Nov 23, 2014, 02:21 AM
scratchbuilder
Thomas B.'s Avatar
Dihedral should be around 6 for each blade. That is 2cm at the tips.
Nov 23, 2014, 01:52 PM
Dragons, WindMills, all Same
jcstalls's Avatar
Hi,
Thanks for the pattern PDF's.
I thought the original printed was small.
Same for these PDF yet larger.
Yet, still a tad small and runout.
Only can get 96 of 100mm scale and some runs out past page with A4 in landscape.
Think I will get some legal paper and increase % to about 103.14% n should work.
Or, am I missen somthang ?
Jared
Nov 23, 2014, 04:07 PM
scratchbuilder
Thomas B.'s Avatar
I wrote to the editor. I hope they can solve the problem.
Nov 23, 2014, 04:28 PM
I have designed a rotor head than can be laser cut from plywood (either 1.5mm or 0.8mm - will need to test strength). It will give the correct pitch and dihedral and the blades will be removable. Either ball bearings or a simple bearing tube can be used with the head. Unfortunately my laser is over 1000 miles away from where I am at the moment. I won't be able to cut and test the design until Christmas.
Nov 23, 2014, 05:25 PM
jcstalls's Avatar
Not a problem at all Thomas, just a challenge and asking as I am not the computer dweeb of me yesteryear's.
Jared
Nov 24, 2014, 02:26 AM
scratchbuilder
Thomas B.'s Avatar
I re - checked the sizes on my printer:
Lockey`s patterns are exactly right, the download plan is almost 20% too small. They also got the rotor diametre and length data wrong: right is 52,5cm diametre and 56cm length.
So I recommend using Lockey`s patterns for cutting and the plan for general overview.
Michael, I can`t wait to get some of these rotor heads!
Nov 24, 2014, 03:42 AM
Lets see if they work as intended first Just because they look OK on paper doesn't always mean they work in "real life". Basically you just glue plywood root pieces onto the blades and these then slot into the hub and are retained by a small screw. I'll post up the drawing of the parts when I've done the final touches.
Nov 24, 2014, 01:33 PM
scratchbuilder
Thomas B.'s Avatar
Size correction
The size of the download plan will be corrected tomorrow.
Nov 25, 2014, 01:40 PM
scratchbuilder
Thomas B.'s Avatar
Download plan now correct
Modell-Aviator corrected the size instantly, now you can use it without calculating. Here is the link again:
http://modell-aviator.de/files/downl...plan_kwirl.pdf
Nov 25, 2014, 03:01 PM
jcstalls's Avatar
Excellent and thank you.
I printed out with A4 in landscape and am even closer enough on standard letter paper.
Jared
Nov 28, 2014, 10:08 AM
I call it 'landing'...
Plattenwerk's Avatar
@Thomas B : you're lucky! All trees around here are damned plane magnets. How did
you turn it off for the video ?
I would not dare to fly in such cramped environment : thumbup:
Nov 28, 2014, 01:03 PM
scratchbuilder
Thomas B.'s Avatar
You just have to build a Kwirl. It has an automatic tree-avoiding- system.
The problem is the magnetism of orange and green Kwirls:
Rc Autogyro crash: Kwirl vs. Kwirl (0 min 34 sec)
Nov 29, 2014, 03:47 AM
If I ever built one, I'll take you up on that!
Suggest to choose other colors to avoid green-to-orange-magnetism.
Nov 29, 2014, 07:25 AM
Are they ever really "done"?
Hookdriver's Avatar
Fantastic! I have been quietly following Lockeys' adventures in autogyroing (is that a word?). For a few weeks now. Stumbled on the jupiter...which led me here. I just really wanted to say thank you so much guys for sharing this. Simple, afforable, easy to build. How does it get any better? Great work guys!
Dec 02, 2014, 01:15 AM
scratchbuilder
Thomas B.'s Avatar
Here is Andre`s build:
