This thread is privately moderated by dragbikebam, who may elect to delete unwanted replies.
Oct 27, 2014, 01:17 AM
dragbikebam's Avatar
Mini-HowTo
HPI G3.0 In Nouva Faor Bike Install "The Whole Story"
The engine will require a little modification to be right for a bike and I will explain in the pictures below.
The G3.0 is a little wider engine than .12's so you may have to adjust your lay shaft position, this is especially true if you have a wide gap between the flywheel and engine bearing. The closer you can get the flywheel to the engine the less shimming or spacing you have to do to the spur and more right side lean angle you get. Try several flywheel collets to get it as close as you can, anywhere close to 1mm or less is good. I highly suggest upgrading to the steel spur with this engine.
