This thread is privately moderated by Old_Pilot, who may elect to delete unwanted replies.
Nov 11, 2014, 04:53 PM
Ad eos qui nesciunt crepitus
Old_Pilot's Avatar
Build Log
Nas-Tee
This is for all the guys on RCAAA......you know who you are !
I've decided to try to build a 3D-ish foamie......so I stole the stuff I liked from 4-5 ARF's and came up with this....takes (2) sheets of 3/16" Elmers board and a 2 liter bottle for the canopy.....I'll revise and annotate once I build her, but you guys get the idea......As always, drawings are on 36x48 paper.. foam board blanks are 40x30.
I did a box fuse because I don't like batteries, ESC's, and Receivers flopping around in the wind !
This ain't Dollar Tree foam !
Preliminary electrics:
Motor:
Golden Power 2217/6 1500 kV...
No. of Cells: 2 - 3 Li-Poly
Kv: 1500 RPM/V
Max Efficiency: 80%
Max Efficiency Current: 8 - 22A (>70%)
Load Current: 1.6A @10V
Resistance: 0.100 ohms
Max Current: 28A for 60S
Max Watts: 311W for 60S
Weight: 70g / 2.45 oz.
Size: 27.5 mm x 30 mm
Shaft Diameter: 4mm
Buddy RC
http://www.buddyrc.com/golden-power-...ess-motor.html
Prop : APC E 8060 or 9060 (probably change, but I'm sure either will fly her)
Battery 2100 mah 20C 3S
30A ESC
9 gram servos
Nov 21, 2014, 09:22 AM
Old_Pilot's Avatar
Almost ready to paint
Added "tiplets" based on the advice of some of the aerobatic pilots at the club.
Latest blog entry: Fuselage Jig for Steve Merrill
