This thread is privately moderated by garyw76, who may elect to delete unwanted replies.
Aug 24, 2014, 02:57 PM
Trader Rating: 173
$3,500.00 USD
Buyer pays shipping
Sold
jtm viper 90 turbine bind n fly
for sale jtm viper 90mm converted to turbine
wren 44 gold turbine
eflite retracts with tam struts and brakes
spectrum metal gear digital mini servos
spectrum 9ch receiver
10 flights old
has minor scrape on bottom of wing tip and has one small blemish in paint from a hot start
$3500.00 plus shipping costs
Aug 25, 2014, 01:18 PM
Trader Rating: 25
Fly more Foam
sam51401's Avatar
How much time on the turbine and when was the last service?
Flight time and amount of fuel on board?
Was this a straight conversion from a new kit or was it EDF prior?
Any chance you may be at E-Jets in Columbus?
pics of the inside and installs
Sam
Aug 25, 2014, 04:34 PM
Trader Rating: 34
superjon's Avatar
What are using for battery power management?
Aug 25, 2014, 04:58 PM
Trader Rating: 173
turbine only has a few hours on it . plane was built turbine from the get go . it was new never flown when I got was built by ron at wren turbines usa. it has 3 16 oz tanks in it I set my timer at 7 minutes and the last tank before the uat was still 3/4 full . it has a 5 cell nimh pack for the rx and a 2 cell lipo 2100 for the turbine
Aug 25, 2014, 04:59 PM
Trader Rating: 173
was not planning on going to ejets but I would make the trip to deliever the viper
Aug 25, 2014, 05:31 PM
Trader Rating: 25
Fly more Foam
sam51401's Avatar
What is the dry weight as the min is 12lbs to qualify toward the waiver?
Aug 25, 2014, 05:35 PM
Trader Rating: 25
Fly more Foam
sam51401's Avatar
Like to see the inside where the burn mark is. How much damage and what effect on airworthiness?
Aug 25, 2014, 09:23 PM
Trader Rating: 173
it is right at 10 pounds without fuel. the only damage was the paint no damage to the pipe or any structure has 8 flights since
Aug 25, 2014, 09:42 PM
Trader Rating: 25
Fly more Foam
sam51401's Avatar
Nice combo but I wouldn't be able to get waiver with a 10lb jet. How unfortunate.
Aug 26, 2014, 04:41 PM
Trader Rating: 173
I didn't think that mattered I didn't think it had to even be turbine for the flying portion just a high speed airplane then prove you can operate a turbine . I know with a heli turbine waiver you cant use a turbine heli because you don't have the waiver yet. I think a lot depends on who is doing your sign off.
Aug 26, 2014, 08:19 PM
Trader Rating: 25
Fly more Foam
sam51401's Avatar
Yea, around Louisville area we have a good bunch of jet jockeys and per the AMA requirements the plane must weight more than 12lbs dry. They fly you on a buddy box till they cut the cord. It all depends on who you have and how well you demonstrate proficiency.
Aug 27, 2014, 06:58 PM
Trader Rating: 0
toolmaker49's Avatar
Needs to be a turbine atleast 12# rule change might be able to slide on the 12# check with a cd waiver holder it would be real close with full fuel or just add some weight under the fuel tanks to make 12#
Aug 30, 2014, 12:51 PM
Trader Rating: 7
Double E's Avatar
I got my waiver flying the exact same jet setup. I guess it depends on who is signing you off. The weight of the plane wasn't even discussed.
Aug 30, 2014, 02:36 PM
Trader Rating: 81
Not a Drone pilot
lashmett75's Avatar
16oz of fuel will weigh just over 1lb. So 3 tanks will make all up weight 13.
You are good with the 12# waiver min
James
