ProBoat Blackjack 24-inch Catamaran
ProBoats Latest Blackjack is due to arrive later this month
It's Almost Here
The ProBoat Blackjack 24 Catamaran is due to arrive in Late September. This boat will haul serious butt and comes Ready To Run, only requiring you to provide your own batteries. The power system is comprised of a 2000Kv brushless motor and a 30A marine ESC. Both are water-cooled and the electronics are sealed away keeping the water out. It's capable of speeds up 25MPH and it appears to handle great as seen in the video below.
Learn more about the Blackjack 24
Sep 08, 2014, 03:01 PM
RC Aviation Freak
John234's Avatar
I think this will really be a winner! I can't wait until it is available.
Subscribed!
Oct 26, 2014, 06:55 AM
Blackjack 24 Issues
Well was excited to open up the new Blackjack 24 and take it for a drive with my son but as soon as I unstrapped the velcro for the battery tie downs, the entire tray that houses everything pulled off the bottom of the boat. There is an apparent poor glue job as I barely had to touch it and the whole tray lifted off. I can't drive it and shouldn't have to be repairing a brand new boat already. It seems to me like glue is not sufficient to hold this piece down, it needs to be bolted to the bottom of the boat. Sent an email to Proboat, hoping they have a resolution.
Oct 27, 2014, 12:52 PM
Tip Stall
DENSRC63's Avatar
Thought the 24" Black Jack hasnt been released yet?? Due Early November, 2014
Do you have the 29 ??
Oct 27, 2014, 01:33 PM
micromodder's Avatar
Its in stock at Amain
http://www.amain.com/Pro-Boat-Blackj...d_aBoCiFTw_wcB
Oct 27, 2014, 03:03 PM
Tip Stall
DENSRC63's Avatar
Originally Posted by micromodder
No eh ... Hmmm mabe might wait for the first batch go go through if I hear of any more assembly issues. Didnt even realize they were out. Wernt suppose to be out till Nov.
Oct 31, 2014, 06:55 PM
Blackjack 24
I returned the first one I got, ordered a second one. Same crap! This time the glue was actually broken off and tray was floating around again. Not buying another one of these. I told the guy at proboat that the tray has to be fastened with bolts because the glue obviously isn't holding. I've never owned a Proboat before, but seems like on these new models they're using this cheap method of securing everything down with the plastic tray that's merely glued to the bottom of the boat. It looks like in the older models they used a nice wooden structure instead but to cut down on cost are now using this instead.
Nov 04, 2014, 10:49 AM
Tip Stall
DENSRC63's Avatar
Sounds like they got a bad batch or probably the wrong type of glue. Shoe Goo or Gorilla glue (a soft setting glue) should hold down the tray. I agree shouldnt be like that but a easy fix if you could break off the factory glue and re glue yourself. Be best to sand / rough up the surfaces before applying glue.
Nov 06, 2014, 10:24 AM
That sounds like it would work and I tried relaying a similar message to the tech folks at proboat but don't know if the message was relayed any further. I was just annoyed because you wouldn't think the customer would have to do this to a brand new boat. My solution for now was to buy the Aquacraft Wildcat, lol.
Nov 06, 2014, 11:11 PM
I feel the need for speed!
scorpion1's Avatar
Wonder if it will take 4s?
Nov 07, 2014, 09:51 AM
Tip Stall
DENSRC63's Avatar
No 3 cell max says in manual on line
A battery (sold separately) is required to operate the boat.
The ESC will operate with 2–3 Cell (7.4V–11.1V) Li-Po or
6–9 Cell (7.2V–10.8V) Ni-MH/Ni-Cd batteries.
I think it will be fast enough on a 3 cell LiPo a 4 cell would be uncontrollable for a boat this size.
Nov 07, 2014, 03:39 PM
Tip Stall
DENSRC63's Avatar
Its weird Horizon Hobby said they havnt gotten them in yet. I called to ask about the loose tray thing and they said no idea they havnt even got the first shipment yet not due to later this month.
Amain did show them in stock .
Nov 07, 2014, 06:51 PM
Ha, well I ordered two from Horizon and returned both. I do see they are currently on backorder. I wonder if they pulled them from the website for now. I might've gotten the "mistake" batch.
http://www.horizonhobby.com/pro-boat...A-rtr-prb08007
Nov 07, 2014, 08:13 PM
Tip Stall
DENSRC63's Avatar
Im thinking the same thing. They pulled all the stock and are repairing or sending back for repair before a bunch get out for Christmas. That would explain why they have no ETA as they usually do on out of stock items. Im thinking there doing damage control playing dumb like the goverment ...deny any knowledge and fixing the issue behind the scenes.
Just noticed in the replacement parts the replacement hull shows the inner black tray NOT installed so I guess they expect you to glue it in yourself if you need a replacement hull.
Nov 10, 2014, 09:55 AM
Tip Stall
DENSRC63's Avatar
NEW ProBoat Blackjack 29 Horizon PRB08011
Just thought I would mention there is a NEW V3 29" Blackjack replacing the V2. ProBoat Blackjack 29 Horizon PRB08011 V3 coming out next spring. Looks like beefed up electronics and rudder sytem.
