May 11, 2004, 08:18 PM
d_trafalgar's Avatar
Vamoose - Cl-i-max Models
I thought I would show you guys how my Vamoose beta was progressing.
Should be ready for maiden by the end of the weekend.
Spec's:
Span: 38 in.
Area: 297 sq.in.
Weight: 16 oz (Less Battery).
Symmetrical Airfoil Section
4 Naro/Pico Style Servo's
Motor: TBD - I'll be doing my initial tests using a Razor 400.
David
May 11, 2004, 08:33 PM
hyperknight's Avatar
David
Nice, but will it have an actual clear canopy?
hk
May 11, 2004, 09:08 PM
hk
Yes.
D
May 11, 2004, 10:03 PM
Crash Master
Gene Bond's Avatar
Very nice, David.
Almost looks like it could be modified for retracts
May 11, 2004, 10:22 PM
i now have a wasp and an axon,. i'm waiting for this one , it will be my next kit !
hurry hurry hurry.......
spithungry
here's my axon, with a razor 2500a in the nose :
May 12, 2004, 03:08 AM
One Piece Wing??? and Battery Area Width
David
Dave, is the Vamoose designed with a one piece wing?? I like the open motor design for cooling...what about the battery area...is it wide enough for the new LiPos coming to market...seems like the newer versions of the LiPos are wider (i.e., they have taps for balancing)...1500mAH are 42mm wide.
May 12, 2004, 04:42 AM
veni,vidi, roto volubilis
Happy|Harry's Avatar
david the vamoose is looking great , i especially like the size of it. good luck with the maiden and i
look forward to reading the flight report
phil
May 12, 2004, 05:22 AM
Looking great David!
Putting it down on my wish list..
Geof.
May 12, 2004, 08:53 AM
Leave me alone!
Martin Hunter's Avatar
I've said it before but that is one beautiful design. I expect she'll fly like she's on rails. Keep those pics coming, Dave.
Martin
May 12, 2004, 09:54 AM
Yes.
That's my little nod to the old gasser's....
In fact I think there is plenty of room for a ICE up front....
No reason to be confused Mike... I've attached a picture that I hope will clear things up. There is plenty of room for the new batteries I think. The standard battery compartment size is 2" x 1.7" x 4.5", but there is room to move. If you opt for mounting the rudder and elevator servo's near the tail the battery compartment can be extended to ~12" in length. The batteries in the picture are 3 x 1200 e-tech's.
David
May 12, 2004, 01:14 PM
ronrandle's Avatar
David, I'm all over this one!! How about some specs? WS, weight, recommended gear?
Thanks a bunch.
Ron
May 12, 2004, 01:36 PM
Thanks a bunch.
Ron
Ron,
I've added some spec's to the original post.
I'll be experimenting and having the beta testers
experiment with different motor/battery configurations.
David
May 12, 2004, 02:06 PM
Scott Stoops
sukhoi26mx's Avatar
Very pretty design! Is it one aileron servo or two? I really like the simplicity of the landing gear.
Scott
May 12, 2004, 02:26 PM
Thanks Scott,
There are two aileron servo's.
The landing gear design is the
same as I did for my Sin-Naps.
David
May 12, 2004, 04:41 PM
How about a pic of the canopy? If it flies anything like the Axon... I make sure to get my name on the backorder list!
dlee
Sold Cl-i-Max Models Wasp-maX kit Twmaster Aircraft - Electric - Airplanes (FS/W) 1 May 14, 2010 07:01 PM
Sold Reduced! - NIB Cl-i-max Models Wasp-maX kit Three-Wire Aircraft - Electric - Airplanes (FS/W) 7 Jun 28, 2008 04:01 PM
