Jul 08, 2019, 09:07 PM
Originally Posted by SilbernerSurfer
Range test!
Radiolink RC6GS transmitter.
R7FG dual antenna telemetry receiver with 600mm antenna extensions.
Eachine TX806 leaf 5.8Ghz 1000mW receiver with Realacc 5.8G 5dBi 50W Pagoda antenna.
V2.0 FXT VIPER goggle with Realac 5dBi 50W pagoda and Eachine StingPad 5.8G 16dBi patch antenna.
Got around 690 meters of range without a single glitch in controls. Possibly more with better FPV equipment!
Attachment 12276621
FPV reception got bad at 690 meters. Later I recognized that the Stingpad patch antenna came loose. Maybe during transport!?
Now it is raining, will try it again when the weather gets better!
Maybe two patch antennas would be better for such a kind of range test! Any suggestions for better FPV antennas?
Used cars was a 10428-A
https://www.youtube.com/watch?v=54-y...ature=youtu.be
Wow, amazing! looking forward to more video for that!
Jul 08, 2019, 09:11 PM
Originally Posted by Beaver_XT
Thanks.
You also can contact the customer support via e-mail: [email protected] or [email protected]
Aug 06, 2019, 04:50 AM
Stunt man
Dr T's Avatar
Originally Posted by Tommygunn
I would also mention that during the problems of getting it to bind I found that the official R6FG method(2presses within 2 secs) did not work and so I thought I'd try the R4EH-G method(hold button untill rapid flashing). I was going back and forth between the two bind methods and only had success with the R4EH-G method, however, I found when I removed power and then powered it back up it had lost its bind.
Funny thing is that I've been out, with the intent of posting about this problem, only to get back, power it up and the LED is solid and bound. Weird.
I'm 99% certain I powered it down after using the R4EH-G method.
Jym73, what method did you use to bind the Rx?
Tom.
Hi guys, I have the same issue as described here: my R6FG Rx will bind with my RC4G Tx, but loses its bind after power down. Does anyone know if this can be solved?
@Tommygunn: has your R6FG Rx been holding its bind consistently after the initial issue?
Thanks!
Aug 06, 2019, 06:35 AM
My name is Tom
Tommygunn's Avatar
Not a problem since, rock solid!
Tom.
Aug 13, 2019, 05:44 AM
SilbernerSurfer's Avatar
New Radiolink receivers and a adapter cable to connect the driving battery to telemetry receiver for voltage!
Adapter cable:
https://www.aliexpress.com/item/4000...51494c4dBAV6DO
R4FGM for micro cars
http://www.radiolink.com.cn/doce/pro...etail-156.html
R7FG, 600m advertised. I got 700m, couldnt go further because I have lost FPV signal. I have posted the vid in this thread.
http://www.radiolink.com.cn/doce/pro...etail-149.html
R8F, advertised 1900m on the ground! I dont have one, couldnt test it! And my FPV equipment wouldnt go so far!
http://www.radiolink.com.cn/doce/pro...etail-157.html
Aug 20, 2019, 05:22 AM
Wow, they have new products
Aug 20, 2019, 01:31 PM
Yes! I like the adapter cable. Its not only useful for the Radiolink telemetry.
Its nice to have if you need a power source from the driving battery. No soldering, just plug it in and you can connect for example the FPV gear.
Aug 20, 2019, 09:46 PM
okay, I see
