Index of Tips, Tools and Techniques - RC Groups
This thread is privately moderated by Steve85, who may elect to delete unwanted replies.
Jul 02, 2014, 12:38 PM
Summit Model Aeronautics
Steve85's Avatar
Link
There's a real wealth of tips, tools and techniques here on RC Groups and elsewhere, and it seems I stumble on one almost every day. Trying to find them again when I need them is another story, even with browser bookmarking. Happily, there are a few compendium threads that allow folks to post their best tips, tools and techniques, but again, searching them can be frustrating.
As an attempt to make the many tips, tools and techniques described on RC Groups and elsewhere more readily available, I've started to compile the following index of links. So far, I've gone through the “Best Building Tip You Ever Got” and “The Tools Money Can't Buy” threads (up in the Scale Kt/Scratch Built forum) and extracted the good stuff, and included material from elsewhere on the web as well. It's just a start though, so if you see a useful tip, tool or technique while browsing, please post the link here and I'll roll it into the index.
To make it easier to keep track of additions, I'll post new tips in red font for a week or so after they've been added.
Happy building!
Steve
Steve85's Avatar
Plan and Construction Techniques
Working with Plans
Transferring plans to balsa:
https://www.rcgroups.com/forums/show...&postcount=120
https://www.rcgroups.com/forums/show...&postcount=657
Making a mirror image of plans:
https://www.rcgroups.com/forums/show...postcount=1195
https://www.rcgroups.com/forums/show...postcount=1196
Glue techniques:
https://www.rcgroups.com/forums/show...8&postcount=36
https://www.rcgroups.com/forums/show...4&postcount=40
https://www.rcgroups.com/forums/show...6&postcount=52
https://www.rcgroups.com/forums/show...&postcount=251
https://www.rcgroups.com/forums/show...&postcount=382
https://www.rcgroups.com/forums/show...&postcount=428
https://www.rcgroups.com/forums/show...&postcount=441
https://www.rcgroups.com/forums/show...&postcount=461
https://www.rcgroups.com/forums/show...&postcount=701
https://www.rcgroups.com/forums/show...&postcount=730
https://www.rcgroups.com/forums/show...&postcount=954
https://www.rcgroups.com/forums/show...postcount=1017
https://www.rcgroups.com/forums/show...postcount=1391
https://www.rcgroups.com/forums/show...postcount=1419
Cutting techniques:
https://www.rcgroups.com/forums/show...&postcount=429
https://www.rcgroups.com/forums/show...postcount=1252
Pins and pinning:
http://pldaniels.com/flying/balsa/ba...g-methods.html
https://www.rcgroups.com/forums/show...&postcount=134
https://www.rcgroups.com/forums/show...postcount=1422
https://www.rcgroups.com/forums/show...postcount=1431
https://www.rcgroups.com/forums/show...postcount=1448
Stick-and-tissue construction techniques:
http://patscustom-models.com/basics_...ck_framing.htm
http://web.archive.org/web/200806211.../fast_fuse.htm
https://www.rcgroups.com/forums/show...0&postcount=43
Making laminated/bowed wingtip and tail surface outlines:
http://patscustom-models.com/Bowed%20Outlines.htm
Drilling neat holes in balsa and foam:
https://www.rcgroups.com/forums/show...1&postcount=31
https://www.rcgroups.com/forums/show...39&postcount=2
Balsa sheeting techniques:
https://www.rcgroups.com/forums/show...&postcount=124
https://www.rcgroups.com/forums/show...&postcount=331
https://www.rcgroups.com/forums/show....php?t=2300058
Adding gussets:
https://www.rcgroups.com/forums/show...5&postcount=52
https://www.rcgroups.com/forums/show...postcount=1081
Depron construction techniques:
https://www.rcgroups.com/forums/showthread.php?t=380552
Cutting foam:
https://www.rcgroups.com/forums/show...8&postcount=81
https://www.rcgroups.com/forums/show...&postcount=108
https://www.rcgroups.com/forums/show...postcount=1143
Controlling foam sanding dust:
https://www.rcgroups.com/forums/show...&postcount=271
Wing attachment techniques:
https://www.rcgroups.com/forums/show...&postcount=508
Wing attachment technique for biplanes:
http://www.ffscale.co.uk/page4b.htm
Squaring tail surfaces:
https://www.rcgroups.com/forums/show...&postcount=157
Hinge techniques:
https://www.rcgroups.com/forums/show...&postcount=932
https://www.rcgroups.com/forums/show...&postcount=937
https://www.rcgroups.com/forums/show...postcount=1290
https://www.rcgroups.com/forums/show...postcount=1403
Threading cables and wire through structure:
https://www.rcgroups.com/forums/show...2&postcount=35
https://www.rcgroups.com/forums/show...postcount=1406
Pull-pull control surfaces:
https://www.rcgroups.com/forums/show...6&postcount=75
https://www.rcgroups.com/forums/show...postcount=1059
Wheel retention:
https://www.rcgroups.com/forums/show...&postcount=365
https://www.rcgroups.com/forums/show...&postcount=401
http://patscustom-models.com/Hidden%...0Retainers.htm
Windshields and cabin windows:
http://www.afterburnerforum.com/view...=107&t=55#p108
http://patscustom-models.com/Windshield%20Pattern.htm
https://www.rcgroups.com/forums/show...&postcount=352
Making cockpit coamings for open cockpits:
https://www.rcgroups.com/forums/show...94&postcount=6
Cowl alignment:
http://patscustom-models.com/cowl_alignment.htm
Assembling wheel pants:
http://patscustom-models.com/assembl...el%20Pants.htm
Wire landing gear :
http://patscustom-models.com/buildin...nding_gear.htm
Shaping tail fairing blocks:
http://patscustom-models.com/tail_fairing_blocks.htm
Shaping wing leading edges:
https://www.rcgroups.com/forums/show...39&postcount=9
Cabane struts:
http://patscustom-models.com/solderi...ane_struts.htm
Making scarf joints :
http://patscustom-models.com/Scarf%20Joints.htm
Making paper fairings:
http://patscustom-models.com/Paper%20Fairings.htm
Motor mounting techniques:
https://www.rcgroups.com/forums/show...&postcount=633
https://www.rcgroups.com/forums/show...postcount=1182
Making custom spinners:
https://www.rcgroups.com/forums/show...0&postcount=45
Jul 02, 2014, 12:40 PM
Steve85's Avatar
Reserved for Future Use...
Steve85's Avatar
Advanced Construction Tips and Techniques
Vacuum Forming and Thermoplastic Techniques
Canopy molds for vacuum forming:
https://www.rcgroups.com/forums/showthread.php?t=489215
https://www.rcgroups.com/forums/show....php?t=1377161
Making plugs for vacuum forming:
https://www.rcgroups.com/forums/show...&postcount=106
Plunge forming canopies:
http://www.ffscale.co.uk/page4f.htm
Forming canopies with a heat gun:
http://www.ffscale.co.uk/page4g.htm
Fiberglass and Composite Techniques
Glassing with water-based polyurethane (WBPU):
http://pldaniels.com/flying/balsa/fi...yurethane.html
Covering Techniques
Iron-on coverings:
https://www.rcgroups.com/forums/showthread.php?t=711624
https://www.rcgroups.com/forums/show...6&postcount=83
https://www.rcgroups.com/forums/show...postcount=1370
Covering with tissue:
http://www.easybuiltmodels.com/Notes_on_tissuing.pdf
Summary of using EZEDope for tissue coverings:
https://www.rcgroups.com/forums/show...9&postcount=43
Entire EZEDope trial thread:
https://www.rcgroups.com/forums/show....php?t=1920210
Painting and Finishing Techniques
Scale paint techniques:
https://www.rcgroups.com/forums/show....php?t=2392790
Painting, panel lines and weathering;
https://www.rcgroups.com/forums/show...t=161218&pp=15
Finishing sheet balsa:
https://www.rcgroups.com/forums/show...&postcount=207
Paint masking techniques:
https://www.rcgroups.com/forums/show...9&postcount=29
https://www.rcgroups.com/forums/show...&postcount=609
https://www.rcgroups.com/forums/show...postcount=1115
http://www.ffscale.co.uk/page4a.htm
https://www.rcgroups.com/forums/show...&postcount=554
Airbrushing techniques:
https://www.rcgroups.com/forums/show...6&postcount=92
Homemade sanding sealer:
https://www.rcgroups.com/forums/show...&postcount=343
Painting Litefilm :
http://patscustom-models.com/Painting%20Litefilm.htm
Painting scale propellers :
http://patscustom-models.com/paintin...propellers.htm
Printing on tissue :
http://www.parmodels.com/Printing%20..._on_tissue.htm
Printing WWI lozenge patterns on tissue:
http://www.ffscale.co.uk/page4e.htm
Jul 02, 2014, 12:41 PM
Steve85's Avatar
Workshop Techniques, Fleet Management and Tools
Workshop Techniques
Safety:
https://www.rcgroups.com/forums/show...postcount=1116
Not losing small parts:
https://www.rcgroups.com/forums/show...&postcount=285
Storing CA:
https://www.rcgroups.com/forums/show...2&postcount=44
Soldering:
https://www.rcgroups.com/forums/show...postcount=1086
https://www.rcgroups.com/forums/show...postcount=1449
Storage solutions:
https://www.rcgroups.com/forums/show...&postcount=224
https://www.rcgroups.com/forums/show...&postcount=457
https://www.rcgroups.com/forums/show...postcount=1203
Fleet Maintenance & Management
Balancing:
https://www.rcgroups.com/forums/show...postcount=1175
Checking wing washout:
https://www.rcgroups.com/forums/show...&postcount=113
Preventing hangar rash:
https://www.rcgroups.com/forums/show...4&postcount=37
https://www.rcgroups.com/forums/show...&postcount=219
Battery management and charging:
https://www.rcgroups.com/forums/show...&postcount=107
https://www.rcgroups.com/forums/show...&postcount=162
https://www.rcgroups.com/forums/show...&postcount=505
https://www.rcgroups.com/forums/show...&postcount=539
https://www.rcgroups.com/forums/show...postcount=1438
https://www.rcgroups.com/forums/show...postcount=1439
Repair techniques:
https://www.rcgroups.com/forums/show...&postcount=477
Tools
Building boards:
https://www.rcgroups.com/forums/show...&postcount=152
https://www.rcgroups.com/forums/show...&postcount=112
https://www.rcgroups.com/forums/show...&postcount=193
Cutting tools:
https://www.rcgroups.com/forums/show...&postcount=183
https://www.rcgroups.com/forums/show...&postcount=192
https://www.rcgroups.com/forums/show...postcount=1154
Balsa/spruce strippers:
https://www.rcgroups.com/forums/show...&postcount=244
https://www.rcgroups.com/forums/show...6&postcount=18
https://www.rcgroups.com/forums/show...&postcount=375
http://www.railroad-line.com/forum/t...TOPIC_ID=20046
https://www.rcgroups.com/forums/show...&postcount=389
https://www.rcgroups.com/forums/show...4&postcount=12
Gusset cutter:
https://www.rcgroups.com/forums/show...&postcount=272
Hinge slot cutter:
https://www.rcgroups.com/forums/show...59&postcount=3
https://www.rcgroups.com/forums/show...8&postcount=50
Foam slot cutter:
https://www.rcgroups.com/forums/show...postcount=1338
Triangle stock cutter:
https://www.rcgroups.com/forums/show...3&postcount=14
Notch cutter:
https://www.rcgroups.com/forums/show...0&postcount=30
https://www.rcgroups.com/forums/show...2&postcount=40
Simple gouges:
https://www.rcgroups.com/forums/show...26&postcount=8
Glue tools:
https://www.rcgroups.com/forums/show...&postcount=358
https://www.rcgroups.com/forums/show...&postcount=144
CA applicators:
https://www.rcgroups.com/forums/show...1&postcount=34
https://www.rcgroups.com/forums/show...8&postcount=38
https://www.rcgroups.com/forums/show...&postcount=258
Sanding tools:
https://www.rcgroups.com/forums/show...&postcount=182
https://www.rcgroups.com/forums/show...&postcount=225
https://www.rcgroups.com/forums/show...&postcount=288
https://www.rcgroups.com/forums/show...&postcount=240
https://www.rcgroups.com/forums/show...&postcount=689
https://www.rcgroups.com/forums/show...postcount=1274
https://www.rcgroups.com/forums/show...postcount=1275
Jigs and fixtures:
https://www.rcgroups.com/forums/show...65&postcount=1
https://www.rcgroups.com/forums/show...postcount=1137
https://www.rcgroups.com/forums/show...postcount=1164
Biplane wing incidence jig:
https://www.rcgroups.com/forums/show...&postcount=317
Tool caddies:
https://www.rcgroups.com/forums/show...&postcount=100
https://www.rcgroups.com/forums/show...&postcount=213
Paint caddy:
https://www.rcgroups.com/forums/show...1&postcount=53
Angle gauges:
https://www.rcgroups.com/forums/show...5&postcount=39
Clamps:
https://www.rcgroups.com/forums/show...&postcount=684
Airbrush paint viscosity gauge:
https://www.rcgroups.com/forums/show...2&postcount=60
Epoxy resin roller:
https://www.rcgroups.com/forums/show...&postcount=434
Marking tools:
https://www.rcgroups.com/forums/show...&postcount=395
Homemade tool marking:
https://www.rcgroups.com/forums/show...&postcount=188
Wire soldering jig:
https://www.rcgroups.com/forums/show...72&postcount=4
Centre of gravity finder:
https://www.rcgroups.com/forums/show...8&postcount=62
https://www.rcgroups.com/forums/show...&postcount=283
Motor thrust measuring stands:
https://www.rcgroups.com/forums/show...&postcount=304
https://www.rcgroups.com/forums/show...&postcount=423
Propellor pitch gauge:
https://www.rcgroups.com/forums/show...&postcount=419
Transmitter programming station:
https://www.rcgroups.com/forums/show...&postcount=215
Jul 02, 2014, 12:53 PM
Steve85's Avatar
Future use...
Nov 03, 2014, 11:13 AM
Promoting Model Aviation...
Murocflyer's Avatar
Great idea for a thread.
Here is a link to a video for making clean holes in film covering.
Making Clean Holes in Covering Film (2 min 30 sec)
Here is a thread for tools for working with balsa.
https://www.rcgroups.com/forums/show....php?t=2069192
Would you like some other links to add to yours above?
Frank
Nov 11, 2014, 09:15 PM
Murocflyer's Avatar
Steve,
I put this thread together from all the posts in the balsa builders forum. https://www.rcgroups.com/forums/show....php?t=2280159 Hope this helps with your thread.
Frank
Jan 12, 2015, 06:00 AM
Gluing wings halfs together ?
Can someone point me in the direction for strengthening wing center section after joining 2 wing haves. I'm building a Air Flair Sundancer 40
Feb 09, 2015, 10:06 PM
Tommy Toy the Crazy Boy
What COG should I use?
I'm rebuilding a very old sport plane. I'm finished except I have no clear idea of where the COG should be so I can balance the plane before the maiden flight. How do I figure out where I should start with the COG?
Tom
Feb 09, 2015, 10:44 PM
TScott1118's Avatar
Center of the spar is a pretty safe bet.
Tom
Latest blog entry: Maiden flight of my Mini BOT
Feb 12, 2015, 04:17 PM
Steve85's Avatar
Hey rcers,
I haven't built the Sundancer, but having seen photos of it, I'd recommend some 1/16" sheet balsa in the two wing root rib bays, and then some 2" fiberglass tape epoxied over the joint.
Steve
Feb 19, 2015, 07:13 PM
Just Jamie and Me
babblefish's Avatar
Just to add my 2 cents, the technique mentioned for making holes in balsa using sharpened brass tubing also works great on foam. No need to cut teeth into the brass, I just sharpen the inside edge with a hobby knife. For the smaller sizes, I chuck the tube into my elecric drill and it makes quick and clean holes, in balsa or foam.
Last edited by babblefish; Feb 22, 2015 at 06:34 PM. Reason: Added more information
Mar 08, 2015, 11:05 PM
As a cutting tool. I took one of the Xacto thin, fine saw blades (approx. 1 x 4") and using a dremel with the cut off grinding wheel, cut off the strong back of the saw for a couple of inches. Gives a thin saw that can be used to cut deeper than the strong back allows and also allows for making flush cuts using a little of the flex of the blade.
Mar 09, 2015, 08:59 AM
Micro-Mark has a number of specialty cutting tools, including a flexible razor saw with no back. Personally, I like these:
http://www.micromark.com/no-11-size-...f-4,11860.html
