Dec 13, 2014, 07:55 AM
Always Excel >>>
BenHayat's Avatar
UnBoxing Video:
YUNEEC Q500 Typhoon UNBOXING (7 min 33 sec)
Dec 13, 2014, 08:04 AM
Always Excel >>>
BenHayat's Avatar
I've added many more videos to the first post. Check them out.
Dec 13, 2014, 08:29 AM
Hawk Fanatic
SkylineFlyer's Avatar
Ok, I want to test.
Dec 13, 2014, 08:17 PM
I hope to hear some chatter as this thing is starting to hit the shelves.
How do you compare to say the tali or phantom?
Dec 13, 2014, 10:08 PM
Crazycanuck_r's Avatar
Here's the specs off the site for the Q500.
Height: 210mm (8.3 in)
Diameter Without Rotor Blades: 565mm (22.2 in)
Propeller/Main Rotor Diameter: 330mm (13.0 in)
Weight Without Battery and Payload: 1130g (40.0 oz)
Takeoff Weight With Battery and CGO2-GB: 1700g (60.0 oz)
Battery: 6300mAh 3S 11.1V LiPo (included)
Charger: 3S 11.1V LiPo DC balancing and AC adapter (included)
Transmitter: 10-channel 2.4GHz with 5.8GHz video downlink (included)
Compared to the Phantom Vision 2 +
Supported Battery DJI 5200mAh LiPo Battery
Weight (Battery & Propellers included) 1242g
Hover Accuracy (Ready to Fly) Vertical: 0.8m; Horizontal: 2.5m
Max Yaw Angular Velocity 200/s
Max Tiltable Angle 35
Max Ascent / Descent Speed Ascent: 6m/s; Descent: 2m/s
Max Flight Speed 15m/s (Not Recommended)
Diagonal motor-motor distance 350mm
Dec 13, 2014, 11:56 PM
Hawk Fanatic
Did anyone get approval yet to demo?
Dec 14, 2014, 01:54 AM
Dec 14, 2014, 03:38 AM
Aerial Vision Systems
OzBlueDragon's Avatar
I'd say they will be going through them this week as they probably got a lot of applications.
Dec 14, 2014, 03:39 AM
Great video Ben, thanks for sharing.
This Quad will shake up the UAV market in a big way!
I'm looking forward to testing one for Yuneec if possible.
Originally Posted by BenHayat
Dec 14, 2014, 10:21 AM
I've seen the specs Crazy
Sky,
I saw a demo yesterday and it looked solid. Didn't like the fpv below the controls, kind of awkward. Did like the "on the fly rate change" on the controller, could have used a ratcheted slide for that though. Quiet for sure, not sure about nimbleness, would have liked to see it go through the paces.
A worry I was told this will not be compatible with goggles?? True or False??
Sweet little setup IMO first impressions.
Looking for more opinions.
dude
Dec 14, 2014, 11:32 AM
Always Excel >>>
BenHayat's Avatar
Sky,
dude
Thanks Dude
I had heard this quad and the bigger brother Hexa are the third design generation Yneec had down before coming to market. So, looks like they did lots of R&D and studied other products.
Personally I think this is a great size falling between the 350 and 800 for a quad. It's stable while still only running 4 motors to last up to 25 minutes for a 556 size.
Another thing I like due to it's design, it has little Prop Wash, which helps with being more predictable.
Dec 14, 2014, 01:07 PM
Thanks Dude
Wow that is interesting they had three predecessors to the Q500, no doubt the design team is ready for this one to release then.
I have no doubt the test pilot program will be a much better way of releasing the Q500 instead of taking peoples money and then changing shipping dates. Thankfully I avoided this and still could make a purchase that actually does release when they say it will.
Hopefully I will get to test fly the Q500 and the testimonials if released at the same time as release I think it could make this a very successful launch.
Also with the front to back design it looks like the camera might not pick up the propellers during a forward lean. I think it's a much simpler solution than the complicated landing gear other companies are going with.
Dec 14, 2014, 01:40 PM
Hawk Fanatic
It would be pretty cool if we all get to test it. Money in hand waiting eagerly!
Dec 14, 2014, 03:59 PM
Agreed
Dec 14, 2014, 04:33 PM
Test Pilots
Agreed
Yuneec, it sounds like you have an audience building here, myself included. I have joined the Yuneec APV page on Facebook as well, to keep people updated this will be the best place to go.
https://www.facebook.com/YuneecAPV
