Aug 30, 2014, 06:22 AM
Cheap single cell charger
Banggood has 10 of these small USB chargers for just over $10:
http://www.banggood.com/10Pcs-USB-Li...-p-943765.html
The charge current is determined by the resistor marked R3. On the board it is 1.2Kohm which means the charge current is 1000mA (1A). By substituting this resistor for a higher value, you reduce the charge current. 5Kohm will give you a 250mA charge current. The values are in the datasheet which can be found here: http://dlnmh9ip6v2uc.cloudfront.net/...ing/TP4056.pdf
The boards have an overcharge protection circuit. As far as I can tell the lowest charge rate you can acheive is 130mAh.
Aug 30, 2014, 11:31 AM
Nooflyer's Avatar
I'm currently using this lipo charger which charges at 100mah. You can also solder a jumper on the back for 500mah. Plus its 6$
http://www.adafruit.com/products/1304
Aug 31, 2014, 04:22 PM
Mark Harrison
Neat! Any idea what size that R3 resistor might be (e.g. 0603)?
Aug 31, 2014, 05:07 PM
skumgummi dave
Lurking...
Dave-
Aug 31, 2014, 05:18 PM
Don't know the size of the resistor but will let you know once the boards arrive. I'll probably hook it up to a switch and a couple resistors so I can change the charge rate.
Sep 08, 2014, 12:55 PM
Max
Very cool find!
Does anybody have calculated R values for different currents?
Sep 08, 2014, 12:56 PM
Maksim, look in the datasheet I posted the link to. It has a table with charge current/resistor values.
Sep 08, 2014, 01:23 PM
Max
Thanks Epilot!
For those wondering, here's the table of resistor values (from the PDF).
Another question that I have is what is the minimal battery current that we could use this for? I don't think the specs show the absolute maximum value of Rprog.
Sep 08, 2014, 01:32 PM
IIRC it says the lowest charge current you can use is 130mAh.
Sep 10, 2014, 11:48 PM
Mark Harrison
Woo Hoo, mine just came in! Got a package of 10. Need to figure out what charge rates I need. I like your idea of offboarding to a switch.
This will be my first time swapping out SMD devices, kinda excited to give it a try!
Sep 11, 2014, 06:19 AM
A.K.A sir Crashalot
methuso's Avatar
it only says lithium charger. Is there no differences in charging li-ion to li-po ?
Since i bought a 5pack li-ion chargers a couple or years ago and thought i bought wrong and never use them
/Ulf
Sep 11, 2014, 06:30 AM
Li-ion cells are 3.6V, Lipo are 3.7V. Worst that can happen is that you don't get a full charge.
EDIT: Both chemstries terminate charging at app. 4.2V so there shouldn't be any issues. The both use CC/CV charging.
Sep 11, 2014, 06:46 AM
Good video about the charger:
New TP4056 Lithium Cell Charger Module with Battery Protection (12 min 56 sec)
Sep 11, 2014, 02:21 PM
A.K.A sir Crashalot
methuso's Avatar
Whoo. Then i have five more chargers laying around
Sep 24, 2014, 12:46 PM
Mine have arrived but then I realised I don't have any resistors of the appropriate values. No trimpots either. Oh well, order some from Banggood and wait another month.
Discussion 1 cheap quad charger or 4 single chargers Pyrofan Batteries and Chargers 24 Jun 03, 2016 09:02 AM
