Mar 13, 2019, 03:38 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
HS-7954SHs are fine. I had them in my 'Big Foot' with no problems.
SteveT.
Latest blog entry: My shop....
Mar 13, 2019, 09:37 PM
FloBau's Avatar
I didn't like their torque and precision.
But at the end it's often about general trust and I nearly only use Sav÷x servos now.
Jun 12, 2019, 08:56 AM
royalstar05's Avatar
extreme flight mxs 76"
I do know this is one size down but help you guys can help I just bought a crashed MXS and need a little help the plane had the ball link pushrod removed from it can you tell me what length ball link and rods I need
Thank you
Jun 12, 2019, 12:59 PM
SteveT.'s Avatar
Which ball link push rod? Aileron or elevator? Or both?
SteveT.
Jun 13, 2019, 07:14 AM
both please
Jun 13, 2019, 09:51 AM
I am not a robot
Sideslip's Avatar
With the Elevator it depends on how the servos are installed. If they are installed with the output shaft toward the hinge line (as mine are) then you would need approximately 72mm, as shown in the photo. If they are installed with the output shaft away from the hinge line you would need a longer turnbuckle. As it turns out Lunsford doesn't make a 72mm only 73mm which should work fine. At any rate, I use the 3mm Punisher Turnbuckles in the proper length.
You may also want a turnbuckle wrench which is shown in the last link below. The wrench for the Punisher Turnbuckles is the one on the left side of the page.
The Ailerons are pretty simple. They should be installed with the output shaft toward the hinge line and the turnbuckles should be approximately 52mm. But as you can see, I took a measurement from the center of the ball link barrel, which could be different from your ball links and that would effect the length of turnbuckle needed. I suggest you get Lunsford titanium turnbuckles as shown in the links below. I also like Secraft ball-links as shown in the link below.
If I were you I would install the ball links and take the same measurements that I did, and then order the correct length that you need. Although the numbers I posted are probably good for most ball links. Installation of the control surface horns could also alter the length needed.
Best of luck with it,
Bert
https://www.f3aunlimited.com/secraft...ty-10-aluminum
https://lunsfordracing.com/products/...=7291690614841
https://lunsfordracing.com/products/...=7743400443961
https://lunsfordracing.com/collections/tools/tools.
EDIT: BTW, the 76" MXS is the same aircraft as the 83". Only difference would be the tips installed on the 83 and not on the 76.
Jun 13, 2019, 10:10 AM
Thank you very much you have been a big help
Jun 18, 2019, 08:43 AM
Sideslip thanks I checked out the Punisher Turnbuckles you listed question why is there 2 different turnbuckle links
they had both a 52mm and 73mm
thanks again for the help
Jun 18, 2019, 08:51 AM
I am not a robot
Sideslip's Avatar
One linked to the 52s and one for the 73. Look closely and you'll see the part numbers are different on each page. Hope they work out well for you. I really like 'em and some of the EF planes come with them now.
Jun 26, 2019, 11:15 AM
What size pilot are you guys putting in the MXS
Jun 26, 2019, 05:53 PM
iumop ap!sdn w,I
G.P.'s Avatar
25% G-force pilot:
Latest blog entry: Canola Huckin'
Jul 05, 2019, 07:47 AM
Now I'm a "Low Flyer"
high flyer Rich's Avatar
The GForce pilot looks very sharp! Another option that is lighter and less expensive is the PilotX from EF.
https://extremeflightrc.com/Pilot-X-...ow_p_1982.html
Jul 05, 2019, 08:01 AM
I am not a robot
Sideslip's Avatar
Yup and the Pilot X weigh about half as much as a G-Force pilot.
Jul 05, 2019, 11:27 AM
They Call him Dead!
YellowJacketsRC's Avatar
How does that Plane hanging system you have there work? Do you have to get on a ladder to hang it and take it down?
Jul 05, 2019, 01:21 PM
SteveT.'s Avatar
He does an inverted harrier into position..kind of like the early vertical take off jets..
SteveT.
