Question
SkyRC iMAX B6 Mini; is it any good?
Hi folks,
I am looking for a new charger and the B6 Mini came up in my search. However I can't seem to find a lot of experiences from with this charger exept for the very few who are on the Banggood website. And these don't go in to details such as weither it's accurate or not, balances correctly etc... https://www.banggood.com/SkyRC-iMAX-B6-Mini-...-p-929890.html The biggest batteries I own at the moment are 3S 2200's and this will be the case for a very long time. To me it seems like a pretty decent charger for $40 and I like the fact that you can hook it up to the PC and there's the possibility to control it with your smartphone. Do any of you own this charger and are happy with it? ![]() |
I own one and love it - easy to use I charge a larger battery than you an E-Flight 3000mAh 30C and she does great - now make note of a few things
Only comes with 12 DC battery clips and so I had to find a wall adapter The temp strap add on works great The wifi module works well ! Not amazing Over all happy with the foot print and the usage / make sure to buy a real one lots of fakes !! |
goober ... where did you get WiFi module - still cannot find on BG site ..
Nigel |
Latest blog entry: 3D printed Vulcan and thoughts
![]() I still hesitate because the Turnigy Reaktor 300W (rebranded iCharger 206) is only +/- $25 more. They both need an additional power supply however a 300W power supply costs also a lot more than a 60W one. |
Most chargers in this range need separate power supplies and tbh - I prefer that ... Myself and many others I know have had in-built power supplies fail in various and you end up with separate anyway. The chargers without built-in are smaller and more compact as well.
Once I get info from Goober about the WiFi module - I might grab one of these mini's to go alongside the 2 B6 standard chargers I have ... The bits that interest me are the PC connectivity - why I want to know about WiFi - and the IR measurement. I have a dedicated IR meter - but it's a pain and needs power supply and so on ... so I rarely use it. This with built in facility will give me a reference check routine that is easier to use. Nigel |
http://feathermerchantrc.com/ More than enough power even if you move up to a PowerLab 6 or 8. 24V for about $90. Glen |
You can get a 60W adapter at Banggood for $8.98
https://www.banggood.com/Wholesale-PD1205-12V-5A-AC-...-p-49439.html |
Wall adaptors are two a penny on ebay .. HK .. Banggood .... and many shops.
For this a minimum spec of 60W and 6A is required ... but that is minimum. Personally I prefer to go higher spec and then adaptor is not pushed to limits when you set charger to max. I bought adaptor of ebay that is said for LED light strips and rated at 100W or 10A max. Price was about $15 incl. shipping. I have had a number of 5A adaptors supplied with my chargers just give out after about a year or less use ... my B6 50W chargers pushing them to limits. This mini charger is rated at 6A ... so do yourself a favour ... get a 10A unit ... Plugs can always be changed / sorted at local electrical shop. Nigel |
![]() If I would need a powerfull power supply I was thinking of using an LED strip power supply like this one: https://www.banggood.com/Wholesale-12V-30A-360W-Switch-...-p-39987.html? |
https://www.hobbyking.com/hobbyking/s...r_Charger.html
consider this unit if pricing and shipping work for you. |
My two 50W B6 chargers can if I really wanted to - be powered of the one adaptor I have .... but that would then at times push the limits. So I have a 50W adaptor - was a warranty replacement by the ebay seller for one charger ... and the 100W adaptor I bought for the other. In reality - there is no real reason to do an overkill on adaptor capacity ... unless later you wish to upgrade to higher capacity charger or multiple set-ups. When people talk of Computer power supplies - these are usually people who are running multiple or higher powered set-ups well above the average sunday flyers needs. They would argue though that they themselves are Sunday flyers !! ![]() What I suggest - is sit down. Think it through ... What will be your needs in say 2 years time ? Personally I think 2 years is the longest time to think ahead because of failure rates and replacement of gear. In 2 years most of us will be flying different gear or have modified requirements. Nigel |
Agreed considering how much watts it can deliver for the given price imax b6 mini is not cheap. I prefer reaktor or 106.
