Turnigy Bolt Li-HV Battery Packs
Higher Voltage Battery Packs
High Performance Batteries
The new Turnigy Bolt Li-HV batteries are looking to change the game. Where most Lipo cells are charged to 4.2V, these cells can go up to 4.35V. In a 3S battery that means a full charge at 13.05V, nearly half a volt higher than a standard Lipo. And that's not all, they can be discharged at 65C with 130C Burts! You can also charge them at 2C. These packs will be phenomenal for performance models with the higher starting voltage providing some extra punch right from the get go. Currently you can get Bolt batteries in 2S, 3S, 4S, and 6S with capacities ranging from 2400-5400mAH.
Learn more about Turnigy Bolt Li-HV Batteries at Hobby King.
Aug 08, 2014, 08:33 PM
www.gunnphotoservices.com
Matt Gunn's Avatar
I wonder if we will see these soon in a 2 cell ROAR approved hard case? There will be quite a stink at the tracks with these as a clear advantage!
Latest blog entry: www.gunnphotoservices.com
Aug 09, 2014, 05:58 AM
Southern Pride
everydayflyer's Avatar
Threads on these already underway.
https://www.rcgroups.com/forums/show....php?t=2220628
https://www.rcgroups.com/forums/show....php?t=2221435
and as usua HK did not lead the way bur merely barrowed (?) someone else's idea and most likely infringed on their R&D.
On a side note wish there could be a New Battery developed,being developed , or even released without there being a half dozen Threads started here on it.
Charles
Aug 09, 2014, 07:22 AM
Matt Gunn's Avatar
This is a news article, Charles. Its not a standard thread; you may notice the different style. It gets more exposure than a thread by being located on the left side of the home page and in the aircraft channel. Hope that helps.
Aug 09, 2014, 08:34 AM
Southern Pride
Great then perhaps you or one of he moderators could combie all of the other Threads on this new LiPoly to this one. What I fail to see is how having numeriuos threads on the same new product / advancement helps the masses as the data is scattered here and there instead of being in one easier to read / Search thread.
Aug 09, 2014, 04:53 PM
capt soap's Avatar
How much heavier are these compared to traditional lipo's of equal size?
Aug 10, 2014, 04:20 AM
I thought this thread was for the new Turnigy BOLT series batteries not the new lico chemistry batteries.
But i cant wait to see BOLT series include some 1400mah batteries to feed us hungry mini quad flyers!
Aug 11, 2014, 09:35 AM
Thanks for the article! What are the weights like for these lipos?
Aug 16, 2014, 03:40 AM
Hey Guys,
I don't mean to sound like a Party pooper, but I've just test driven these cells and I was very underwhelmed.
I picked up a 4S 2800mAh 65C pack. The cells only charged to 4.2V a cell and I just flew it on my EF MXS 48" exp swinging a 12x6 prop running a Hacker A30-14L v3. Sorry guys my 6 month old ThunderPower 70C pack blew it off the park.
It's a little disappointing because I have had a good run with the 65C Nanotechs in the 3S and 4S varieties.
It could very well be a quality control issue but this is what I have found.
Sorry guys
Danny
Aug 16, 2014, 03:50 AM
Dan is your charger capable of charging at 4.35v a cell..?..
Aug 16, 2014, 07:27 AM
Electric,
It's an older charger a Hyperion EOS0606i so that could be my issue. What's a good current spec charger I should be using?
Thanks mate.
Danny
Aug 16, 2014, 07:28 AM
For what it's worth - I always balance charge.
Aug 16, 2014, 10:00 AM
Bo Edstrom, Sweden
Danny,
There is a new Turnigy 80 and 200 watt charger that can charge High Voltage LiPo to 4.35 volt.
http://www.hobbyking.com/hobbyking/s...n_Charger.html
Probably many of the other major charger manufacturer will have firmware upgrades to their existing chargers (that can be firmware upgradable by a user) to alllow setting TVC up to 4.35 volt.
In iCharger 4010 user manual it is shown You can set in Charge setup 4.35 volt if needed.
http://icharger.co.nz/manuals/4010DUO.pdf
(page 13)
iCharger 308 Duo has also same settings possibility in Charge setup:
http://icharger.co.nz/manuals/308DUO.pdf
(page 16)
And iCharger 406 Duo can do it also:
http://www.progressiverc.com/media/i...o%20Manual.pdf
(page 16)
/Bo
Aug 16, 2014, 10:12 AM
The final voltage on a lipo is determined by the charger, not the lipo. I've seen lipos accidentally charged past 4.35V per cell due to charger settings - not that that's good for them or you of course!
So if you just attach one of these to a charger set for 4.2V, you're going to get 4.2V.
Aug 16, 2014, 10:31 PM
Hey bossee and Dave H,
Many thanks for the steer on that. I'll give those a run. At least it's been an instructional experience everyone can learn from.
All the Best
Danny
