Dec 19, 2014, 05:09 PM
Tri-Quad-Hexa-Octo-copters!!
Hi P,
In the Vision Assistant application, while connected to your Phantom, select the Basic/RC and then select the Upgrade Version. You will have pitch gimbal control with your lever if fitted. Note that it is set for the thmbwheel type of operation with a center spring so any movement from the lever's center will start the gimbal moving up or down until it is re-centered. You should also calibrate your X1 lever and Tx while on that page.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by pitcher8811
Thanks for the info Mako. Mine only took about 2 minutes to calibrate and gave me the temp warning 3/4 of the way through.
I haven't gotten a chance to fly it yet, but so far everything looks good. Has anyone found a way of getting X1 tilt control while in the Vision App?
Dec 20, 2014, 01:15 AM
Anyone want to lay out a step by step Parts and wiring diagram for us ADD dummies?
I can solder, read, clip and crimp and use a volt meter.
Dec 20, 2014, 12:33 PM
Here are some diagrams. One shows the stock wiring, and the other shows how it should be connected with the H3-3D. The only extra thing you will need is a long, 8 pin gimbal ribbon cable from a Phantom 2. You can order it online as a replacement part.
Dec 20, 2014, 12:37 PM
Originally Posted by jesolins
Hi P,
Cheers,
Jim
Thanks Jim! I knew I read something like that somewhere on this thread, but I couldn't find it again. I probably passed it up 2-3 times.
Dec 20, 2014, 04:09 PM
Finally got a flight in with the H3-3D. It was great! My next project will be finding a control knob that will return to center for gimbal control. After that, I may play around with an arduino and try to find a way to take pictures and video.
Dec 21, 2014, 11:31 AM
Will my new controller with the gimbal rotary switch work?
Dec 21, 2014, 11:39 AM
Also, is this the cable?
DJI Phantom 2 Quadcopter FPV Wireless Video Transmitter Signal Connection 8-Pin Cable 300mm Gray for Zenmuse H3-2D Z15 Gimbal https://www.amazon.com/dp/B00NIRT8O6..._iEVLub1YM8Q6B
THANK YOU FOR your help.
Dec 21, 2014, 12:06 PM
Hi D,
Yes.
Yes.
Cheers,
Jim
Dec 21, 2014, 12:41 PM
K. Now if I can find one shipped from U.S and not China I'll be cooking. Tha k yall so much. Going to buy a hero 4.
Ooops. One more thing. That cable says for HD-2D does it also work for HD-3D? Sorry for all the questions. You guys kick ass
Dec 21, 2014, 12:46 PM
I got mine shipped from China, and it was fine. I ordered through Helipal and got a cable pack that included a spare compass cable and CAN bus cable. It took ten business days in total from when I ordered it to when I received it.
Dec 21, 2014, 01:46 PM
Ok. Will I have to modify the p2v+ belly When I mount my HD-3D gimbal? I have read the opening is smaller.
Dec 22, 2014, 03:21 PM
It depends. Some of the earlier models had a slightly different opening on the bottom. If you have a rounded opening like the one in the picture below, it should fit just fine. If it is the rectangular version below, modification will be needed.
Dec 22, 2014, 09:42 PM
Sweet! Thanks
Dec 23, 2014, 09:36 AM
Sweet! Thanks
You're welcome!
Dec 23, 2014, 10:40 AM
Fail
Hello guys i have finally received a new range extender so i was ready to go test everything out. So.....
GPS Locked quite fast. Transmitter seems to be working fine. Telemetry and video look ok in the app but i have a HUGE SHAKE on my GLB Gimbal when flying.
Any ideas?
It has 2.40b7 GUI.
