Guys, I have a couple of questions I'm hoping someone can chime in on;
1 - Is it possible to mount the FC to the underside of the top plate? Can you get 90 degree pins to make it so that the FC is thinner? I'm hoping to be able to fit a larger battery (1800-2200) on the bottom plate but pushed forward of the FC. 2 - The arms on this unit can come off, has anyone created arms with a 'twist' for forward sloping motors? Cheers. |
If you want a larger battery just mount it on the top. Saves all kinds of problems. Quote:
There is no special mixing in the radio. |
So just in case you are still set on getting another radio, and444, I'm super happy with my FrSky Taranis. Range is great, price is a fraction of the big-brand radios and it has built-in telemetry so you can have the transmitter read out the receiver signal strength to you while you fly, i.e. you will know the signal is getting weak before you fall out of the sky. Best investment for FPV I've made, hands down. Rx is same size as stock and no special mixing happens in the Tx, so no problem swapping it out. |
Yes, go through the Transmitter setup wizard in OpenPilot GCS and it will ask you to wiggle your flight mode switch eventually to calibrate it all
Hey guys. I just ordered the new frame: http://www.helipal.com/storm-racing-...tning-250.html
I will record a youtube review, anything you want to know about it? This is my channel btw: https://www.youtube.com/channel/UCPe...G_kaAhVkxT9t7Q Juan |
Eneloops by Panasonic work great! A single charge lasts weeks.
Anyone else eyeballing this? Looks like an awesome option for a PDB on this bird.https://www.rcgroups.com/forums/show....php?t=2342983
