Balsa Hobby King Fokker DVII - 47" - RC Groups
Jan 02, 2015, 12:22 AM
kdahlhaus's Avatar
Cool! I did not know they had this:
http://www.hobbyking.com/hobbyking/s...00mm_ARF_.html
Jan 05, 2015, 12:09 PM
Huge member!
BRUTUS2238's Avatar
It looks like a decent start for a somewhat scale version. B
Jan 07, 2015, 09:38 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
Doesn't the gear look a bit short??
SteveT.
Latest blog entry: My hangar...
May 13, 2015, 06:49 AM
Nil Illegitimi Carborundum
Threenaddies's Avatar
Here's mine
Just got this from HK Australia. It really is a superbly thought-out and manufactured model. The build quality is excellent and fittings are of good quality. It saved me scratcbuilding one and the outlines compare favourably with the Wingnut 1/32 and Eduard 1/48 - both of which I have.
The shiny covering makes it look toylike but that is an easy fix with satin acrylic clear.
The supplied guns and engine are OK when detailed a bit and The engine bay looks better shadowed out with matte black..
It comes with a surprisingly good pilot figure .
I have added fuselage cheeks out of plasticard and shallow conical wheel covers out of red craft card .
I'm just back at work but when I return in a couple of weeks I will post a PDF of the cheeks that should print out to the correct size on A4. And a method of making them. Also a template for the wheel covers.
It gets a NTM 35 900kv , E-flite SAFE receiver , 40A E-flite ESC , and I'm looking at Turnigy wooden slow-fly props and thinking 11" rather than the suggested 12".
Metal-gear servos installed. The supplied instruction manual is truly excellent BTW , and is a rare departure from the usual poorly translated and nebulous instructions we are given to expect.
This is made by Super Flying Model in Taiwan and they have done a nice job of it.
And credit to Hobbyking for supplying a model of this quality at a great price!
May 17, 2015, 01:03 AM
Well, based on your recommendation, I just hit the buy button! I recon it would benefit from having the wing slightly altered with 1/64 ply added to the leading edge (which would need you to recover the wing!!! But that's easy!
Cheers,
Hugh
May 17, 2015, 07:04 AM
Hi Hugh,
You wont regret it. I'm pulling the trigger on another one to strip/re-clad with lozenge.
Might tweak a few things to make it more scale but even as a starting point it would be hard to build from scratch for less.
Concealed servos and altered strut attachments could be quite nice and the ply would certainly be a good idea.
I just have to experiment with a decent, printable covering for the lozenge when I get time off.
There's a Japanese tissue paper that sounds promising and I have had reasonable results with brown masking paper.
Wright Brothers do 1/8 scale MG08 Spandau kits - close enough to 1/7.4 - and they look good.
Dave.
May 17, 2015, 12:26 PM
SteveT.'s Avatar
And lengthening the landing gear struts which (at least to me) appear to be too short...if you are going to strip and recover..
SteveT.
May 19, 2015, 04:37 AM
AMcC's Avatar
For Aussies, HHQ have these ARFs much cheaper and a kit version for $119
May 19, 2015, 05:00 AM
SteveT.
Indeed Steve! One of the things that will be worth looking at.
I have the Wingnut 1/32 kit and the Eduard 1/48 as fairly reliable references.
The Wingnut is worth the dough just for the nicely done instructions/detail booklet alone. The decal sheets are exquisite as well.
My second HK/SFM Fokker will be on it's way now.
May 19, 2015, 05:04 AM
I had a look at that site but they seemed to be a wholesaler only?
Can you order direct or simply get referred to a retailer?
$119 sounds great for a kit but I'm time-challenged and modding an ARF makes the extra $100 or so a good choice for me.
Found the retail link - HTdirect.com.au --- some great kits and planes there - quite like the SFM Pilatus.
Not bad prices on some stuff
May 19, 2015, 01:14 PM
SteveT.'s Avatar
The HTdirect.com does not work, unless you put .au on the end...so.. HTdirect.com.au...
SteveT.
May 19, 2015, 11:40 PM
Arrived today. Looks good.
One thing I will definitely be doing is what Steve suggested... Making the U/C legs more scale length and moving them back to where they should be (mounted in line with the Cabane Struts).
Cheers,
Hugh
May 20, 2015, 12:30 AM
SteveT.'s Avatar
Ok...so it wasn't just the picture!! I thought it looked a little strange. That like HK sells a Gee Bee that has horribly short landing gear which really makes the plane ugly..
SteveT.
May 20, 2015, 01:42 AM
Yeah, it's too short and way out of where it should be.
Should be easy enough to beef up where it needs to be though...
Cheers,
Hugh
May 20, 2015, 02:31 AM
Post some pics when you're done please. I'm going to post the cheek template when I'm back home 2nd June.
