AerobTec Competition Recording Altimeter Switch Altis V4
FAI/F5J Multipurpose Altitude Recorder
Record Your Altitude
The Altis V4 can be used on anything, but really caters to F5J competition pilots. It uses a barometric pressure sensor to calculate your altitude above the ground. For F5J it has a built in screen that can display the start height making it easier to run competitions. If you have a Jeti Duplex or Multiplex M-Link radio system, you can connect them to the Altis V4 to get live altitude data on your radio. You can also use the downloadable software to import and review the data from the Altis on a PC.
Features:
  • Telemetry Support: Jeti Duplex, Multiplex M-Link
  • Voltage Range: 4 - 12.6V
  • Size: 33mm x 20mm x 6.5mm
  • Weight: 8g
Learn More about the Altis V4 at Esprit Model
Sold AerobTec Competition Recording Altimeter Switch Altis V4 (FAI F5J) rsbabcock Aircraft - Sailplanes (FS/W) 1 Jun 13, 2014 09:08 PM
