RG 65 Mass Build? - Page 42 - RC Groups
Apr 18, 2017, 12:30 PM
I think that 5mm thick is a little too much. This is more like the max thickness of an RG65 fin. The max thickness of my RG65 rudder blades are 3.5mm with a 3mm shaft. I've also made some Footy rudder blades and they are about 2.5mm thick with a 2mm shaft.
Apr 18, 2017, 12:50 PM
Brilliant thanks
I'm sure I'll have more questions after I attempt that lol
Sent from my iPhone using Tapatalk Pro
Apr 19, 2017, 12:01 AM
Manta RG65
Round 3 of fairing lol
Apr 19, 2017, 07:11 PM
Dick L.'s Avatar
Thomas,
Looks like a good turnout for the 2017 South Americans.
How did your "nARROW" do against the professionally built boats? There were some photos that looked like good starts, but more interested in how it did boat for boat go as far as speed ? Any major changes that need to be made from original build? Any comments or other observations?
Thanks Dick
Apr 19, 2017, 11:25 PM
Manta RG65
A little more tlc, and the plug will be ready
Apr 19, 2017, 11:37 PM
RCphotoguy's Avatar
Thanks for sharing the process with pics!
Apr 20, 2017, 11:31 AM
Lucas
Hi David,
Did you mention what you are using as a fairing compound? It looks like you've done a few layers now and the surface is looking real good.
Also, I'm curious if you've ever tried the shaping foam method from BG's video? If so what are the pros and cons of making the initial skeleton of the mold from balsa instead of foam?
Apr 20, 2017, 06:33 PM
Thomas Armstrong
Originally Posted by Dick L.
Thomas,
Thanks Dick
Not sure why you question is in this thread and not here: https://www.rcgroups.com/forums/show...can-Champ-2017
I can say that the nArrow sails great. I'm sure a better skipper would have been much higher in the results... Still need better sails myself, and to improve in the thumbs+brain area...
Apr 20, 2017, 07:25 PM
Manta RG65
Originally Posted by lhurt
Hi David,
Hi there, I think Mr. Gibson ' s video is amazing on building a foam plug. One day I would like to try it. Just have been chicken to so. Thank you Brad for sharing your foam method.
I simply use drywall puddy for fairing.
Apr 20, 2017, 11:33 PM
Manta RG65
Still need to apply some epoxie over the hull, but getting closer
Apr 21, 2017, 08:11 PM
Looking really good.
Apr 25, 2017, 12:19 AM
Manta RG65
Off the shadow build board
Apr 28, 2017, 08:42 AM
Manta RG65
Deck fitted to hull, a bit of fairing still to do. Then a bunch of wet sanding
May 01, 2017, 02:26 PM
Orco Skinny
Mark Dicks
Can you PM me in regards to Sith
MMB
May 08, 2017, 08:02 AM
Did the double mould. Not the greatest print but it worked well.
One rather amusing failure with resin melting the foam core and a second attempt with a balsa core until I can get epoxy.
Foam core compressed to get the shape
Melted foam core
Attempt 2 with balsa.
Very little time spent on surface finish.
