Apr 11, 2015, 12:44 AM
Portland Oregon
Greetings,
A very nice looking model there. One quick question, did you glass and resin the outside of the Hull?
Andre
Nov 16, 2015, 04:34 PM
Joe Pierson's Avatar
I Pat,
What type of ESC did you use ?
Thank you,
Joe
Nov 16, 2015, 06:41 PM
P. Tritle's Avatar
Andre, I didn't fiberglass the outside of the hull -- but I should have. I simply sealed it with resin, but in transporting it to the pond on the stand has chafed it's way through the resin and into the soft wood, so now needs a bit of repair before she runs again. Personally, I would strongly urge you to sheath it with at least a 2 oz. cloth.
Joe, The ESC I used was a forward/reverse RC Car unit. It's one I've had around for a few years now so couldn't tell you what brand it is, but just about any appropriate F/W ESC will work.
PAT
Nov 16, 2015, 07:13 PM
AMA 937634
Stone1295's Avatar
Joe / Pat,
It looks like the HobbyKing ones. This may the model but not sure of the sizing.
https://www.hobbyking.com/hobbyking/s...w_Reverse.html
-Mike
Nov 17, 2015, 10:36 AM
Hi Pat,
One more question, (prop shaft using a section of brass tubing ) Can I buy a motor coupling
or did you make yours?
Joe
Nov 17, 2015, 11:27 AM
P. Tritle's Avatar
Joe, The drive hardware is available as a package from Dumas. It includes the stuffing box, prop shaft, prop and dogbone coupling.
PAT
Nov 17, 2015, 11:48 AM
Hi Pat,
Thank you, that will do it! Have a Great Holiday!
Joe
