Blackhorse Fieseler Storch - RC Groups
Oct 06, 2014, 03:45 PM
Hi All,
Has anyone out there converted the big 112inch storch to electric.
Will be picking up a kit in a few weeks and want to get components ready first.
Was thinking of using my power 110 on 9s on the 18lb kit which should give around 100-110w/lb.
Flight characteristics are like a high wing trainer so i'd reckon 100w/lb would be ok.
Any thoughts out there.
Cheers
Andy
Oct 27, 2014, 04:59 PM
Have done a few static tests with my 110. 9 cells with a zoar 20x8 gave 52amps @1980watts. On 10s gave 67amps and 2250watts. With the max amps @65 i'd have to be carefull or prop down.
Aiming for approx 80w/lb the fully laden kit will be around 18lb this will require around 1440watts. Si I could either go 9s if extra weight is needed or possible 6/7cells and save a little weight.
Any thoughts out there on the above ?
Oct 28, 2014, 09:02 AM
I meant to do that - no really
ImpactSpecialist's Avatar
Hi Andy,
I am certainly no expert but have you considered using eCalc as a guide to give you a starting point?
Whilst there it no substitute for real-world meter readings, using eCalc to play with the variables (prop size / pitch / battery cell count) might guide you somewhere close to where you want to be initially.
I have found that using it in this way got me close to what I wanted and time spent looking at alternatives in the software saved me investing in over-spec'd kit (particularly ESC) that, just to play safe, I might otherwise have spent hard earned cash on. Personally, for my chosen setup on a Cub conversion the predicted watts/amp readings were also fairly close to the actuals.
Hope this helps.
Peter
Oct 28, 2014, 12:31 PM
Hi Peter,
Thanks for the info.
I've run the numbers as suggested and best set up will be 8 or 9s with a 100amp esc on a 20x8.
Andy
Oct 30, 2014, 09:27 AM
Converted mine with HK 1.60 brushless motor, 100 amp HV ESC, and 10s 5000 mah pack. Had to build a plywood motor box, removing the firewall and extending the sides to the correct length. The batteries loaded through the canopy hatch. I got rid of all the lead I put in the nose for the gas (DLE 30) version.
Oct 31, 2014, 08:11 AM
Hi ,
I'm curious on your set up , did you use full throttle at any point. I've considered 10s on my e-flite 110 which will stand the power but keeping an eye on the amps, but unsure if the models requires this power to fly scale.
I've used a motor box from a seagull kit bolted to the firewall and still had to use 30mm extensions to get to the correct length but my lipos stop at the firewall. Do you envisage more weight needed up front ?
Andy
Nov 01, 2014, 05:59 PM
Hi,
I've decided the e-flite 110 may not give me enough in reserve, so have purchased a Turnigy G160 245KV. Reviews are good and reliable.
Nov 06, 2014, 07:13 AM
Have run up the turnigy on 10cells and must say I'm impressed. 64amps @2350w and i'd not gone to the stop on the throttle.
This should really give the FS some grunt..........if needed.
Nov 09, 2014, 08:37 AM
No need for full throttle, but the weight if the packs and larger motor was very appreciated. I did the first flight or two with a DLE 30cc, two heavy batts strapped to the sides of the engine mount, and still one pound plus in lead screwed to the firewall!
Nov 11, 2014, 07:19 AM
With the G160 and the 10s it looks like its not far off balancing but that brings me to another headache.
Does the cg measurement come from the slat or from the leading edge of the wing. The instructions look like its from the slat.
Nov 25, 2017, 02:42 AM
Terminater's Avatar
Just got one of these planes is the CG from the LE of the slat or leading edge of the wing?
Anyway here's the Pictures
Dec 13, 2017, 09:52 AM
iumop ap!sdn w,I
G.P.'s Avatar
Has anybody had any luck with the customer service at Black Horse? I've sent several emails and used the contact form on the website without getting any replies.
I'm in need of a RH elevator, or just the top and bottom covering. Mine was damaged during shipping. Any crashed Storches out there that could help?
Thanks!
Latest blog entry: R.I.P. (rest in pieces)
Dec 13, 2017, 02:17 PM
Terminater's Avatar
BH doesn't reply to any email unless its from the Shop / Distributors I have found.
Also when your ready to balance is Use 115mm from the leading edge of the Slat it flies very well with that...
Dec 13, 2017, 04:28 PM
iumop ap!sdn w,I
G.P.'s Avatar
Thank you! I've been reading whatever threads I can find on it and there seems to be a lot of confusion about the CG.
Sold Durafly Fieseler Storch stephmet Aircraft - Electric - Airplanes (FS/W) 3 Nov 17, 2016 04:07 PM
Sold Maxford Fieseler Storch ARF NIB with servos/motor/esc/prop/detail upgrades klautzsch Aircraft - Electric - Airplanes (FS/W) 2 Oct 11, 2016 09:29 PM
Discussion Fieseler Storch build FieslerStorch Scale Kit/Scratch Built 30 Oct 07, 2016 06:21 PM
Sold *REDUCED $20* Fieseler 156 STORCH w/2 Micro Servos...Dumas Kit...BEAUTIFUL BUILD! bighank13 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 28, 2016 06:26 PM
Sold Fieseler STORCH, Albatros D.Va, Diamond Demon & Twin Cyclone...CHECK THEW OUT! bighank13 Aircraft - Electric - Airplanes (FS/W) 0 Sep 25, 2016 11:53 AM
