Cool! Looking for a fan for my F-100. I am looking for 17-18lbs at 110-115amps on12s which looks to be very doable with this fan with the right motor.
man, thats impressive!
going to sell like hot cakes |
This might be able with the right motor and cells, even 22lbs coulb be done! Rainer www.ejets.at team@ejets.at |
Shaft size 8mm
Hi,
we are doing 8mm chuck type collet, even that our rotor system complete with spinner is around 145 Gramms only, we want to have the security of an solid 8mm axle. No flat spots allowed, the chuck type collet can handle different diameters of 8,00 to 7,90, but needs fully round axles. BR Rainer |
Great, so all I need is a rotor <g>. When can I order ...
My Starfire currently has a DS-94, 12S, 1527/1.5Y. I'd love to swap out the rotor. Quote:
These are awesome numbers!!
Batteries are going to be nice and cool. With these numbers flight times are going to go up. Wow, cannot wait to get a few of these for my models. They already fly well, but with power and efficiency well they are going to be that much more fun to fly!
Latest blog entry: The "Six" Delta Dart
Paul |
Our shroud is XXL inside, to get this dammed 51mm outrunners fitting without an extension, that was the target! No idea if this motors will fit exactly with their KV's, but there is also a company in Germany which can "rewind" this motors for higher power and other KV's. Also the SK3-Helidrive 530 will fit, now we have to tell them to use fully 8mm axles. Normaly they have 8mm inside, and outside turned down to 6mm, with a flat spot. Or we can get someone to make jackets from 6mm to 8mm, ready to be shrinked on the axles. I dont want to make extra 6mm chuck collet type adapters also. If yes, theres still a flat spot on this 6mm axles, always a pain in the .. Rainer |
We got around 6,2 Kilos of thrust with 12s and around 75Amps with the HET-800-58-530KV And as posted 7 kilos on 12s and around 93 Amps with the HET-800-73-590, But please excuse that we have not tested the Neu 1527 1.5y with 825KV yet. Could be good for 10 - 12 s, but has to be improved, Rainer |
I'll need get a fan when they are available. Thanks! Bob |
Paul |
Thread Tools | |
Similar Threads | |||||
Wanted | Jetfan 120 ECO | F7X | Aircraft - Electric - Jets (FS/W) | 0 | Oct 28, 2016 08:36 PM |
Sold | JetFan 120 ECO Pair with HET 800-60-535 | Air-Jon | Aircraft - Electric - Jets (FS/W) | 5 | Oct 19, 2016 09:26 AM |
Discussion | Jetfan 120 exhaust diameter | baykah | Large EDF Jets | 11 | Oct 17, 2016 02:13 PM |
Wanted | Jetfan 90 and Jetfan 120/120eco fan units only | reaper60 | Aircraft - Electric - Jets (FS/W) | 2 | Apr 03, 2016 04:19 AM |
Sold | Jetfan 120 heat sinks, | Air-Jon | Aircraft - Electric - Jets (FS/W) | 1 | Jan 05, 2016 05:43 AM |
