Nov 03, 2014, 06:17 AM
My new APM Mini 250 Quad
Well I finally managed to get her built, not flown a modern mini before, a long time ago I home madea 150 quad but good micro motors were scarce then
APM Mini on a Goodluckbuy QAV250 frame
Mini APM 250 Quad Maiden (3 min 29 sec)
APM 250 Quad Maiden
I was very impressed with the speed, even in stabilised mode with only 60% throttle she was nearly out of orienation range before I had a chance to slam the brakes on
First two batteries I set my TX timer for 5 minutes
After having now topped up the batteries I found they only used 560mah in 5 mins, that gives me an easy 9 minutes flight time on the 1500mah even with the headlights on , all up weight with Mobius and well everything is 480 grams
Goodluckbuy QAV250 Frame:
http://www.goodluckbuy.com/qav250-fi...pcb-board.html
ZMR 1804 2400kv CCW Motors:
http://www.goodluckbuy.com/brushless...uadcopter.html
ZMR 1804 2400kv CW Motors:
FVT-SKYII012-M 12A ESC Simonk:
http://www.goodluckbuy.com/fvt-skyii...ticopters.html
APM Mini Flight Controller:
http://www.goodluckbuy.com/miniapm-v...lticopter.html
Gemfan 5030 Props (there's lots of different colours, here's just one)
http://www.goodluckbuy.com/gemfan-50...pter-4pcs.html
600mw Micro Video Transmitter with RHCP Clover Antenna:
http://www.tecnic.co.uk/600mw-5.8GHz...ansmitter.html
Mobius Wide Angle Camera:
Search Google, there's loads of sellers
Ultra Low Light 0.00008 lux FPV Camera:
http://www.tecnic.co.uk/Ultra-Low-Li...ux-800tvl.html
Turnigy 1500mah 25-35c Battery:
https://www.hobbyking.com/hobbyking/s...arehouse_.html
Radio Control:
Transmitter: Rmilec LRS/UHF system (this version is no longer available but others are)
Receiver: Rmilec 4047 Lite
http://www.fpvmodel.com/rmilec-r4047...stem_g549.html
And just to check on another set of scales
Nov 04, 2014, 03:18 AM
Now with gyro adjusted tilt on the FPV camera so I can see where I'm going and not just see the grass
APM Mini 250 Quadcopter with servo gimbal FPV Camera (0 min 25 sec)
Oh and also a night test of the headlights
GLB QAV250 Mini Quad Headlights (0 min 44 sec)
Nov 06, 2014, 12:42 PM
A little practice
Mini Quad practice at TickTock (3 min 15 sec)
Nov 06, 2014, 03:11 PM
Nice work, keep up the good work
Nov 08, 2014, 03:50 AM
More practice and more crashing
Mini Quads at the Iron Works (3 min 25 sec)
Nov 09, 2014, 01:58 AM
can you provide some more info on the gyro camera tilt? Amazing idea btw!!!
Nov 09, 2014, 05:18 AM
I'm sure the idea isn't original, I think others may have already done it, I just haven't seen any myself
It's very simple really, some flight controllers such as the APM and Copter Control have outputs that could be used for the old school camera gimbals which used servos (rather then the current brushless gimbal designs)
These outputs can still be used so all I did was tap into output 11 and set it up on the PC program to be camera tilt, I used a tiny Blue Arrow micro servo hot glued to the frame a 1mm hole in the side of the camera case and a 1mm rod to connect the servo arm to the camera (bent to the right length)
Actually I cut the rod fitted it to the camera and servo then I glued the servo in place so I could get the camera angle correct whilst the srvo was centred (didn't have any proper screw on servo rods to adjust afterwards)
You could of course glue a horn to the back of the camera rather than drill a hole
I do find have the camera stay level a great benefit, I've not flown a mini before but I used to struggle with my 450 quad in full forward as all I could see was the ground
Nov 10, 2014, 09:41 AM
Ah so this is the gimbal you were telling me about when I spoke to you on the phone the other day. Makes more sense now I have seen your videos. Nice idea!!
Jun 14, 2015, 04:20 PM
Hi! Can you post the screenshot of pid values for your setup? I am going to sacrifice more time and get my setup with apm working, but nobody believe it's a good idea.
Do you have problems with alt hold mode? It's the most annoying thing now, as most of the pid values are flyable.
Jun 14, 2015, 07:43 PM
Who is John Powers ?
How did you go with Compass calibration ? I got the same flight controller and I find the compass has very high calibration numbers (above 400)
Discussion My new APM Mini 250 Quad Dogdude FPV Aircraft 6 Nov 12, 2014 02:16 AM
