This thread is privately moderated by Pushjerk, who may elect to delete unwanted replies.
Oct 09, 2014, 01:13 PM
Build Log
TBS GS/RJ45 to IRC vTX harness using Cat6
gathered. Tools at the ready. This is to become the harness.
- Soldering station and associated materials
- Wire strippers/clippes
- Heat shrink
- Butane torch
- 12" or so of Cat6 nework cable with RJ45 connector
- IRC vTX connectors - 2-Pin (+12V and Grnd) and 5-pin (Video, Grnd, Audio) molex
- Stereo wire loom
Description:
I've cut the Cat6 to length, and removed about 3/4" of the PVC sheath off the end to expose the wire grounding shield and individually shielded (aluminum) pairs.
For more info about Cat6 and why it rocks, look here:
http://fpvlab.com/forums/showthread....For-FPV-(CAT-6)
Description:
Foil pulled back to expose the 26AWG wire pairs.
Description:
Cut the IRC vTX connectors to length.
Description:
Removed "Audio 2" and "5V out" as they will not be used.
Description:
Time to do some continuity testing to ensure I know which of the eight wires is which, and that they will correspond correctly to the Pin-out of the TBS GS (pg 10 of the TBS GS manual here - http://www.team-blacksheep.com/tbs-g...ion-manual.pdf)
Description:
Insulation on wire ends removed, wires tinned, ready for soldering.
Description:
Soldering completed, heat shrink applied, loom in place. All that is left is to make it pretty.
Description:
The wires are sort of a mess underneath the heat shrink, a little lumpy, but not too bad. Here is the vTX end.
Description:
the GS/RJ45 end.
Description:
We're left with a nice, neat little solution to quickly and securely install our repeater to our TBS GS.
Description:
Oct 09, 2014, 09:30 PM
On the Threshold of Control...
Very professional Richard!
I and everyone else thank you for making this build log
Feb 14, 2015, 04:48 AM
keeping it legal
How about a pic of what your plugging this in to? Curious to see how you wired in the ground station.
