Thread Tools |
This thread is privately moderated by Up&Away, who may elect to delete unwanted replies. |
Build Log
RCRCM eTyphoon
My first glass slipper! Well technically, my second. My first new glass slipper then.
My first one was a very nice second hand Jaro Muller F5J glider, which I dorked on the second flight, because I thought the guy who soldered the BESC and ESC knew what he was doing. And because I ignored the fact that during pre-flight I had to plug and un-plug the battery a few times for the ESC to give the proper signal. Water under the bridge. A while ago I tried to compete in a friendly slope soar event. During a quick pre-race flight I landed my Speedo hard in the sand, and the fuse broke in two places. That left me with a 8 year old WeaselPro to compete. Suffice to say my times were not very good. Consistent, but not very good. The seed was sown. I now wanted a “proper” full house sloper. (The Speedo mishap was partly due to the lack of landing speed control with a 4Ch Rx) Gliders were compared, prices were compared. And in the end I decided that, for me, the current best available and best price, was the Typhoon of RCRCM. Two hangar queens were sold, plus the “leftovers” of the Jaro Muller glider, and I had enough funds in my hands to put an order in. Two weeks later: ![]() Can’t complain about the way they packed and boxed her. ![]() Suit included. ![]() Tadaaaaaaah ![]() The included goodies ![]() Servo frames and covers ![]() Elevator rods and control horns ![]() Clevises and motor mount. (I think the threaded rods are doubling as pushrods for the ailerons and flaps. Seems a bit iffy, but we’ll see) ![]() Wings wiring ![]() Elevator and rudder hollow carbon pushrods ![]() ![]() I don’t know how consistant they lob of the nose, but the inside diameter here is just under 33mm. The carbon inlay causes a slight “bump”. ![]() Nice thick carbon matting under the wings’ servo hatch ![]() ![]() View of the root. You can just make out a hint of carbon inside the spar box. ![]() View towards the LE. One balsa spar, just visible inside the servo hatch ![]() View towards the TE. Another balsa spar, just visible inside the servo hatch ![]() Current throws of flaps and ailerons. These can be increased with a bit of sanding, if needed. ![]() ![]() ![]() Where do I glue the control horns? I’m sure I’ll find a way, but your ideas would be appreciated ![]() ![]() ![]() All very nice. Really. Now the bits I have my doubts about: On the seam, the gell coat seems to be chipped. ![]() Tail servos hatch is not a good fit (never mind, I’ll tape it shut. But Still…) ![]() The hatch over the bellcranck fits fine, but the hole for the full flying elevator is closed. (no problem I’ll drill it out) ![]() The bellcrank itself is full of epoxy/wax residue ![]() There are some tentative openings for the tail servos, but there’s no opening for the pushrods (yet) ![]() But I’ve kept the best for last. This belongs in the “It may be nothing, but…” department Inside the fuse (at least in the part we can see, we don’t know how it is further back) in some areas, there is air trapped under the fiberglass. i.e. There is no firm bond here, and could be problematic in the future ![]() ![]() On the whole, a very nice glider, for that price. And I am looking forward fitting her out, and flying her. Oh yes, and last but not least. The bags that come with the Typhoon; the wings and elevator bags are a great fit. But the fuse bag is clearly meant for the glider version. It is a very tight fit as is, and when a spinner and folding prop are attached, the fuse will not fit in the bag. I patiently opend up the bottom seem and made a long strip of three strips of duct tape. Two face up, and one face down. The face down strip covered half of each face up strip. This I pressed on to the (now opened) underside of the bag, in effect enlarging the bag. Simple... |
Anything can be compared.
