and done it. I have some reference threads, that put's things in laymens terms. I'll send them when I get home. I've some 50mm Don's RC EDF units. I'll check the specs 'cause this plane NEEDS to be an EDF Plane. Awesome project!
Ksqm
Jan 13, 2015, 08:56 PM
Lockey's Avatar
Lockey,
Ksqm
Thanks mate please do send me the info, I can understand "laymans terms" (I think)
Are you going to build this one with me ? ... hope so ... you gonna use the 50 mm fan ?
I have a couple of the HK 50mm fans and one of the 64 mm ones (other is in a MIG15) and it flies well with a AUW of 1260 grams (with paint) haven't flown it since I painted it
Lockey
MIG 15 EDF (1 min 55 sec)
Jan 14, 2015, 01:56 PM
Lockey,
I haven't been able to get much sone in the last day or so, but take a look at this thread. Claus demistifies EDF basics. You can also search for other threads.
Ksqm
Jan 15, 2015, 07:15 AM
Lockey's Avatar
Lockey,
Ksqm
Thanks Aaron, interesting
I have almost finished the provisional plans / patterns for the FS-2020, I will get them printed and maybe start the build over the weekend ... looks like it will also take just over one and a half sheets of Depron and a sheet of card or thin plastic
I have once again done the plans on A1 size paper for printing, I find this the best size not only for commercial printing but for printing at home ... but of course, I can make them to suit Depron size sheets either
As usual, I will log the build and video the maiden and early flights and will post the plans once I am happy with the build
If anyone would like to BETA build one with me, please let me know
Lockey
Jan 15, 2015, 08:21 AM
Lockey,
You are one of those rare builder/designers, who see's what they want to build and just do it. One of the "Masters". And you have the TIME!!! You can sign me up. I have EDFs from 20mm up to 50mm. Decisions, Decisions, Decisions!!!
Ksqm
