This thread is privately moderated by ServoCity, who may elect to delete unwanted replies.
Oct 23, 2014, 03:36 PM
ServoCity's Avatar
Cool
Drag Racer out of Actobotics
This past week a few of our R&D crew had fun building a drag racer out of Actobotics. It's a pretty simple design and would be a fun project to duplicate and then customize.
Watch the video to see the dragster in action "off the line" and check out some more close-up pictures below. We'd love to hear what you think in the comments!
Dragracer (0 min 11 sec)
Here is a parts list for those of you interested in building something similar. We'd love to see any improvements or customization to our design!
1 - 4TMD: Foam Wheels http://www.servocity.com/html/4_00__foam_wheels.html
1 – 638286: 1,621 RPM Planetary Gearmotor (http://www.servocity.com/html/1621_r..._planetar.html)
3 – 585436: 45 Channel Brackets (http://www.servocity.com/html/45o_si...nel_brack.html)
1 – 585426: 45 Dual Angle Bracket (http://www.servocity.com/html/45o_du...l_bracket.html)
1 – 585412: 4.62" Aluminum Beam (http://www.servocity.com/html/aluminum_beams.html)
2 – 585580: Flat Triple Channel Bracket (http://www.servocity.com/html/flat_t...racket__5.html)
1 – 585454: 12" Aluminum Channel (http://www.servocity.com/html/12__al...__585454_.html)
1 – 615406: 6mm bore, 24T bevel gear (http://www.servocity.com/html/32_pit...vel_gears.html)
1 – 615398: 1/4" bore, 24T bevel gear (http://www.servocity.com/html/32_pit...vel_gears.html)
2 – 634074: 2.5" Long 1/4" D-shafts (http://www.servocity.com/html/1_4__p...-shafting.html)
1 – 555180: Planetary Gearmotor Mount C (http://www.servocity.com/html/planet...ount_c__5.html)
2 – 585470: 90 Dual Side Mounts ( http://www.servocity.com/html/90o_du...__585470_.html)
4 – 545548: 1/4" bore Set Screw hubs (http://www.servocity.com/html/0_770_...crew_hubs.html)
1 – 575144: Standard Servo Plate C (http://www.servocity.com/html/standa...c__575144.html)
2 – 545456: 0.770 to 0.625 Hub Adaptor (http://www.servocity.com/html/0_770_...b_adaptor.html)
2 – 545448: Aluminum End Cap B (http://www.servocity.com/html/alumin...__545448_.html)
1 – 585468: Flat Single Channel Bracket (http://www.servocity.com/html/flat_s...racket__5.html)
1 - 33485S: HS-485HB Servo (http://www.servocity.com/html/hs-485hb_servo.html)
1 -525124: Lightweight Hub Horn (http://www.servocity.com/html/lightweight_hub_horn.html)
1 – 585474: Single Screw Plates (http://www.servocity.com/html/single...__585474_.html)
1 – 59571: pair of 2" Precision Disk Wheels (http://www.servocity.com/html/precis...sk_wheels.html)
1 - 534-3485: 6-32 Aluminum Standoffs (http://www.servocity.com/html/6-32_a...fs__round.html)
1 – 633104: 1/4" Plastic Spacers (http://www.servocity.com/html/shafti...g_spacers.html)
1 – 633110: 1/2" Plastic Spacers (http://www.servocity.com/html/shafti...g_spacers.html)
2 – 632106: 6-32 x 1/4" Socket Head Screws (http://www.servocity.com/html/6-32_s...ine_screw.html)
1 – 632118: 6-32 x 5/8" Socket Head Screws (http://www.servocity.com/html/6-32_s...ine_screw.html)
Total build cost is just over $200.
