Oct 18, 2014, 08:36 AM
Build Log
Completed: Peter Rake's Martin Kitten
Removed Scale Build off #4 - as I did not make the time frame - I put too much time into work, school, family and other projects -
- A Promise I made to Peter a while ago, and now she will be completed - Very interesting history on the airplane - sort of a flop - but a few innovative possibilities were incorporated in it.
Oct 18, 2014, 09:41 AM
nytjadens's Avatar
DUH! Took me a minute (or 30) but I get it :-)
Looking forward to this!
Stephen
Oct 18, 2014, 10:06 AM
Still the "Pro"-crastinator...
Steve85's Avatar
Just a little too wild and crazy...welcome aboard, Jon!
Steve
Oct 18, 2014, 10:59 AM
You are two wild and crazy guys... .I thought you guys may see the humor in it - -
Oct 18, 2014, 01:30 PM
Senile Member
Lnagel's Avatar
Too bad there wasn't a rake somewhere in the photo.
Larry
Oct 19, 2014, 09:41 AM
JIMA's Avatar
Boy you guys are starting to show off your age. LOL. The younger guys probably have no idea what you guys are talking about.
Jim
Oct 19, 2014, 10:40 AM
Let's help them a little - Peter probably feels this way when many builders make the same airplane, which one will end up completed? it like...... - This is an educational site:
Cat Juggling (0 min 54 sec)
Oct 20, 2014, 06:41 PM
Always assuming, of course, that the curse of the Kitten doesn't strike again.
I have to admit, I'll be interested to see how this one turns out. Even on a bad day the model has to fly better than the original. I won't steal Jon's thunder by relating the history but it certainly wasn't an overwhelming success.
Pete
Apr 04, 2015, 10:05 AM
It's Kitten time - I have cleared the bench and I have started - As always, I read over the plans and mentally "build" the plane before glueing so I know where to start, and what piece goes where - before I have to cut things apart because I put them together wrong. The only thing that stumped me on this plane was the wheels - The are called "Ackerman Innerspring wheels" and they are supposed to be self shock absorbing. It would not look right to put a regular set of wheels on this plane (and yes, the retracts will work - another cool feature).
So what to do? - I created a jig (Copying the very successful one from Kay at Aerodromerc) for how she does her wire wheel kits. (BTW, you ever need a stellar wire wheel look on your plane - get one of Aerodromerc kits - they are perfect ) - So my plan was simple... Bend some spring steel, build a jig, and solder the steel to a center post - WRONG.... What a mess, I could not align anything, and when done, I had a wobbly egg with no lateral stability at all.
So I went to where I knew I could go - My CNC machine - Designed and measured a scale model of the spokes, then I set up a hardwood design and cut out the entire inner wheel with a PVC rim that I cut on my lathe from a 3" drain pipe.
I sanded and cleaned up the "spokes" and added a brass bolt to each one for a little bling. I think it represents the Ackerman wheel just fine, and with a final CA soaking, the wood and PVC will be just fine. Add some rubber tire material - and we are off to the races - One hurdle done... Now, where did I leave my kitten scratch post? .....
Apr 05, 2015, 08:32 AM
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
You've got me sub'd on the wheels alone!
Interesting subject for sure, you had me looking again when you mentioned retracts.
Latest blog entry: RC Throw Gauge
Apr 05, 2015, 09:32 AM
nytjadens's Avatar
Beautiful :-)
Apr 05, 2015, 09:56 AM
Thanks Guys - I'm going to do a little remodeling (When do I ever leave things alone?) as the entire sides are light plywood, and I am going to cut from the cockpit back in 1/8 balsa - the Rudder, a large and multi-tasked item (it also serves as a shock absorbed tail skid) is also big pieces of solid wood, have to lighten them up as well. Once the fuselage "Box" is done - I'll figure out the retracts - A fun image how the real one was designed and patented. Have to make it "Jon" proof for landings in taller grass.
May 02, 2015, 08:00 AM
No - the Kitten curse did not bite me - Travel has been on the schedule, and has put a delay in the project - and also my biggest engineering challenge was how to make a scale retractable landing gear?
May 02, 2015, 08:06 AM
Well I drew up on the plan where the gear should go, and it will mean changing the rear wire supporting the wing, and adapting the fuselage for the gear. - No problem, Just took me a week to figure it out, make it scale and operable, and make it survive my landings - -
May 02, 2015, 08:09 AM
First thing was to bend the gear and add the "bearings" I used 1/8 wheel collars on them, and if you have the set screw outside the wheel collar it keeps it from spinning in the hardwood. Then I tool 1/8 music wire and threaded it to the same threads as the 1/8 collar set screws and attached tow collars and silver soldered them to the wire, the other end of the wire has a 90 degree bend in it (tell you more later why)
