Bandit F3P (free plan) - RC Groups
Dec 14, 2014, 07:49 AM
DiAbLo3D's Avatar
Hello !
I presented my "Bandit" it's a personal design.
840mm wingspan
940mm long
70g RTF
My equipment :
- Motor XPower XC2802/44 Nicolas Pietu Feather
- Glavak carbone prop
- ESC YGE 8S
- Receiver Aether Science RXF3P (Deltang)
- Servo 3x DSMS309 Topmodel
- Accu Turnigy nano tech 120mah
I join the plan on DXF.
Regards,
Mickael
Dec 14, 2014, 08:54 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Very nice looking model.
Thanks for posting the plans.
Did you crumple up the mylar before applying it to the frame?
What paint did you use on the Mylar?
Pat MacKenzie
Dec 14, 2014, 11:54 AM
juzchillin's Avatar
I love it !
Thank you for posting the plan. Would you mind if i made a 3d interpritation?
A flight video would be great if you can
Again Thanks
Dec 14, 2014, 01:01 PM
how did you get RXF3P to work with futaba?
i thought all rx's were for dsm2?
cheers
Dec 14, 2014, 02:23 PM
DiAbLo3D's Avatar
Hi !
Yes, I have crumple the mylar.
I use Tamiya acrylic paint.
juz chillin : sorry, I don't understand, you want to drawing a 3D model ? If that's : I have !
I have modified spektrum module for use RXF3P with my Futaba T8FG.
https://www.rcgroups.com/forums/show....php?t=1556607
First flight video :
Bandit F3P first fly (3 min 41 sec)
(bad quality)
Sorry the flight is very bad !! but the modèle is very pleasant and good réaction.
Dec 15, 2014, 12:54 AM
Originally Posted by DiAbLo3D
Hi !
https://www.youtube.com/watch?v=rwmD...ature=youtu.be
(bad quality)
Hello Mikael,
What timing/PWM frequency did you program on the YGE 8S?
I have the YGE 7S with the XC2802 motor on my mylar Disney, with a 9x2,8 prop and Hyperion 120 mAh 2S 25C battery, but it has not enough power for the vertical lines. All-up-weight of my Disney is 76,5 gr.
What's the size of the Glavak prop (diameter and pitch)?
Dec 15, 2014, 02:17 AM
Risto Hölttä - F3A/P Team FIN
Finnspeed's Avatar
Hans,
I'm using the same motor in a F3P plane that weighs 97 g ready to fly. I tested it with both SG 9 x 2.3 and SG 9 x 2.8 with good results. No problems in vertical uplines. In this case the ESC was Turnigy Plush 6A but the YGE should be even better.
In most cases the default settings (12 kHz, auto timing) of the YGE are good. I usually change the low battery cut off to 3.1 V/cell and set the throttle end points with the programming card. Check those and make sure you are getting full throttle. The LED on the YGE board (at least on the YGE 7) shows the throttle position. The LED goes completely off at full throttle.
Dec 15, 2014, 02:52 AM
Originally Posted by Finnspeed
Hans,
I don't have the programming card, but the throttle range is defined during the basic setup, no? Full throttle when arming the YGE 7S to get into programming mode (max. throttle stick position) and during the follwing 20 beeps throttle stick to the desired min. throttle stick position.
Actual settings I have programmed on the 7S: timing 30° and frenquency 11 kHz.
I do have noticed that the upper part (let's say above 85 %) of the throttle stick throttle range is not used, so indeed something might be wrong with the enpoint. Maybe I should have rebound the RX first.
Dec 15, 2014, 03:25 AM
DiAbLo3D's Avatar
Hello Hans,
I use basic setup on my YGE8. I have a propeller SG 9x2.8 and the power is very comfortable. I have limited the max puissance on my transmitter.
Dec 15, 2014, 05:22 AM
pmackenzie's Avatar
Get the card.
I found it can be easy to get the wrong settings, and hard/impossible to fix them using the stick programming.
It is a pain to have to solder a connector on it while in the model, but not impossible.
Even in the middle of a contest
Image by Xavier Mouraux
Pat MacKenzie
Dec 16, 2014, 01:46 PM
juzchillin's Avatar
Hello DiAbLo3D
Your video was great ! Thanks . I really like the way it turns so flat.
also i love your indoor arena . Wish i had an indoor place to fly .
I made some very small changes to your plan to fit my gear and will post my version shortly
I hope you approve
Dec 19, 2014, 07:59 AM
DiAbLo3D's Avatar
Originally Posted by juzchillin
Hello DiAbLo3D
I hope you approve
I agreeeee !! No problem !
You will share pictures when finished
Dec 20, 2014, 01:56 PM
DiAbLo3D,
Impressive airplane! so little foam. Great workmanship.
I see you are using the Deltang receiver. Are you supplying full 2S voltage to this receiver ?
Vince
Dec 20, 2014, 02:00 PM
juzchillin's Avatar
I normally don't post many pictures . But because you asked , Yes i will.
Dec 21, 2014, 01:57 PM
juzchillin's Avatar
This plane is presenting quite the challenge.
None the less . My plan is finished and i will begin cutting this evening .
Small pictures will follow
