Armattan Morphite V1/V2 180mm/224mm Micro Frame - RC Groups
Dec 11, 2014, 08:15 PM
ParagonUAV
MayMayDay's Avatar
New Product
Flips and Stuff [[Armattan Morphite]] (2 min 13 sec)
Bashing Concrete [[Armattan Morphite]] (3 min 27 sec)
Head On Crash [[RotorX]] [[Armattan Morphite]] (3 min 9 sec)
WHY?
So I wanted something a little more micro that many of my minis, something I could fly indoors without much worry. But not a weak brushed quad, I wanted to retain the power that many are used to on the mini frames while still maintaining the small form factor.
WHAT?
So I designed the Morphite 180mm. Unibody design for simplicity and weight reduction. But unibody means if you break an arm you have to replace the whole frame! Good luck, it's 3mm 3k twill carbon fiber. Also, should mention that it has a Lifetime Warranty on the CF components. So ya, good luck.
This frame is spec'd around running 3100kV motors on 3S and 4045 props to give some real speed. Or on 4S if you really want to break the space-time continuum.
Or, if you have a broken 200QX frame but good electronics, the V1 frame is compatible. Install onto this frame and don't worry about breaking it again.
HOW CAN I HAVE?
180/224 quad versions are available below!
http://www.paragonuav.com/
http://www.armattanquads.com/
Frame Specs and Recommended Components:
3mm Carbon Fiber Main Chassis (41.2g)
2mm Carbon Fiber Top Plate (~3.8g)
Armattan 1306 3100kV motors
Gemfan/HQ 4045 props
Armattan 20A ESCs
Mullet Acro FC
3S ~950mAh 35C (powerhouse!) or 2S ~1000mAh 25C (more docile flier, good for indoors)
Micro FPV cam
Micro 5.8GHz or 1.3GHz VTx
808/Mobius camera capable
Armattan Morphite 180 Build Log Part 1 (1 hr 1 min 8 sec)
Morphite V2 Assembly Video (1 min 14 sec)
Dec 11, 2014, 08:25 PM
Team cobra USA/ team n-armed
awdspider's Avatar
what cam and vtx were you using in the vid?
this little guy is gonna be fun
Dec 11, 2014, 08:26 PM
Oops! There goes a prop...
3s indoors? That would be fast. How's it on 2s?
Dec 11, 2014, 08:27 PM
d4ddyo's Avatar
Looking forward to getting mine
I posted in the Morphling but ill post here!
I bought a TS5823 vTx and want to be able to use it with my Fatshark dominators v2.
http://www.massiverc.com/PrestaShop/...connector.html
How do i wire this? with the Mini CCTV camera. http://www.surveilzone.com/0.008lux-...3.6-24v-hs1151
Can i put a power wire from the battery to the cam and video signal and video ground to the TS5823?
I could power both the vTx and the mini cam from the battery as they both can handle 12v.
Dec 11, 2014, 08:31 PM
I'm excited about this little guy,
Is there any way you can post some high res shots of the frame?
Dec 11, 2014, 08:33 PM
ParagonUAV
MayMayDay's Avatar
That video is done with this cam:
And this VTx:
http://www.readymaderc.com/store/ind...oducts_id=1301
I also had a MinimOSD with MWOSD, but hadn't changed my video type so it didn't display properly.
Like this (this is a different micro I'm working on)
Raiju On Rails (2 min 46 sec)
A lot more docile obviously, but I haven't actually tested it. I have a need for speed.
You'll need a filter off the PDB to the VTx, and then run 3 wires from the VTx to the cam. That'd be my recommendation (unless you're using an OSD).
The 5 preorders were the only CF frames I had, and they're all shipped to those that ordered them. Hopefully they can post pictures once they get them (though the design is changed a bit).
Dec 11, 2014, 08:53 PM
Team SRW
ares2180's Avatar
I will post pics as soon as it gets here. Tracking says probably Monday.
Dec 11, 2014, 09:00 PM
d4ddyo's Avatar
My vTx doesn't have a power out.
Dec 11, 2014, 09:05 PM
ParagonUAV
MayMayDay's Avatar
Solder the power wires going to the cam to the same pads where the wires coming from the filter attach to the VTx. This will share the power across them.
Dec 11, 2014, 09:12 PM
d4ddyo's Avatar
Thanks. Where do i get a the filter. I guess it's called an LC filter?
Dec 11, 2014, 09:17 PM
ParagonUAV
MayMayDay's Avatar
Yes, something like this.
https://www.rcgroups.com/forums/show...7&postcount=14
Dec 11, 2014, 09:20 PM
QuAd FaNaTiC
Razors edge 29's Avatar
Awesome
following this with great interest
Team SRW
ares2180's Avatar
Would this filter work?
http://www.readymaderc.com/store/ind...oducts_id=1854
Dec 11, 2014, 09:36 PM
d4ddyo's Avatar
sweet. just learned something new. I have been using 600mw vTx Immersion that powered the cam so never had to use this.
Dec 11, 2014, 09:42 PM
awdspider's Avatar
i have the camera you are using on the way. will this power combo pick up a fatshark 250mw vtx?
