View Poll Results: How do you find the Flying3D X8 ?
It's a great 350mm quadcopter, I am very happy to own it 96 36.23%
It's a good model, but I am not fully statisfied 91 34.34%
I am disapointed 78 29.43%
Voters: 265. You may not vote on this poll
Jul 31, 2014, 05:05 PM
SeByDocKy's Avatar
Mini-Review
Flying3D X8 (FY-X8)
EDIT 07/15/16: he V1.4 version coupled with last V1.49 solve most instabilities. Still remains the "plastic cracks" and fragile landing gear problems
ALERT 06/29/15
Too many problems have been reported even with the V1.4. The quality construction is not reliable. I advise to not buy this product
ALERT 01/23/15
New version of the FY-X8 is now sold since january at BG with a new F/W (V1.42) fixing "fly-away "problems. New model of the FC is now included (a BS-X8 instead of a BS-X4) Now F/W can also be updated online. Other changes will be reviewed soon
ALERT 02/11/14
Due to the "plastic's crack" problem and some unexplained "flyaway/falls", I don't advice to buy this quadcopter until Flying3D is fixing all problems
ALERT 01/15/15 for FY-X8 (V1.2 & V1.3)
DON'T FLASH THE FY-X8 (V1.2 & V1.3) WITH OFFLINE FLASHER PROVIDED BY BIG-SHARK. THIS F/W IS DEDICACED FOR THE CHEERSON CX-20. YOU CAN BRICK YOUR FY-X8 IF YOU ARE FLASHING WITH THIS F/W. ACTUALLY (V1.2 & V1.3) F/W CAN'T BE UPGRADED
CAUTIONS
This quadcopter is not a toy. Please read carefully all the following guide. At least, the compass calibration must be performed before the first take off. You may damage your FY-X8 if not !!!!!
Emergency landing for low main battery voltage is not implemented for attitude (manual) mode, only for altitude and GPS modes
BEFORE YOUR FIRST TAKE OFF, FIRST OWNERS OF THE FY-X8 MUST INSTALL SOME WASHERS OR SPACERS TO AVOID PLASTIC'S CRACKS IN THE MOTOR POD. The screws have been overtighten in first batches (FY-X8 last batch should solve this problem)
with the QX350 spacers
with some washer (OD = 3.5mm, OD = 8mm)
If you install spacers in both side of the FY-X8, you will need longer M3 screws. Some M3x12mm for example. In this setup you can also install any 9" props
INTRODUCTION
Flying3D is a new chinese brand delivering quadcopters. They announced in the last Germany RC congress 3 models: the microquadcopter X3 (Hubsan X4 clone), the X6 (a 250mm brushless quadcopter) and the X8, the largest model, a brushless 350 size including GPS, barometer and magnetometer. This review is dedicaced to the X8 model. After the success of the DJI phantom, a lot of 350mm quadcopters have emerged and prices decreased considerably in one year (WLtoys V303, Cheerson CX-20, Ideafly Appolo). Now you can find full model including Return To Home function, Hold altitude, Hold on position w/ GPS, automatic landing for around 300 USD. This X8 model is of course including such features: Hold position, RTH, automatic landing but also is returning some telemetry informations (Battery voltage, GPS informations, RSSI, etc.)
to the transmitter. The exhaustive features list (provided by Banggood)
+ Flight Control interation design, concentrated with gyroscope, balance meter, pressure meter
+ 3 flght modes,, 5 flying functions(attitude, hight, GPS, returning, AOC)
+ High precision GPS support, high precision fixed-point, constant speed, and with good resistance to wind.
+ High precision high, climbing at a constant speed, automatic landing , and with good resistance to wind.
+ Effectively enhance the flight safety and reduce drop probability by self-course reversal and hover when losing control.
+ Intelligent landing test, the power output will stop once landing --provide a perfect landing.
+ Low voltage protection, low voltage automatic landing, significantly prolong the service life of battery.
+ Automatical couse control, in spite the aeroplane heading.
+ Calibrating and starting flying with no use to contact the computer.
+ USB hub available, no diver required.
+ Flying log recording and playback, massive SD card ensured long data record.
+ Automatical firmware upgrading online
+ System one key recover
+ Flying area restrict, height and distance can be auto controllerd.
BOX CONTENT
+ 1 x Flying3D X8 (with a 161g 2200mAh 3S LiPo using a T-dean connector (no rated))
+ 1 x Transmitter (using 4xAA batteries not included)
+ 1 x Charger (using the balancer plug)
+ 4 x Props (2 CW, 2 CCW)
+ 1 x Instruction manual (English/chinese)
OVERVIEW
CHASSIS/SHELL
The size of this X8 is 34cmx27cm with ground clearance of 14cm when landing skid are installed. More precisely, distances motor are 26.5cm in x-axis .
and 25.5cm in y-axis
Be aware to not tighten too strong screws of the landing skid. The associated metal part jailing screws can pop out if you tighten too much them.
Without landing skid and props but with battery, the X8 is scaling 753.5g
Landing skid (14cm high) are scaling individually 41.3g
The GPS module is installed on the top canopy in order to reduce electronic interferences from the FC, RX and ESC.
The battery bay can be open by the rear door
A large space is available
The 2200mah 3S lipo dimensions are 100mmx34mmx22mm but the battery bay could probably welcome a battery up to 140mmx40mmx22mm. Max dimensions for the battery without modify 140mmx41mm X 23mm.
MOTORS
Motors are announced to be 900kV. No inscriptions permit to confirm this number
Shaft are 7mm
For the model I received, the screwing sens of the nuts locking props was identical to the motor'rotation (so 2 CW and 2 CCW). It means that you need to pay attention when you install props by screwing efficiently these screws.
See #228, screws are M3x9mm.
EDIT 10/20/14
Probably due to short screw's head, overtighting during assemblling and poor plastic quality of the top shell, some cracks in the plastic close to these screws (see #1431) will likely comes from motor's vibrations. These cracks can also be accentuated when the X8 is lifting a gimbal setup.
A solution would be to install some nylon washers/nuts on both side of the motor's mount to protect it and to raise motors a little to install easily any kind or 9" props or this fix item for the walkera 350QX pro
http://www.banggood.com/Walkera-QR-X350-RC-Quadcopter-Spare-Parts-Fixing-Board-QR-X350-Z-04-p-83877.html
Update 09/18/14
Motors are branded by Emax, probably some MT2213 935KV model
PROPELLERS
Props are some 8045 model
Update 09/23/14
According to some user's feedback, the 9045 props from the QX350pro can be installed, improving flight duration and payload capacity
http://www.banggood.com/Walkera-QR-X...-p-918375.html
QUAD CONNEXIONS
On the bottom surface, your can fin a micro-USB connector. Actually no CD or internet adress to pick up sofware was provided. When plugged to the computer, the OS is installing the device correctly but no more action. Probably this USB port can be use to upgrade FC F/W and set some parameters. You can find also some holes to screw a gimbal as as well as connector delivering +12V and connexion to a video camera and a gimbal. Gimbal screws are in M2 type
QUAD INTERIOR
To access in the interior of the X8, you will need to unscrew 20 screws
When pulling delicately the upper part, you can see ESC, the RX and the bottom par of the FC
ESC
I was not able to rate the ESC (no visible inscriptions )
Update 09/18/14
ESC are some Hobbywing rated 12A, probably "Skywalker-12A"
http://www.hobbywing.com/uploadfiles...W-SM003ENG.pdf
The power port and microUSB
RECEIVER
The latter seems to be a variant of the FlySky iA10 with a diversity system. The sensibility is announced to reach -105dBm.
According to the documentation, you can install any receiver of your choice but of course, you should loose telemetry informations if it's not a FlySky model. I will try to determine if the FC is accepting CPPM receiver (Or maybe, through the some OS configuration Tools if available)
FLIGHT CONTROLLER
Here a first snapshot of the FC
To have a more complete view, I would need to disconnect all wires. I will update this review with such photos
Actually I was not able to identify main chips used (MCU, GPS ? probably a Ubox Neo-6), especially if there are some hidden features such as a pathplanner.
Update 09/20/14
The FC is manufactured by "BigShark" (BS) compagny (http://bigflyshark.com/Home/Product/SharkX8#). In the final version of our FY-X8, the FC is the "X4" model from BS, a derivated product of their "X8" FC. The X4 don't have anymore the datalogger (but I am not sure that a SDcard can be connected, I have to investigate this point). Actually a special version of the Bigsshark ground station software is in beta release for our X8. In a future, release, mission planning will be probably added
My general impression of the quadcopter building is good. Wires are correctly installed, plastic and main body seems to be solid/robust to at least minor crashes.
CHARGEUR
Some users reported their LiPo died fast .... Maybe linked with the quality of the LiPo or the charger. AFAIK, all users using a real Professional charger didn't meet such problem
BATTERY
The battery is a 2200mah in 3S format rated 20C. The quality of this battery is not fantastic. After few charging cycle, some users noticed a big drop in performances and some had crashes due to major failure of the LiPo. I strongly advice to use a real model (Zippy compact, nanotech) with a real charger.
TRANSMITTER
The transmitter is derivated from the FlySky i6 model
except they installed 2x3 position switches (instead of 3x2 + 1x3) and limited the TX OS's functionalities (D/R rate and mixer are not available for example)
I am feeling that Flying3D is belonging indirectly to the FLySky compagny. The stick are very precise and for a RTF model, the quality of the transmitter is just great . The display is large and to access to the telemetry informations, you just need to press page up/down. If press more than 1s on the OK button you are entering into the setup. You can find for example a channel monitor.
The trainer port behind must be also be used to upgrade the TX os. So maybe, it would be able to upgrade this limited OS to return to the orignal FlySky one.
I have to check if this quadcopter is using the classic FlySky protocol and can be binded by another transmitter
Update : Unfortunatly, it's using a new protocol "2-ways" from FlySky
EDIT 11/07/14 : mode 1 to mode 2 / mode 2 to mode 1 procÚdures
https://www.rcgroups.com/forums/show...2#post29730118
Default TX settings
Go into Functions Setup
Go into your reversing settings and make sure that
Ch1 Nor
Ch2 Rev
Ch3Rev
Ch4,5,6,7 and 8 Nor
Then failsafe
Ch11 OFF
Ch12OFF
Ch13 100%
Ch14 OFF
Ch15 100%
Ch16 100%
Ch17 OFF
Ch18 OFF
Servo Freq is set to 50
Aux Channels
Channel1 7
Source Vra
Channel 1 8
Source Vrb
Also, go into system setup
Then Sticks Mode
Make sure it's in mode 2
CALIBRATE R/C TRANSMITTER/DRIFTING PROBLEMS:
When receiver is being connected, it requires calibrating the transmitter channel
throw and center point.
Calibration steps as followed (All channels must be set to 0 during calibration)
1. Turn on transmitter, push throttle to Max, all other sticks at center
2. Power on aircraft (receiver), wait for the yellow LED flashes
3. During the blue LED flashing, pull throttle to 0
4. Wait for the system to enter normal status
If unable to enter calibration mode, push throttle to reserves direction and repeat.
how to bind the Tx with Rx:
connect the bind-plug to the Tx marked port on the Rx and power up with the lipo connected, now keep pressing the BIND button on the Tx and turn on the Tx. now the red light on the Rx should stop blinking. unplug the lipo and turn off Tx. remove bind plug and close up the quad.
EDIT 10/16/14
The three alarms settings available in your TX have no influence on the quadcopter itselft (see videos in #2). These alarms are useful in the case where the receiver in powered standalone with a seperate LiPo. It's not the case here. The real voltage threshold concerning automatic landing must be tuned in the groundstation software.
Finally, the instruction manual is just awful ..... In chinese mainly but with some automatic translation (probably using google translate). So for me most of the sections are unreadable, especially the explanation of LED sequence where you can't determine LED colors in this black/white printed manual. Banggood have a version with a better english, but not all informations are present. For example, you can find Throttle calibration procedure only in the provided manual.
Notice, that my version didn't include the dataflight recorder. I don't know if it will like this for all shipped model (I asked to the BG manager)
CAUTIONS
Before to enjoy your X8 please be sure to check the following points
1) Props lock must be well tighten !!!!! Some users reported lost prop in flight because the props lock was not enought tight. The "swapping motors" mod helps to prevent this phenomena
2) ESC wires welding must be inspected. A user reported a crash due to bad ESC connexion in flight
3) Compass calibration must be done before the first flight!!!!! Especially if you want to engage RTH of GPS hold. No "flyaway" quad have been reported but can occurs if the compass calibration is not correctly done
4) Be aware with the charger. A user reported a dead LiPo after charging with the provided one. If you have a real charger (B6AC for ex), use it.
FIRST USAGE
The first time you are powering one the X8, first your need to turn on the transmitter than the X8. The first start-up seems to take close to 3-4 mm before to have this slowing flashing blue LED located at the back rear. When the GPS fixed at least one time, new GPS fixing takes only few seconds. When you are in the default flying mode (altitude), the rear LED is flashing slowly in blue.
The compass calibration must be performed at startup: Turn on TX then turn on the X8. press up/down (position 0 and 2) the left swith A fast several times and a fast green will flash designing the beginning of the compass calibration procedure. Take the quad horizontally in your hand and turn on yourself slowly at least 2 times. Then blue LED is flashing again. After take the quadcopter vertically, the front pointing the ground and turn on yourself as before at least 2 times. If everything is ok, the blue LED slowly flashing shoud restart. Maybe the rear LED should be bigger to see quad status from longer distances.
By default, the flying mode is altitude/state one. Here is the provided list of the Flight modes
Switch A
- Attitude mode is the manual mode with autoleveling, the equivalent of the "Horizon" mode for Multiwii
- Altitude mode is allowing you to keep the same altitude if your throttle stick is set at 50%. If you decreasing throttle, you are descending, otherwise, your are ascending
- GPS mode force the quad to lock its position if sticks are centralized.
Switch B
- RTH mode need to be also in GPS mode. Before engaging RTH, the quad is delaying maneouver 3s (the time to desengage RTH) . The quad is climbing at 5m high if the current altitude was lower then return to home.
BE AWARE, ONLY YAW COMMAND ARE NOT IMPACTING RTH. IF YOU PLAY WITH THROTTLE, YOU CAN QUIT RTH MODE
-The "AOC" is the headless function.
Actually I mainly tested the first altitude/state mode and also abit the GPS mode.
To arm the quadcopter, you can for example push both sticks either full lower-left position or full lower-right or one lower-left the other lower-right. When the props starts to sping immediatly release stick and start to push throttle. If you keep the start-up position, the props will stop 3s later.
I was positively surprized by the velocity of the quadcopter in this mode. You can feel a lot of power, probably because no gimbals are installed.
Telemetry informations can be read on the TX OSD and it's a great feature. For example, you have access to the last GPS coordinates (in case of crash, it's a nice option).
GPS locking altitude seems to working well to. For the first flight, the flying duration was something under 10mm.... but I performed a lot of take-off and it was remaining 30% of battery.
Notice that the low-voltage warning started to appear around 30% of capacity. In the manual (fast sequence of red light flashing ending by 2 normal blue ones), it's written than this value can be changed in the "debugging sofware".... Actually, I don't where to find this software (almost no information available on their website).
I have to test the RTH function but for this quick test, to many trees around and in case of RTH, the quadcopter will first reach 15m high before landing as indicated in the documentation (even if he was below). More to come
EDIT 10/27/14
After many week of usage, the FY-X8 is definitively a sportive and agile flyer well equilibrated. Thanks to the ground station sofware, you can now also tune all flight caracteristics. In another hand, you MUST immediatly install some washers (both side of the motor holder) as well as longer M3 screws (14-16mm) to
i) Avoid/delayed plastic cracks nearby screws holding motors
ii) Install larger props size
CONCLUSIONS
Here are my first prelimary conclusions. I am impressed by the general design of the X8 especially for less than 300 USD (actually at BG.) I really appreciate the presence of the telemetry informations displayed on the TX. The is a very good pro point.
The TX is a great model for a such cheap RTF 350 sizel. The X8 seems to be a really good flyer, I like it, I found it quiet agile in the altitude mode. The X8 is also very stable (even if I didn't find yet the gyroscope calibration procedure). In another hand, you MUST immediatly install some washers (both side of the motor holder) as well as longer M3 screws (see above)
UNBOXING
Flying3D X8 Unboxing (Courtesy of Banggood) (11 min 4 sec)
preliminary pros/cons points
PROS
+ Very fast
+ RTH
+ Automatic landing (via the RTH button or when voltage is below the alarm threshold)
+ Telemetry information displayed on the LCD
+ Announced to have 1km of control range (to be verify)
+ Great TX included in the Bundle
+ Any (CPPM) receiver can be installed (Telemetry can be lost in this case)
+ Excellent deal for 290 280 290USD
+ DJI phantom 8045 can be installed. Some 9045 after installing a washer to raise motors
CONS
- Horrible instruction manual
- Nuts for Prop'locker (same sens that the motor rotation), see video section in #2 to fix this problem Fixed with final batch
- Bushing bronze screws easily poping out of the shell's plastic. You need to reglue them with CA
- No dataflight recorder included despite advertising (with my provided version at least, to be precise later).
- No spare parts available (yet) All parts are available now
- Approximatively 10mm of flying duration (with the shipped 2200mAh Lipo). Tje quality of the shipped LiPo is not fantastic. The LiPo can be killed with the shipped charger. Please use a real charger.
- 9043 props can't be installed (touching canopy) The QX 350 pro 9045 can be installed directly, other 9 " need some washers to raise motors of few mm
- Potential bad ESC wiring/welding(happened for 1 user). Must be checked before the first flight
- Potential overtighten motor's screws introducing some cracks in the shell' plastic part (see #1431). Need to be fixed with washer!!
- Poor quality of the shipped Lipo. Diying fast (~10-20 cycles). Must be changed fast if you don't want to you quad falling by a major failure of your LiPo
Ground station software drivers for Windows
http://www.silabs.com/products/mcu/p...cpdrivers.aspx
For Win8 users, run it in admistrative mode and XP comptability
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 285 USD at Flying3D X8
EDIT 12/08/14: +Add STL file for FY-X8 spacers (3D printer)
EDIT 10/21/14: +Add V1.22 ground station sofware
EDIT 08/01/14 : +Attached scanned manual (in 2 parts) and the link to the BG version of the manual
http://imgmgr.banggood.com/images/up...r%20Manual.pdf
+ Add new photo showing FC environnement
+ Typos corrections + some minor text improvements
Jul 31, 2014, 05:07 PM
SeByDocKy's Avatar
Reserved for mods, photos and videos
MODS
-Range increasement (Thx to kikymad)
By installing 2 uFL to RP-SMA cable (15cm). You will need uninstall the two internal antennas, drill two hole to install the RP-SMA connectors
http://www.banggood.com/50cm-U_FLIPX-to-RP-SMA-Female-Antenna-Pigtail-Jumper-Cable-p-924946.html
VIDEOS
+ Compass calibration
Flying3D X8 compass calibration procedure (Courtesy of Banggood) (3 min 57 sec)
+ Motor's swapping
Flying3D X8 "motors swapping" tutorial (Courtesy of Banggood) (56 min 38 sec)
+ Fix the RX voltage/per cell alarms to lower values
Flying3D X8 setting RX voltage (Courtesy of Banggood) (1 min 46 sec)
+ Binding procedure between RX&TX
Flying3D X8 binding procedure tutorial (3 min 56 sec)
+ Bind switch mod
00192 (2 min 46 sec)
+ Ground station software overview
Flying3D X8 ground station software demo (7 min 35 sec)
+ HDOP measurement (Horizontal hold on precizion)
Flying3D X8 HDOP measurement (Courtesy of Banggood) (0 min 43 sec)
+ State/altitude flight mode illustration
Flying3D X8 first flight in altitude mode (Courtesy of Banggood) (4 min 49 sec)
+GPS hold on illustration
Flying3D X8 Hold on GPS illustration (Courtesy of Banggood) (2 min 23 sec)
+ Return to Home illustration
Flying3D X8 Return to Home Demo (Courtesy of Banggood) (3 min 35 sec)
+ Plastic G-2D Walkera gimbal installation for the FY-X8
Plastic G-2D installation for FY-X8 (Courtesy Banggood) (12 min 7 sec)
+ FY-X8 with the plastic G-2D Walkera gimbal
Flying3D X8 Monstertronic Invader Testflight with Walkera Gimbal G2D & Easypix GoXtreme WiFi (7 min 12 sec)
see post #1379 for gimbal installation
+ Flying3D Rx Battery Alarm
Flying3D Rx Battery Alarm (1 min 45 sec)
+ Flying3D LowBat Test
Flying3D LowBat Test (1 min 30 sec)
PHOTOS
Transmitter : Mode 2 to mode 1/ mode 1 to mode 2
https://www.rcgroups.com/forums/show...postcount=1482
(Thanks to kikymad )
Arms
Gimbal fixation
Battery
A 3S LiPo 2200mAh rated 20C
Motor's screws
SPARE PARTS
Upper-Body-Shell-Cover - $24.87
http://www.banggood.com/Flying-3D-X8...105842201212FR
Bottom Body Shell - $25.00
Receiver - $38.29
Lipo-Battery - $25.23
Landing Gear - $11.50
Tail Cover - $7.32
Bronze Bushings - $4.91
Bodyshell screws - $4
Motor screws - $3.5
Cushions/rubber feet - $3.65
http://www.banggood.com/Flying-3D-FY...105842201212FR
Charger - $11
Transmitter - $44.98
GPS cover - $5.21
GPS circuit board - $46.73
Motors - $14.48
Ballbearings : 3mm x 8mm x 4mm (Inner Diameter x Outter Diameter x Width )
ESC - $13.81
Flight controller board - $88.65
Motor caps - $2.65
Compatible model - 6USD
http://www.amazon.com/Aluminum-Alloy...iglink20264-20
Compatible propellers
a) Genuine 8045 props - *5.58
b) 8045 props from DJI phantom - $8.82
http://www.banggood.com/DJI-PHANTOM-...105842201212FR
c) 9045 props from QX 350 Pro - $10
http://www.banggood.com/Walkera-QR-X...105842201212FR
Jul 31, 2014, 06:15 PM
wilcamach's Avatar
nice vids cant wait to see some onboard flight videos. I like what i see so far
Jul 31, 2014, 10:26 PM
Multirotor Builder!!!!!
Very nice. I might have to get one of these. How is the GPS hold on it. and the RTH how accurate is it.
Jul 31, 2014, 10:58 PM
That telemetry function is really a huge plus. No more confusing light blip on the quad to read its status because you can read them directly on the TX. I can't clearly see the TX lcd, wondering how accurate the distance and altitude reading is.
The motors have two rotational direction. Did the props lock go in one direction or both. I mean, you turn the screw both clockwise and counter-clockwise according to props direction or just clockwise on all props like normal screw?
Jul 31, 2014, 11:05 PM
The motors look to be E-max motors which are pretty good motors. also here is the flying 3d website. http://en.flying3d.cn/goods.php?id=60
and here is something interesting. here is a pic of the flight controller that should be in the copter and it has the SD card in it.
also on there site there is no where to download any firmware or software.
Aug 01, 2014, 12:18 AM
SeByDocKy's Avatar
The accuracy is tenth in meter and tenth is m/s
2 motors have props lock CW and 2 motors CCW and unfortunatly, on mine (I asked BG manager to confirm), when a props lock is CW, the motor is also CW and so on ....
Aug 01, 2014, 12:21 AM
SeByDocKy's Avatar
Yes .... but when I started to disassemble it, I didn't see such box. All FC electronic can be find beneath this green PCB. I have to disconnect all connector to fully access to it and there are a lot of cable . So first I want to do some videos before completly make the autopsy
Aug 01, 2014, 12:23 AM
SeByDocKy's Avatar
I just activated one the GPS hold on.... I should have a small piece of video. I will upload it. For me it's seems to be very accurate. There is no reason that RTH won't benefit of such precision
Aug 01, 2014, 02:59 AM
SeByDocKy's Avatar
I added a small new video illustrating the GPS hold on function. For me is not very clear I how to use it but it's working well
Aug 01, 2014, 09:05 PM
SeByDocKy's Avatar
Do you have the exact reference of this E-max motor ?. They seems to be very similar to the V303's motors too .
Aug 01, 2014, 09:12 PM
a lot of these companies use the same motors. like the CX-20 or Nova from HK they use the same motors as the DJI phantom and I mean they are exactly the same. LOL. I will try to find the reference for the e-max motors.
Aug 02, 2014, 07:39 AM
One of the reasons I ordered this quad is that the motors in my V303 are vibrating. Also, one of the prop shafts is a tiny bit bigger than the others, so fitting a prop is difficult.
Hopefully the new X8 will remedy this. Even a decent and well programmed FC cannot hold a shaking quad as well as it should. Maybe I will buy new motors for the V303 (sorry the offtopic) or more likely, if the new X8 is better, I will fly it happily and forget my "first step" in AP quads...
Aug 03, 2014, 07:38 AM
Still not spare parts... risky bussines XD
I bought one :P
Aug 03, 2014, 01:47 PM
SeByDocKy's Avatar
I bought one :P
I will ask when they will be available
