This thread is privately moderated by JureZ, who may elect to delete unwanted replies.
Dec 24, 2014, 05:28 PM
Sokol
JureZ's Avatar
Radian
This entry relates to the Parkzone Radian, Radian_discussion_thread.
This story started like this:
Danny gave me as a gift, a Radian fuselage (thanks Danny !).
This fuse had a previous life as an FPV platform, with a power pod, pusher style, above and behind the wing trailing edge.
Dremel tool in hand, the pod was cut off.
I purchased a brand new set of wings and horizontal stabilizer from my LHS, 15 mi away ( HobbyTown, $44 total).
I used a 70 g brush less motor ( no data on make, model, specs), an equally unspecified ESC (I guess 30 A from its size...) , 2200 mAh 3S 25C Lipo battery , and a HK Super Kinetic folding propeller. Link to the HK folding propeller: Super_Kinetic_Prop
The motor was mounted in a non standard fashion , with the motor outside and ahead of of the Radian motor mount.
The motor current draw was 21 A at full throttle, on a bench static test.
The fuselage was covered with clear scotch heavy duty packing tape , which I shrunk with a sealing iron. This gave a lot of strength to the wobbly fuse...
Similar treatment with clear tape was applied to the wings, albeit not covering them completely, mostly the leading edge and the wing roots.
A couple of pictures are attached to this post showing the plane.
A roundel sticker for a HZ Corsair was placed under the right wing, three brown packing tape bars under the left one.
a video of the maiden flight can be found clicking on the link below:
Radian_maiden_flight_video_link
Dec 26, 2014, 06:54 PM
Sokol
JureZ's Avatar
Radian Videos
December 24, 2014 : Radian_maiden_flight_video_link
December 26, 2014 : Radian_video_Dec_26_2014 (using fixed prop , folder was out of commission...)
December 26, 2014 : Radian_video_Dec_26_2014_part_2_landing
December 27, 2014 : https://flic.kr/p/pCcU2N
December 27, 2014 : https://flic.kr/p/qzfxHy
December 27, 2014 : https://flic.kr/p/qz3HMZ
December 27, 2014 : https://flic.kr/p/qhACcx
December 28, 2014 : https://flic.kr/p/pCBXWU Danny flying his Radian
December 29, 2014 : https://flic.kr/p/qApMbV foggy morning, airborne camera, with rear view
December 29, 2014 : https://flic.kr/p/qAthvh foggy morning, ground based hat camera
Dec 27, 2014, 11:24 AM
Up, Up & hopefully away!!
flboy286's Avatar
JureZ ~ using the hard motor brake will stop your prop from spinning as you're gliding. The instructions are within your ESC manual.
Dec 27, 2014, 02:57 PM
Sokol
JureZ's Avatar
Thanks flboy286,
if I only had the manual for this esc !
Maybe I can try with some Hobby King generic ESC programming instructions..
Dec 29, 2014, 07:19 AM
Sokol
JureZ's Avatar
decalage mod
did the decalage mod, described by Paul Naton
Paul Naton : parkzone-radian-modifications-and-set-ups.html
the change let me remove 3 oz of weight I had in the nose section to make it flyable.
the CG location is 70 mm (2.75 in) back from the wing leading edge, as per the Vanessa machine.
AUW is 940g with 2200 mAh battery.
It flies wonderfully now !
May 27, 2016, 05:47 AM
Sokol
JureZ's Avatar
RADIAN wing and a carbon tube fuselage with V-Tail.
looking for a destiny for the Radian wings, got the idea of making a pure glider using the wing and a carbon tube fuselage with V-Tail.
This version has only V-Tail control (two servos) . Very little control authority.
Flying at Lariat Canyon, Walnut Creek, CA.
V Tail Radian glider Movie (0 min 45 sec)
Jun 02, 2016, 12:38 AM
Sokol
JureZ's Avatar
Franken Radian at Shell Ridge
Here is one more chapter in the history of my Radian.
Built using the original Radian wings, a Franken Glider Plane.
The Radian wings, were modified with added (cut) ailerons and two 9 g servos .
It is then a three channel system: Rudder , Elevator and Ailerons (on a Y cable) .
V-Tail , carbon tube fuselage (a kind gift from RCG Member Cityevader , Thanks!)
length : 44 " or 1165 mm
wing span : 80 " or 2000 mm
wing root : 7.7 " or 200 mm
AUW : 26.4 oz or 743 g
wing loading : 6.6 oz/sqin
Nominal Radian CG : 62 mm from Leading Edge
Pure glider, no motor .
It is much faster than the Radian as it has less drag with the CF tube fuse and V-Tail.
V-Tail Franken Glider Maiden Flight Movie (2 min 17 sec)
Dec 19, 2016, 09:22 PM
Sokol
JureZ's Avatar
flew the radian with the recently acquired "Emeter II RDU", was able to log elevation, flight battery voltage and current.
Very nice product, at a very reasonable price, now on sale.
Apr 10, 2017, 09:18 PM
Sokol
JureZ's Avatar
a video of the Radian using Mobius on-board video cam
Radian Mobius at the Bald Mtn Movie (2 min 2 sec)
Question Which for FPV..Radian or Radian XL Jim_W FPV Aircraft 7 Nov 23, 2016 11:42 AM
Discussion Parkzone Radian Pro vs E-Flite Radian Papo_60 Electric Sailplanes 20 May 16, 2016 11:35 AM
Found Parkzone Radian/Radian Pro 480B Reverse Shaft Motor PKZ4716 blissinindy Aircraft - Electric - Power Systems (FS/W) 1 Apr 28, 2016 01:04 AM
