May 13, 2019, 08:26 AM
SebastianG.'s Avatar
Hi there,
This will be my first plane since a couple of years... so be patient this is going to be a slow build.
Cheers Sebastian
May 13, 2019, 10:16 AM
robertus's Avatar
Hi Sebastian
I keep my fingers crossed for your success.
May 13, 2019, 10:31 AM
Thanks.
Did i miss something in the plans or are the ailerons not shown in the wing pdf ?
May 13, 2019, 11:13 AM
robertus's Avatar
There is nothing wrong with your eyes There are no ailerons in the pdf.
To be honest you are first person that noticed it.
You can cut any size you want. Mine ailerons are 50mm x 250mm.
May 13, 2019, 11:28 AM
Okidoki!
May 19, 2019, 08:33 AM
Just another question.... for your canopy... did you used a simple 3 side view of the original canopy and sanded it in shape or did you fold the foam in shape?
May 19, 2019, 09:47 AM
robertus's Avatar
Canopy is from SIG: part number is SIGWC811
My foam canopy was only temporary and i cut it ad hoc. No plans for it.
Try to use those.
May 30, 2019, 03:37 PM
Ok, as i told you... this will be a slowbuild..
I installed a 68mm EDF, some LED‘s and Servos to the wing
Jun 13, 2019, 07:13 AM
Cg
Almost complete .... working on the battery placement and compartment. What is the recommended CG on this plane?
Jun 13, 2019, 09:49 AM
robertus's Avatar
CoG is 115mm from the leading edge, next to fuselage
Jun 15, 2019, 08:30 AM
Thank you much!
Jun 21, 2019, 12:43 PM
All finished, hoping for some decent weather to maiden this fine bird.
Jun 21, 2019, 01:01 PM
robertus's Avatar
Don't forget about mix throttle to elevator.
