This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Nov 27, 2014, 07:47 PM
Jack Crossfire's Avatar
3DR current sensor notes
The 3DR current sensor outputs 0.3V for 5A, 0.1V for 2A, 0.05V for 1A. It was designed for much higher current. It's nonlinear, under 5A. After tearing it down while thinking it over, the decision was made to try a home made shunt resistor.
Based on the internet, the target current is 0-5A. A simple power supply exercise reveals a small piece of wire drops 0.027V at 5A. It would need 122x gain to reach full range. Bench power supplies are quite useful for measuring extremely low resistances.
Then, it was decided a full power regulated system would need to sense current, voltage, gyro, & a voltage representing target power. Then it would need a fixed point multiply. None of the G-buggy circuit could be reused. It would need a higher end microcontroller with the full MP lab build system, finally using the pickit that arrived years ago. The era of the home made programmer with gpasm was over.
Then it was decided making it through hole wasn't worth it. A tried & true surface mount ARM would support bluetooth for phone configuration, 400Mhz for the hand controller, & have real floating point power calculations.
The ancient dspic33fj128mc802 may never be used. It's not worth building a through hole board & bringing up yet another build environment.
