New Product
E-flite UMX B17
Looks like we finally have a 4 engine bomber in the UMX range!
[/URL] |
Working on it.
Horizon hobby posted it on Instagram |
http://www.e-fliterc.com/Products/De...#quickFeatures UMX B-17G Flying Fortress BNF Key Features Completely built and flight ready AS3X® technology provides superior flight performance Ultra-lightweight construction with an authentic "Man O War II" trim scheme Four-motor, counter-rotating operation with 3-blade propellers Four-channel control includes throttle, aileron, elevator and rudder Industry leading 2.4GHz Spektrum™ DSMX® technology Performance ultra micro linear long-throw servos Removable landing gear and simulated retracted wheels Ultra micro 250mAh 1S 3.7V 20C Li-Po battery (included) E-flite® 1S DC Li-Po charger (included) Overview Conceived in the mid-1930s by Boeing Aircraft Company, the B-17 aircraft not only demonstrated capabilities beyond expectations over Europe, around the globe it went on to deliver military service well into the 1960s. She was dubbed the "Flying Fortress" for her incredible defensive firepower and is credited with downing 23 enemy aircraft per 1,000 raids that devastated European targets in daylight raids with 640,036 tons of bombs. Now known as the most famous bomber of WWII, heroic crew members loved the B-17 for her ability to withstand extensive combat damage and still return home safely. The E-flite® UMX™ B-17G Flying Fortress model is an ultra micro marvel. Not only is it the first ultra micro RC model of the famous WWII bomber, it includes innovative AS3X® technology that makes flying more fun. Built into the Spektrum™ DSMX® receiver, AS3X technology has been specially tuned to combat the effects of wind and turbulence so you get the kind of locked-in handling that’s comparable to an expertly tuned airplane that’s much larger. With four motors, three-blade propellers and full four-channel control plus an abundant amount of scale detail, it’s a replica you can fly almost anywhere. Whether you’re an intermediate park pilot looking for your first RC multi-engine experience or a scale pilot looking for a unique replica that can be flown anywhere, the E-flite UMX B-17G Flying Fortress is ideal. All you need to start flying today is your favorite 4+ channel aircraft transmitter with Spektrum 2.4GHz DSM2®/DSMX technology. Ultra-Smooth Flight The advanced AS3X® (Artificial Stabilization - 3-axis) system built into the Spektrum™ 6-channel ultra micro receiver is what helps give the E-flite® UMX™ B-17G Flying Fortress an incredibly solid look and feel in the air. This technology works behind the scenes to help counter the effects of wind and turbulence by combining 3-axis sensing with flight control software tuned exclusively by Horizon Hobby product experts. As a result, your workload is significantly reduced while control feel is natural and precise so you can focus on making victory passes laser-straight. It’s an impressive scale flight experience that will have you convinced that you’re at the controls of an expertly-tuned multi-engine airplane that’s much larger. Authentic Trim Scheme Attention to detail and respect for the scale outline of the original B-17G Flying Fortress makes this fully-assembled 1/48-scale ultra micro airplane a thrill to fly. Its three-blade propellers complement its authentic "Man O War II" trim scheme. Removable Landing Gear The plug-in main landing gear can be replaced with simulated retracted wheels and the tail wheel can be removed for an authentic gear-up flight appearance. Counter-Rotating Motors Counter-rotating motors improve flight performance by virtually eliminating the adverse effects of torque. Full Four-Channel Control Four-channel control includes throttle, aileron, elevator and rudder with performance ultra micro linear long-throw servos. Battery Hatch The magnetically attached nose section of the B-17G conceals the battery compartment where the included 250mAh 1S 3.7V 20C Li-Po battery is installed. Product Specifications Wingspan: 26.0 in (660mm) Overall Length: 18.3 in (465mm) Wing Area: 87.5 sq in (5.65 sq dm) Flying Weight: 2.75 oz (78 g) Motor Size: 6mm in runner (Left and RIght Rotation) Radio: 4+ channel DSM2/DSMX transmitter required CG (center of gravity): 38mm back from leading edge at wing root Prop Size: 72x65 3 Blade Speed Control : Brushed ESC (included) Recommended Battery: 3.7V 1S 250mAh 20C LiPo Battery Scale: 1/48th Scale Experience Level: Intermediate Is Assembly Required: No Needed to Complete Recommended Transmitters A 4+ channel DSM2- or DSMX-compatible transmitter. cheers chuck |
want
there looks like they are just plastic skids for that wheels up view
O.T., but did anyone see THESE!
A new Habu that doesn't look like a banana! And it has SAFE. http://www.horizonhobby.com/product/...f-bnf-eflu4380 And, almost a BEAST!!!!!!!! http://www.horizonhobby.com/product/...80-bnf-efl6650 |
Hurray!
No under-cambered wings! Logical, one brushed controller can control all 4 motors. Maybe saves weight compared to having 4 brushless controllers? |
Uses two brushed ESCs, one for each side. Removable wire LG, or if you want to belly land there are plastic skids that snap into the same slot that look like wheels in the retracted position. |
You had to go and bust his bubble. |
I thought all UMX where brushless
Thread Tools | |
Similar Threads | |||||
Gallery | E-Flite B17 UMX flying fortress | robertmax | Electric Warbirds | 2 | Nov 02, 2018 09:27 PM |
Video | E-Flite B17 UMX flying fortress | robertmax | Micro Ready-to-Fly | 0 | Feb 28, 2017 12:08 PM |
