Jupiter Kwirl free download plan - Page 4 - RC Groups
Dec 05, 2014, 07:28 PM
bcredneck's Avatar
wheres the CG
Dec 05, 2014, 07:51 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Originally Posted by bcredneck
wheres the CG
Thomas shows the CG directly where the mast meets the top of the fuselage (or just in front)
Lockey
Dec 05, 2014, 09:27 PM
bcredneck's Avatar
I ran out of foam. So i used a old fuse and built something based on what i learned from this. Batterys charging right now. Same rotor but much bigger and only 1 . Its running a DT-900 motor and 10x6 prop on 3s
Dec 05, 2014, 09:47 PM
bcredneck's Avatar
it flipped over backwards?
Dec 06, 2014, 11:09 AM
scratchbuilder
Thomas B.'s Avatar
If it has a different fuselage, a bigger rotor - and only one - it`so different to a Kwirl that I probably can`t help you.
Dec 06, 2014, 01:50 PM
scratchbuilder
Thomas B.'s Avatar
One of my fellow Modell Aviator writers, Lutz Näkel, built this wonderful Cabin Kwirl. Look at the details! Maidened today, flies very well.
Dec 06, 2014, 07:27 PM
Lockey's Avatar
Magnificent
Lockey
Dec 07, 2014, 11:02 AM
jclassic1
I am a great lover of Al Foots Twirl.I still have an enlarged version in my shed for calm day flying but this has really sparked my enthusiasm to build this contra rotating version.
I have no 3mm depron at the moment so will probably start my build in the new year but really looking forward to giving this one a go.
Just noticed Lockeys 150% version for 6mm depron so may give that one a go as I like the larger models.
John
Dec 08, 2014, 02:01 PM
scratchbuilder
Thomas B.'s Avatar
Two Kwirls, this time without midair:
Kwirl + Kwirl (1 min 46 sec)
Dec 08, 2014, 02:42 PM
Dragons, WindMills, all Same
jcstalls's Avatar
semi inebriated mosquito flying
I would not translate
Dec 08, 2014, 04:12 PM
Halb besoffene Mosquitos?
Dec 11, 2014, 03:54 AM
Tomas Dunker's Avatar
How long must the skewers become?
The longest I have found here in Sweden is 280 mm, including the taper at one end.
Dec 11, 2014, 09:38 AM
Please can somebody confirm the motor size to use wattage etc
regards Jeff
Dec 11, 2014, 11:32 AM
scratchbuilder
Thomas B.'s Avatar
Jeff, You need an outrunner with around 20g weight and around 1500kV on 2 or 3 cell 450 - 800 mAh lipo.
Wattage should be around 60W.
Tomas, your skewers should work fine. Maybe you have to move the distance pieces for the dihedral a bit to get the right angle because of the the tapered ends.
6° or 2cm at the tips. I guess a bit less should be no problem.
Dec 11, 2014, 01:15 PM
for Lockey
I am going to build the enlarged version 150%,you have not indicated the size of the rotors can you please advise.
regards Jeff
