Sep 14, 2014, 10:23 PM
KC8WPF
CG Bob's Avatar
Build Log
Coast Guard 36551
I started working on the Dumas kit of the USCG 36' motor lifeboat. I've already planned most of the modifications I'll be making to make the stock kit more accurate:
Open up & detail the forward manhole at the bow
Extend the main deck to the gunwales
Add intermediate frames
Open up the scuppers
Replace the stock port lights and wheel
Sep 15, 2014, 08:17 AM
charlie eaton's Avatar
How about 36424, she was double planked below and ice sheeted. The sheeting followed the upper edge of the double bottom same as the boot top on 551. Bbenner needs one for spring up there.
Sep 15, 2014, 09:33 AM
Webmaster, MMCNE
RCBoater's Avatar
I see you applied Finishing Resin to the interior, to waterproof everything. What sort of glue will you be using when it come time to plank the boat? I'm wondering if the resin impedes a strong glue joint?
Sep 15, 2014, 10:31 AM
boat butcher
the goon's Avatar
Mark
Sep 15, 2014, 11:54 AM
Tim B.'s Avatar
Sure and this is an interesting subject Indeed ~
Sep 15, 2014, 09:52 PM
KC8WPF
CG Bob's Avatar
Finishing resin was applied to some of the frames, keel, and bottom of the sheers; mainly in areas that will be hard to access after the planking is applied. Be careful not to get it on the edge where the planks will be attached. I use medium CA for most of the construction. Some areas, like motor and servo mounts, get reinforced with 30 minute epoxy. After the hull is planked, the inside of the hull will have finishing resin applied. The planks for the forward and aft turtle backs or decks will have resin applied to one side before they are glued to the frames.
Some planking was completed and intermediate frames installed. The interior of the hull was sealed with finishing resin.
I'll be back working on the model when I return from the Coast Guard Tug Association reunion.
Sep 15, 2014, 10:14 PM
Tim B.'s Avatar
These efforts are Sure to pay off later as they will be visible ~........
It will be fun to see the detailing on the forward area !
Sep 21, 2014, 09:34 PM
KC8WPF
CG Bob's Avatar
When I applied finishing resin to the interior of the hull, I mixed more than enough and applied the extra to one side of the balsa strips that will be used to plank the forward and after cabin tops.
Sep 21, 2014, 09:37 PM
Tim B.'s Avatar
How was the reunion ?
Sep 21, 2014, 10:17 PM
KC8WPF
CG Bob's Avatar
The reunion was great. I've started posting some pictures of the CG Yard tour in Dock Talk.
Sep 26, 2014, 07:58 AM
Bob, what do you think of the kit so far??
Sep 26, 2014, 04:04 PM
KC8WPF
CG Bob's Avatar
Charlie, it's not a bad kit. It could be more accurate, but that would increase the price. While there are some things wrong with the box stock kit, I'm trying to show some easy fixes to correct some of those issues.
