Sep 01, 2014, 09:35 PM
Three green
Build Log
Jerry Bates 1/5.6 Sea Fury build
This is my first scale project and it is going to be a serious challenge for me. I've built several kits before, but never anything like this. I'm not going for a high degree of scale detail, but rather just a nice warbird that flies well. For example im not planning on a retract on the tail due to the large weight penalty. I have purchased the plans, the canopy, and cowl from Jerry, and the wood parts kit from Bob Holman.
These are the specs
Scale: 1/5.6, Wingspan: 81.25
Length: 72, Weight: 18 24 lbs.
Power: ST3250 G45
This is the goal
Name: Canadian Sea Fury.jpg
Description:
This is what I have so far
Name: wing centre section.jpg
Description:
More to follow
Sep 02, 2014, 05:39 AM
Subscribed
Sep 02, 2014, 08:45 PM
Hi, throw away or sell the Super Tiger that was all we had in the old days.
G45 very good engine but side carb and side exhaust.
When running an engine upside down you need a pumped carb like a walbro etc. they were designed for chain saws and give positive fuel in all positions also you need a spark that will give positive ignition against a glow plug upside down that may on a a good day supply the glow if its not drowned by fuel.
I am running a DLE55 gas in a 25 Pounds 81 inch me109 and its a very good match foe weight and power.
All warbirds end up tail heavy and you have to add nose weight so put a heaver engine in instead.
If it was me i would put in the rear exhaust DLE55 with rear carb..
If in Australia custom retracts.
The above advice comes from experience learnt the hard way.
Dave.
Sep 03, 2014, 02:04 AM
Three green
I'm on day one of seven 12 hr shifts right now so I won't be getting much done for a while.
I did get a bit done before work tonight. I got the rest of the nose ribs installed that make up the stepped shape of the leading edge. I still need to put the 1/4 square forward part of the leading edge on.
Description:
These 1/2 inch thick nose ribs didn't come with the parts kit but they were easy to make. They give some material to be shaped when the skin is on to round the leading edge step out
Description:
Sep 07, 2014, 02:09 PM
Nergall's Avatar
From what I understand, it's nearly impossible to laser cut half inch think balsa. So, yeah, no one would include that part in a laser cut kit.
Sep 10, 2014, 08:40 AM
Three green
That makes sense. I wasn't complaining about the parts kit. Im very happy with Bob Holman's kit.
I got a bit more done yesterday. Got the forward leading edge 1/4 square on, and the lower spars glued to the dihedral braces. Thats all good. I went at sanding the tops of the ribs in prep for the skin and realized that the outboard ribs on the centre section are sitting lower at the front than they should be. Thier slots in the dihedral brace must have been deeper. This is looking down the rib from aft at the fwd dihedral brace. Its about .040 inch or so.
Description:
My worry is that this rib is essentially the inboard rib of the outer wing pannel, so is this going to build in some washout? Its the same on both sides. Any suggestions?
Sep 10, 2014, 01:09 PM
Three green
I've been looking it over and I dont think its gonna be an issue. The dihedral brace extends out to the next rib on the outer panel, so while that one section by that rib on each side will be turned down slightly, the rest of the outer panel should be indexed by the brace and all should be straight. I put a staight edge over the ribs at the front and its more like 20 thou low so im gonna move on. Off to get some 3/32 balsa fo skin..
Description:
Oct 08, 2014, 04:43 PM
Three green
Its been a month since I posted anything but I've been getting a bit done. Got the centre section sheeted and working on the right wing panel now.
Oct 08, 2014, 05:01 PM
Three green
Had to sand down the top spar for the outer couple ribs. I did that before gluing it in place.
Description:
The rib at the inboard end of the aileron was a bit tricky to glue in place without the bottom spar in place but I'm happy with the result.
Description:
Now I just need to sheet this section and I can get into the aileron and flaps.
Oct 23, 2014, 02:47 PM
ct-7 , I can see that you are starting the build the same as I did I have the wing framed up and I am gluing in the spar webbing now . what are you going to use for power ,retracts , paint ??
I have the ailerons done with a center hinge point . nice to see more of this plane being built
Jim
Oct 24, 2014, 11:06 PM
bluffman's Avatar
This is s great project here is mine cowl isn't on motor now dialed in and ready for maiden. Build the tail light mine is 36lbs with a g62 and Sierra giant scale gear. Ian
Oct 26, 2014, 12:38 PM
Three green
Jim
Hi Jim
For power I will likely use a DLE 55. I'm not sure about the gear. The Sierras are beautiful but im not sure I want to spend that much so ill just move on and decide later. If I end up really happy with my work maybe ill go for them. Ill be glassing and painting it but I haven't put too much thought into specifics.
The other wing is framed up and I should be ready to sheet it soon.
I am also thinking about the ailerons. I was going to hinge them on the top as in the full scale but now im not sure. Maybe I should use robart hinge points. It seems that is what most people do on this plane. I wanted to use the plans design but I need to think about that.
Oct 26, 2014, 12:48 PM
Three green
Hi Bluff
Wow! That thing looks awesome. Nice work. I'll be super happy if mine looks anything like that!
Ya I plan to keep the tail as light as I can. The tail wheel will be fixed and steerable.
Id love to hear about the maiden. Best of luck to you.
Nov 09, 2014, 11:39 AM
ct-7 , as far as the ailerons I did what the plan showed but I added a center hinge made from G-10 and it came out awesome and works with no binding and very strong . I am thinking the same as you for the retracts they are very spendy
so I think that I mite use something from robart for half the price and I'm still debating on an engine G-62 or a DLE-55
Ian , its nice to see that you are still around I wonder what happened to you
from the RCU build that you had
Nov 11, 2014, 10:45 AM
bluffman's Avatar
I am still around flying PSS. The ailerons I did mine with the aluminum tube with a carbon rod the whole length just like the plans, I hope it holds up. With many delays for maiden this Sunday looks like a GO. I will post Sunday night Ian
