Sep 18, 2014, 03:37 AM
ChuckTseeker's Avatar
New Product
Habu 32x DF ARF by E-flite
this looks very nice
http://s7d5.scene7.com/is/image/hori...5_a1?$pdpLand$
http://s7d5.scene7.com/is/image/hori...5_a2?$pdpLand$
Key Features
New streamlined swept-back planform design
Vibrant trim scheme in high-gloss paint and genuine Hangar 9® UltraCote® covering
Molded fiberglass fuselage and vertical stabilizer
Full balsa-sheeting wing and horizontal stabilizers
Two-piece, plug-in wings and stabilizers with carbon blade spar support
Pre-hinged elevators, ailerons and functional flaps
Hyper-efficient inlet and exhaust duct design
Ready for the E-flite® Delta-V® 32 EDF power system (sold separately)
E-flite 15-25 size electric retract ready (required-sold separately)
Optimized for use with modern Spektrum™ micro servo technology
Includes main wheel landing gear doors that improve streamlining
Quick-release battery hatch features a tinted canopy and cockpit detail
Complete precision hardware package includes machined aluminum wheels
Needed To Complete
6+channel full-range transmitter and receiver
80mm EDF system with rotor
32-class brushless EDF motor
80-amp, 22.2V brushless ESC
6S 5000mAh 22.2V high-power Li-Po battery
(8) metal-gear micro servos
Tricycle 15-25 size retractable landing gear
High-power AC/DC Li-Po balance charger
Overview
The E-flite® Habu 32x DF airplane takes electric ducted fan (EDF) performance and engineering to new heights. Designed around the E-flite Delta-V® 32 80mm fan unit and high-speed DF32 brushless motor, its hyper-efficient intake and exhaust ducting deliver a potent power system that produces a large amount of thrust available as quickly as you can move the throttle stick. The new swept wing and horizontal stabilizers enhance the appearance as well as both speed and maneuverability. The result is a sport EDF that will give even experienced jet jockeys goose bumps. Even more satisfying is the short amount of time you’ll need to get this hot-rod flight-ready.
The Sport-Jet Sensation
Since 2008, when the ParkZone® Habu was first introduced, jet jocks and speed fans worldwide have flocked to the Habu line of EDF jets for the sporty looks and great performance. The E-flite® Habu 32 DF is the largest in the series and has delivered pro-grade performance to the club field environment. The new E-flite® Habu 32x DF jet takes electric ducted fan (EDF) performance and engineering to new heights. Designed around the E-flite Delta-V® 32 80mm fan unit and high-speed DF32 brushless motor, its hyper-efficient intake and exhaust ducting deliver a potent power system that produces a large amount of thrust available as quickly as you can move the throttle stick. The new swept-back wing and horizontal stabilizers enhance the sleek appearance. The result is a sport EDF that will give even experienced jet jockeys goose bumps. The Habu 32x DF boasts a level of fit and finish that is every bit as impressive as its performance. Even more satisfying is the short amount of time you’ll need to get this hot-rod flight-ready. The recommended E-flite accessories and Spektrum™ radio gear can help provide the smoothest build possible, as well as flight performance even the discerning modeler and expert pilot can appreciate.
Rigid Construction
The new swept-back planform of the wings and horizontal stabilizers feature full-balsa sheeting and genuine UltraCote® film covering. The wings attach to the fuselage using carbon fiber blade spars that fit into aluminum sockets for a rigid structure that can handle incredible speeds and G-loads.
Retract Ready
The Habu 32x DF features built-in wheel wells and hard-points that easily accept the required retracts such as the E-flite 15-25 size electric retracts (EFLG230-sold separately). The gear doors included improve streamlining and conceal the main landing gear struts when they’re retracted.
Fast Assembly
The ailerons, elevator and flaps use a sealed-hinge of genuine Hangar 9® UltraCote® covering for a clean look and less drag. The complex, bifurcated fiberglass intake ducts are factory installed and perfectly faired inside the fuselage so you can get in the air quicker.
Optimized Ducting
An optimized intake and exhaust design delivers maximum fan thrust without requiring cheater holes. As a result, the Habu 32x DF delivers outstanding performance in all flight conditions, reduced amp draw, quieter operation and a better flying experience overall.
Easy Access that’s Sleek
The quick-release hatch makes swapping out batteries and accessing electronics easy. Nose and belly hatches make access to the nose gear and EDF simple. A tinted clear canopy adds greatly to its "real" appearance in flight. Pilot figure not included.
SPECIFICATION
Plane Type: Ducted Fan
Fuel Type: Electric
Experience Level: Advanced
Is Assembly Required: Yes
Recommended Environment: Outdoor
Motor Size: 32-class brushless EDF motor
Fuselage Construction: Molded fibreglass fuselage/fin
Wing Construction: Foam-core wings and stabilisers with full balsa sheeting
Wing Area: 26.6 sq dm (412 sq in)
Wingspan: 1070mm (42.0 in)
Flying Weight: 3.20–3.40 kg (7.05–7.50 lb)
Overall Length: 1250mm (49.5 in)
Radio: 6+channel full range transmitter and receiver
Retracts: 15- to 25-size, tricycle (required)
Flaps: Yes
Servos: (8) metal-gear micro servos
Speed Control: 80-amp, 22.2V brushless ESC
Flight Battery: 6S 22.2V 5000mAh 30C Li-Po
Trim Scheme Colors: UltraCote® - Dark Yellow, Silver, Pearl Charcoal
Approx. Flying Duration: 4.5 minutes
Center of Gravity: 110–125mm (4.30–4.90 in) back from the leading edge at wing root
Pilot Figure: Optional
Hardware: Complete precision hardware package includes machined aluminium wheels
Manual#
http://www.horizonhobby.co.uk/aeroon...085-Manual.pdf
Sep 18, 2014, 05:04 AM
who dares wins
like2fly!'s Avatar
Interesting. I think I prefer this colour scheme. Better visibility. Otherwise identical to Habu 32?
Sep 18, 2014, 05:11 AM
There is a video posted on YouTube now. Says new swept wing design. Looks very similar to the old plane. Even if it is just a new color scheme it is nice to still have the airframe available. They fly great.
Sep 18, 2014, 05:34 AM
At High Altitude...
flightpunch34's Avatar
Looks great chuck,i posted a thread early this morning cause i couldn't find any on it,good to see you posted this anyway,if i was to go for another EDF myself this is the one i would go for,looks great.
icicles's Avatar
Looks like it is slightly larger. The wingspan has increased. So it looks like they have done some work. Thumbs up from me.
Chris
Sep 18, 2014, 06:02 AM
Warbird & Jet Lover
Same fuselage, new wings & horizontal tail.
Sep 18, 2014, 06:35 AM
Need 4 Speed!
pdawg's Avatar
Black and Yellow work great for high visibility! Good choice of scheme!
Is there a better top-view photo of the habu-X showing the wing sweep?
Latest blog entry: original Y/A F-18 Kit
Sep 18, 2014, 06:43 AM
kthadlee53's Avatar
RacerX colors from old Speed Racer cartoon and renamed 32X.Hmmmmm
Sep 18, 2014, 06:45 AM
Kevin Cox's Avatar
EFL8085 Habu 32x v1 YT (2 min 4 sec)
Sep 18, 2014, 07:30 AM
who dares wins
like2fly!'s Avatar
Thanks for the update Dave. Any chance of Oleo/spring/trailing struts as an option for your retracts?
I just fitted Tams struts to my Habu 32. I didn't like chopping a part of the wing away. A smaller version of the retracts the Stinger 90 uses would be perfect; metal trunnions, compression mains, trailing oleo nose. Many landings no issues.
Alex
Sep 18, 2014, 07:31 AM
Hawk Fanatic
SkylineFlyer's Avatar
Oh boy.
Sep 18, 2014, 07:34 AM
Dont forget the velcro straps
corsair nut's Avatar
oh snap, thats pretty sweet!!!!
Sep 18, 2014, 07:52 AM
Multi-Platform Pilot
barracudahockey's Avatar
Cool
Sep 18, 2014, 08:20 AM
The best in EDF since 2005
Extreme_RC's Avatar
Love the colours!
Latest blog entry: Extreme RC AUSTRALIA
Sep 18, 2014, 08:24 AM
At High Altitude...
Any one know prices of speccing out items and airframe etc,or roughly to give some food for thought,thanks!
