This thread is privately moderated by Old_Pilot, who may elect to delete unwanted replies.
Sep 24, 2014, 07:41 AM
Ad eos qui nesciunt crepitus
Old_Pilot's Avatar
Build Log
Jetstream 2.0 plans (mid-engine)
I've had a couple of requests to publish the plans for this bird......
My notes:
1. Round over the leading edge of the wing.
2. Tab and slot the fins
3. Waterproof (I used (2) coats of clear polycrylic). Water based urethane will work too
4. Add a little up and left to the motor (I used one washer)
5. Maximize the elevon servo throws and add expo for flight
6. Keep your hand out of the prop
7. Canopy pattern is close...trim as required
8. 6mm Depron or 1/4" blue foam would yield a lighter assembly (I didn't have any)...I used 3/16 PFF..Paper Faced Foam board
9. I used tape hinges
10. Jetstream 1.0 balanced about 3/4 " forward of the intersection of the trailing edges of the Klein-Fogleman airfoil. I used a 50% top. Jetstream 2.0 should balance about 1" forward of the same intersection.....the front of the fin terminates along that line.
Canopy hold downs are builders choice.....I glued mine down and cut hatches for internal access
AUW as shown is 27 oz. Wing loading is 7.66 oz/SF
Electrics:
Turnigy 2836/8 1100 kV motor
30A ESC with BEC
HiTec HS 82 MG servos
3s 2100 20C battery
One more thing.. cut in air intakes at the front of the canopy, or add a scoop
Another one more thing......DON'T USE POLYCRYLIC.......BRUSH MARKS !
Sep 24, 2014, 10:27 AM
Waste Nothing
RickC_RCAV8R's Avatar
Thanx for posting the plans with the assembly info and power set-up ! Count on another one of these models to be flying in Southwest Canada bby next spring .
Kudos
Sep 24, 2014, 10:49 AM
Old_Pilot's Avatar
Plans and other stuff
Always happy to oblige.....
25% balance point is another inch back from the nose...17 3/4"
Latest blog entry: S-3 finished
