This thread is privately moderated by JNJO, who may elect to delete unwanted replies.
Sep 06, 2014, 04:37 PM
Done Posting, Gone Flying
JNJO's Avatar
Build Log
(In Progress) 70mm EDF Foam Viggen
My way of solving it.
Built using plans by Johan Hansson, downloaded from FliteTest
Johans original build thread is here: Sportskala Viggen EDF
There are plenty of good build logs already made for this awesome model, so I won't go into much detail.
I'm only showing how I got around what, for me, was the more critical steps.
My biggest concern was getting the formers done.
A tip from D_Fast on the SAAB Viggen thread suggested using cardboard.
Mine are made from empty Xerox printer paper boxes, which are about 2mm cardboard.
A well made pizza-box would probably work too.
Made some A3 and A4 size printouts for the formers to help with printing.
A3_Formers_Btb_Ctb
A3_Formers_F2tb_Ftb_Atb_B...
A4_Formers_Dtb_Etb
A4_Formers_G1tb_E2b_G2b
A4_Formers_Htb
I make a rough outline with a dremel and a 2mm diamond wheel point.
Then, with a very light hand, sand down to the lines using a 6,4 mandrel.
Final sanding to get a smooth edge is done with 400 - 600 grit paper.
That is also used to get rid of the "paper-frizz" around the edges.
I make two formers for each station, one for the inner cut, one for the outer.
They are dirt cheap and quick to make, and I like the extra stability.
I make a centerline on each former to aid in placement.
I also extend them about 10mm from the line that marks the dividing line between upper and lower half.
This is to get lead-in and lead-out ramps that helps keeping the entry end exit of the hotwire straight.
A light mist of 3m 77 Scotch Weld on the formers sits for about a minute before I put them on the foam.
Another problem I had, was to cut the foam squarely.
The gravity method didn't work for me, so I made a jig from laminated shelves.
Instant square cuts.
Not too bad for a first attempt. (I hope...)
Measurements for each block:
Width: 180mm.
Height: about 100mm
A-H
824mm
A-B
100mm
B-C
120mm
C-F
305mm
F-H
298mm
C-D
68mm
D-E
74mm
E-F
163mm
F-G
227mm
G-H
71mm
Sep 09, 2014, 10:08 AM
Coming along . If you cut carefully with scissors you barely even need to sand around the edges . At least with posterboard that is . The Square jig is a good idea .
Sep 09, 2014, 12:36 PM
JNJO's Avatar
Yeah, I tried with posterboard, but I guess the one I found was the thinner kind, and it didn't work well. Too flimsy.
Sep 24, 2014, 07:06 PM
Hi for the viggen plans how do I print all of your plans and piece them together? after I printed them, they were uncompleted and I couldent put them together please help
Sep 25, 2014, 02:52 AM
JNJO's Avatar
I just made the ones for the formers, as those were the only only ones I needed for now.
To print those you need to select the right paper (A3 or A4) for your printer and also make sure the orientation is correct (Portrait or Landscape.)
I suggest you use PDF-XChange Viewer. It has an excellent preview function.
