Aug 23, 2014, 12:24 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Depron LadyBird
1 metre wing span ... easy build ... slide on grass ... designed to take up to a 8" prop for quieter flying but could be easily made to take a 64 - 70 mm EDF
LadyBird anyone ?
Lockey
Aug 23, 2014, 01:07 AM
Zen in the art of foam
djacob7's Avatar
All ears...
Aug 23, 2014, 02:47 PM
skumgummi dave
Lurking again...
Aug 23, 2014, 03:27 PM
If it's easy, durable, and cool looking, which this looks like one, I'm all ears... errr eyes!
If this can be made out of 9mm EPP, then I'm definitely building one. I have 6 pieces of 24x36 9mm EPP foam boards that just arrived in the mail.
Aug 23, 2014, 07:59 PM
Lockey's Avatar
Thanks for the interest guys
As you know, most of the models I design and build are based on 6 mm Depron, but I am sure most other sheet foam products can be used instead by adjusting the measurements to accommodate the different thicknesses
I have been playing with different ideas to make building easier (and quicker) and was intending making this one a "score and bend" type of fuselage build
Unlike the score and build that RC Powers uses, as he scores and folds out, I intend to score and fold in making for a lot nicer finish ... this is probably not new, but is something that I haven't tried with my plans before
I tried this on my Tiny Little Fokker and it worked very well, so will go one further with this one
Lockey
Fuselage (6 min 58 sec)
Aug 23, 2014, 08:01 PM
Lockey's Avatar
This will be the top and bottom patterns for the fuselage, to be bent the same way as the Tiny Fokker
Lockey
Aug 24, 2014, 12:41 AM
Marty Petri Sr.
mbpetri's Avatar
Lockey
Lockey,
Do you do anything at the folds for re-enforcement? If not, then this technique would save a ton of glue, both volume and weight.
Marty
Aug 24, 2014, 03:58 AM
Lockey's Avatar
Originally Posted by mbpetri
Lockey,
Marty
Hi Marty, yes I would run a bead of glue down the joint, but I guess it wouldn't be totally necessary, I also tape the outside of the foam before bending and this can either stay on or be removed
Lockey
Aug 24, 2014, 06:26 AM
Lockey's Avatar
Plans almost finished, 2 sheets of Depron for this one ... not many parts, should be quite a quick build
Anyone like to have a crack at it ?
I went out on Friday and got myself a box of Depron (20 sheets) so I will make a start next week if I get the chance
I have done a double thickness booms on this one to be able to sink the elevator and rudder servos in and it will also hide the CF spar
Lockey
Aug 24, 2014, 01:17 PM
Retired CAD guy
birdofplay's Avatar
Wow Nice version !
I have been making Charas' Harpy for yrs and have just recently been modifying it
See pix.
All I.'ve done is square up the Fuse and narrow the forward wing a bit.
Still I like yours too :-)
Mine needs an RX and ESC and it'll be ready.
Going to an Aero Tow next weekend so I'll be getting ready for it.
We'll compare notes l8r
BOB
Aug 24, 2014, 01:29 PM
Not always grumpy!!
insomaniac45's Avatar
Wow Lockey.
Another fantastic looking bird.
If i ever have time. this could very easily find its way high on my build list
Aug 24, 2014, 04:22 PM
elmagnificado's Avatar
Originally Posted by birdofplay
Wow Nice version !
See pix.
BOB
This definitely reminded me of the harpy as well. I tried to modify my harpy to fly off water very early in my building career by adding a bottom fuse before learning how to water proof $ tree foam board. ;-) Flew off grass just fine.
Aug 24, 2014, 05:05 PM
michigan jet guy
mrshea's Avatar
that is awesome! Phil
Aug 25, 2014, 12:11 AM
Lockey's Avatar
Decided to do an optional wing skin in 3 mm Depron with 6 mm wing ribs
I think it looks kinda cool
Or ... maybe a delta wing version ... I think I must have too much time on my hands
Lockey
Aug 25, 2014, 02:38 AM
Alpha Whisky
AlphaWhisky's Avatar
Subscribe .... Downloaded Polaris plans two house moves ago but haven`t got started on that one yet. Still flying my amended Mermaid and loving it.
Plenty on the plate right now but I`ll be keen to see this neat design develop ....
Alan W
For Sale Rakon nQx Custom LEDs, Walkera Ladybird V1, MMW 0615-11 Motors, Ladybird Motors... MONOAMORE Aircraft - Electric - Multirotor (FS/W) 3 Feb 16, 2016 02:40 PM
Gallery Depron ladybird RUDOLF Your Plane Photos 0 Oct 19, 2003 09:31 AM
