SJCam SJ5000 ***Owners Thread*** - Page 5 - RC Groups
Dec 15, 2014, 01:25 AM
Firebird_PL's Avatar
Some photos from inside.
https://www.facebook.com/vat19pl/posts/1582985075258465
Dec 15, 2014, 05:59 AM
Mtz
Mtz
Mtz's Avatar
Sj5000+
Nice pictures, I couldn't remove the PCB, only the metallic part. Do you think the brown label is the wireless antenna?
Yesterday I uploaded a video recorded in the car at dusk time. Now one a little earlier of day:
SJ5000+ vs Mini 0806 - 1080p sunset wild road (1 min 32 sec)
Somebody asked if the sound is stereo or double mono. I think is double mono and this is a sound volume test at 60% setting:
SJ5000+ outdoor volume sound recording test (0 min 13 sec)
More nature pictures here.
And a short timelapse made from pictures:
SJ5000+ sunrise timelapse 4K from 16MP pictures (0 min 56 sec)
I think sjcam.com and foxoffer.com delayed the shipping because firmware have some problems and I consider is not finished even you can see camera is working, recording, taking photos.
enjoy,
Mtz
Dec 15, 2014, 08:28 AM
Thanks for posting videos and pictures!
I have the SJ4000 a half year, very impressed for 85$ camera.
I expected more from the 5000, I don't know which sensor it use but its definitely not 16MP.
Will wait to see more videos and photos at clear sunny day, right now I don't think its worth 170$.
Dec 15, 2014, 11:03 AM
Moscú fpv
shuricus's Avatar
Considering this - $128 for Sony cam!
Price for SJ5k doesn't look attractive AT ALL!
Dec 15, 2014, 11:21 AM
yeah, but not very gimbal friendly shape factor
Dec 15, 2014, 11:36 AM
Exactly....
Dec 15, 2014, 11:55 AM
RocketMouse's Avatar
Sony isn't the best cam for gimbals, but price for sj5000+ should be less for sure.
Dec 15, 2014, 04:09 PM
Mtz
Mtz
Mtz's Avatar
Sj5000+
The battery was going from full to empty in 47 minutes (latest 5 minutes were with „Low battery” warning on LCD display) of continuous recording and:
- 1080p 60fps
- dual streams enabled
- Wi-Fi = On and streaming to my android smartphone
- LCD= On almost all time.
The latest file was saved correctly when camera was shut down because empty battery.
enjoy,
Mtz
Dec 15, 2014, 04:25 PM
What's dual streams?
And do you happen to know weither the SJ5000 uses the same battery as the SJ4000?
Thanks for all the info btw!
Dec 16, 2014, 02:26 AM
Mtz
Mtz
Mtz's Avatar
Sj5000+
It is using the same battery as SJ4000.
Next things are about Android application and smartphone because this is what I have. I don't have iOS devices or tablet, which should work in the same way both.
Dual Streams = On is needed if you want to use the wireless connection.
Dual stream means the camera is recording at the same time the video at your selected resolution (for example 1080p 60fps) and another video with very low specs 240p 10fps, 615kbps needed for live viewing on smartphone screen of the current recording.
If you want just live viewing but not recording you can disable Dual Stream in camera settings and you will have live view of the high resolution you set on SJ5000+.
This dual stream mode cannot be set from Android application and I posted few screenshots from application/camera settings here.
You can see these settings which are available in reality if you enabled Dual Stream = On:
Playback streaming (High resolution - Low resolution)
Download size (High resolution - Low resolution)
For example a 1 min High resolution video is 180MB and the android application is telling you that you need 6 minutes to download the video from camera to smartphone storage. When you want to play it to your Android smartphone it will take a lot of time to buffer it.
For 1 min (20MB) of Low resolution you need 1 minute do download.
About file sizes:
The filesizes are always multiple of 20MB. For example: 20512 KB, 40992 KB, 61472 KB, 81952 KB and these example sizes are for small test videos between 2s and 20s. For example a 8s, 11s, 13s video will have the same size, 40992 KB.
More about wireless:
- I consider the Wireless is needed when you want to start/stop the recording and you don't have access to the place were camera is . For example the camera is under water and you want to start the recording only when you see some activity.
- The smartphone application is better to be started when SJ5000+ is in stand by and not recording after pressed the camera button.
The card must be always inserted in the camera because the Wi-Fi settings are on the card. So you cannot have live streaming on your smartphone without card inserted. You can not trick the camera to start smartphone wireless connection when card is inside camera and then remove the card because you want to use just the live viewing. You need at least one old card, even 1GB size.
- Wireless area coverage is depending a lot of open area or not and your smartphone quality components.
- You need to set the SJ5000 Plus to always on to not lose the live view.
enjoy,
Mtz
Dec 16, 2014, 04:11 AM
Did original battery from camera SJCAM SJ 4000 or camera SJCAM SJ 4000 Wifi go to new Sjcam SJ 5000+?
According to http://www.banggood.com/3_7V-900mAh-...-p-949908.html battery from SJCAM SJ 4000 Wifi is not sutable for SJCAM SJ 4000?! If correct, how is that possible?
Dec 16, 2014, 04:18 AM
Mtz
Mtz
Mtz's Avatar
I think that info is there before SJ5000 series were released.
I have the info from official site.
enjoy,
Mtz
Dec 16, 2014, 10:36 AM
Mines is getting shipped on saturday
Dec 16, 2014, 11:41 AM
Mtz
Mtz
Mtz's Avatar
The LCD screen of SJ5000 Wi-Fi is 2", bigger than 1.5" SJ 5000 Plus.
More comparison between SJ5000 WiFi and SJ5000+:
SJ5000 WiFi vs SJ5000+ slideshow pictures comparison (1 min 38 sec)
Video out cable for SJ5000:
SJ5000 Plus - Menu settings (6 min 23 sec)
SJ5000+ menu and settings:
SJCam SJ5000, SJ5000Wi-Fi, SJ5000 Plus - analog Video Out connection (5 min 34 sec)
enjoy,
Mtz
PS: of course I will make video comparisons between both SJ5000, side by side. ;-) I hope a good weather without storm and rain.
Dec 16, 2014, 04:38 PM
From where?
bob
Discussion SJCAM SJ5000+ Plus 2K A7LS75 **Owner's Thread** sjcamhd Aerial Photography 124 Mar 31, 2017 02:57 AM
