Sequence 120 GP/EP - RC Groups
Aug 10, 2014, 06:23 PM
Aerodynamically challenged
3Deranged's Avatar
New Product
Sequence 120 GP/EP
Took them long enough after canceling the smaller version:
http://www3.towerhobbies.com/cgi-bin...?&I=LNEDWF&P=G
Aug 11, 2014, 06:41 AM
ltc
ltc
AMA 97737
ltc's Avatar
I'm guessing based on pricing that it is another built up fuselage, similar to the 2m Vanquish and 2m Monolog 140 ... albeit at a lower price point than those and a bit smaller.
The original was a bit 'weak' in the fuselage (firewall and landing gear) IMHO, so hopefully they've made some improvements to go along with the increased size and weight.
Aug 11, 2014, 02:21 PM
3Deranged's Avatar
It appears to be partially built up with the usual foam turtledeck etc. As with most planes you have to do some hobbying up to make them right. Bolstering up the LG plate and firewall area are always something I do to any kit no matter who makes it as I know repeated landings in grass will kill even a good LG mount eventually. And we always "overpower" our planes a little bit anyway so some triangle cornerstock is always added to the firewall area. As long as they didn't slobber on too much epoxy for the GP build the EP might be about the right weight.
Aug 12, 2014, 02:10 PM
intheairagain's Avatar
Just found this on towers website. Is there and specs available yet?
Aug 12, 2014, 02:22 PM
ltc
ltc
AMA 97737
ltc's Avatar
More details
http://www.towerhobbies.com/products.../gpma1232.html
Wingspan: 71.5 in (1815 mm), Wing Area: 836 in2 (53.9 dm2), Weight: 9.75-10.75 lb (4420-4870 g), Wing Loading: 27-30 oz/ft2 (82-92 g/dm2), Length: 73 in (1855 mm) Requirements: Radio system with a minimum of 4 channels and 5-6 servos, 2-stroke 1.20 or 4-stroke 1.55 glow engine or 50-65-450 outrunner brushless motor, 80A (min.) brushless ESC, 22.2V 5000mAh LiPo battery & compatible charger
Aug 12, 2014, 02:24 PM
ltc
ltc
AMA 97737
ltc's Avatar
Aug 12, 2014, 02:43 PM
Nice!!! Thanks for the info.
Aug 13, 2014, 01:21 PM
3Deranged's Avatar
I'm thinking 8 to 10s setup would be for comp/practice. Used a Motrofly 5320-277kv on a Mythos 125-seemed to have plenty of grunt for uplines.
Aug 13, 2014, 01:45 PM
ltc
ltc
AMA 97737
ltc's Avatar
Ken at Subsonic does some good motors.
Aug 15, 2014, 10:30 AM
I wish they'd bring back the original Sequence. It had a few short comings, but tracks like it is on rails and looks nice in the air. A perfect size for the club field I belong to. I would love to find a spare - just in case!
Aug 15, 2014, 12:37 PM
Does anyone know if the wing tube and landing gear legs are metal or carbon fiber? The listed weight for the plane is a little on the high side for its size.
Aug 15, 2014, 08:03 PM
ltc
ltc
AMA 97737
ltc's Avatar
The photo I posted in #6 states "lightweight carbon fiber landing gear"
Aug 16, 2014, 09:37 PM
Thanks. I missed that. We had a Sequence at the field today and guy that owns it really likes. He is one of our newer pilots so he is a little worried that if anything happens to the plane he will not be able to replace it.
Aug 16, 2014, 09:55 PM
ltc
ltc
AMA 97737
ltc's Avatar
He may be correct
The only NIB Sequences Ive seen as of late are from European hobby shops.
Even the spare parts are disappearing from the US
Aug 21, 2014, 08:12 AM
3Deranged's Avatar
My bud Blake still has his Sequence with a Scorpion setup. Man that thing screams! Kind of ol' school pattern-100mph but nice and straight! Added some small SFGs to the wingtips and it's locked in.
