Help!
Have Frysky D4R-II not binding?
Have the Frsky D4R-II connected for CPPM to my naze 32 broad but doesn't seem to receive signal from turnigy flashed with er9x and has frysky djt telemetry module as well.
I do what says on the manual but get nothing linking up. Any help be appreciated? Do i have to upgrade the firmware or can i get it going with out the update? |
A FrSky DJT module is designed to be able to work with the D4R-II receiver.
I am confident that you shouldn't need a firmware upgrade. Jump onto the FrSky website, go to the product page for the DJT module and download the manual for it. Within the manual it will explain what the two dip switches are for that are on the back of the module. On that back of your DJT, look at the dip switches. Switch 1 should be in the OFF position (ON position used for firmware upgrades) Switch 2 should be in the OFF position (ON position used for V series receivers) Once both switches are in the OFF position, proceed with the bind procedure with the module and the D4R-II, and you should get a bind no worries. Having the module in V8 receiver mode is the only thing I can think of that would prevent you getting a bind. |
