Sep 30, 2014, 08:21 PM
Plane Fanatic
DeathWarmedUp's Avatar
Originally Posted by MattyB
old faithful D6FR in there (Why did they stop making those? My absolute favourite FrSky RX)
Matty,
FrSky did discontinue them but Aloft and others talked them into re-introducing them. HK have them in stock at the moment - Aloft Hobbies probably do to.
https://www.hobbyking.com/hobbyking/...hannel_RX.html
(My fav RX too)
Sep 30, 2014, 08:26 PM
FlyWW1's Avatar
Originally Posted by fluffybunny
thats the pic I was refering too, glad I'm not the only one that realized how tight of a fit it was in there.
It looks like you'll be able to slide a top pin RX toward the battery and be fine.
These sure to look sweet when they roll. Can't wait for point rolls!
Sep 30, 2014, 08:31 PM
CelloGuy's Avatar
Was gonna wait until I wrote off my Moray before getting an EFX but only managed to hold out for a couple of hours after release - delaying gratification fail! Was gonna get yellow but ended up ordering red (gf said so). Added a 3S 2200 and 4S 1800 to the order but went with the Zippy Flightmax 40C rather than G2 - less than half the price and good reviews. No buddy code that I can see. Either it hasn't been added yet or they've just hit a limit. Will try it at the field first but it's just coming into slope season here and that's gotta be worth a try. Can't wait.
Sep 30, 2014, 08:34 PM
ɹǝʎןℲ ǝıssn∀
taz101's Avatar
I was thinking the same thing!!
If you slide the Rx to where I have put the green line, you would then have room to put the pins in from either side where I have the red arrows.
LURCH
Latest blog entry: Compulsory Reading!!
Sep 30, 2014, 08:37 PM
Plane Fanatic
In one of the videos, I'm pretty sure Stuart was using a Taranis and I could see one antenna sticking out the fuse side. So, I think he has managed to get a twin antenna FrSky RX in it. I am pretty sure the D6FR can squeeze in - I may remove the case and heatshrink it if its too tight.
Sep 30, 2014, 08:41 PM
LURCH
great pictures, but I wonder if it will work with the battery in there, if it does I think its going to be a REALLY tight fit.
This picture is from this review by Jason Cole
Sep 30, 2014, 08:51 PM
FlyWW1's Avatar
Maybe we can slice out the white tabs that hold the RX in place. They don't appear to be structural. That would open it up quite a bit. Either way it's going to be tight!
Sep 30, 2014, 08:55 PM
Originally Posted by Sammy70
Now if we could get H/King to ship out as quickly as MotionRC we'd all be flying by the weekend
Ya right! I love motion rc. I have you beat though. Have you ordered from heads up hobby? They ship before you clear paypal receipt
Sep 30, 2014, 09:08 PM
Plane Fanatic
Does look like they can be trimmed a bit - appear to also support the Servos so would not want to trim too much off.
Sep 30, 2014, 09:17 PM
Ahh a little hot glue on servos might be worth the extra real-estate.
Maybe a flush mounted rx in the fuse.. Hmm idea's. I hope to see mine Saturday...
Sep 30, 2014, 09:19 PM
I have the plane in hand right now and it is definitely a tight fit for the receiver.
xxD-Manxx, thanks for the invite. I've been to the Rams field and it isn't bad but I'm a member at the MRRCS and am there most weekends. Consider yourself invited.
Sep 30, 2014, 09:25 PM
Your pretty lucky to live driving distance from HK. I've just made my first order from the AK warehouse let's see what's fastest..
Sep 30, 2014, 09:37 PM
I didnt know hobby king had a warehouse in Alaska Common mistake, AR is the abbreviation for Arkansas, happens all the time.
Sep 30, 2014, 09:42 PM
Thats cool you have the plane in hand, any way you could put both a end pin receiver and a side pin receiver in the plane and maybe snap a few pics to see whats possible? I'm planning on doing that as soon as I get my plane later this week if someone else hasn't done it.
Sep 30, 2014, 09:57 PM
Stuart Warne's Avatar
Ok, hello:
1) Yes end pin type Rx's are the best fit, that why we mentioned/suggest the R620 or Tarannis D6FR (though admittedly this is only on the international listing under the 'accessories' tab, this will be on all listings by Friday) With the Dual aerial Rx's, I route 1 down the fuselage and cut a little slit and have one coming out from under the hatch.
2) The foam tabs holding the Rx are there only to hold the Rx so they can be removed to fit other Rx's if desired.
3) Yes, its no secret metal geared only in the wing as this are in a higher impact risk area that those servo wrapped up nicely in the fuselage. Over a year of testing and development the tail servo's did not fail. They are up to the job otherwise they'd not be in there.
4) There have been no reported issues with interference between the Rx and the ESC on FRSKY, DSM2 and DSMX type systems.
5) We have higher initial stock levels with this launch so they shouldn't go on back order just yet.
S.
